Re: [RCP] Ctrl+S for Save not working [message #252444 is a reply to message #250483] |
Mon, 14 June 2004 19:45 |
Originally posted by: douglas.pollock.magma.ca
David Graham wrote:
> However, pressing Ctrl+S does not run the save action. How can I get
> the shortcut to work?
Could you running with some debugging options, and then open a bug
describing the problem in detail (preferrably with sample code showing the
problem)?
You would need to create a file some on disk called "options". In it put
the following 4 lines:
org.eclipse.ui/debug=true
org.eclipse.ui/trace/contexts=true
org.eclipse.ui/trace/keyBindings=true
org.eclipse.ui/trace/keyBindings.verbose=true
Then, open a command prompt and run Eclipse. Start Eclipse with the
following additional parameter:
-debug C:\path\to\options
Then recreate the problem (preferrably without pressing any keys except for
the "Ctrl+S"). Include the output from the command prompt.
thanks,
d.
FUDForum. Page generated in 0.03345 seconds
