Home » Language IDEs » Java Development Tools (JDT) » Prevent lines from unwrapping in the formatter
Prevent lines from unwrapping in the formatter [message #249871] Wed, 28 November 2007 14:22
Originally posted by: markr.date.com
Does anyone know of a way to use the Java code Formatter without having it
enforce a certain line-wrapping mode? For example, our code contains many
SQL strings which are made up of constants and string literals, such as:
String sql =
" SELECT * " +
" FROM "
TABLE_A + ", " +
TABLE_B + " " +
" WHERE " + FIELD_A_A + " = " + FIELD_B_A +
" AND " + FIELD_A_B + " = ? ";
The formatter always wants to mess around with this no matter what
settings I use. What I want is for it to ignore the formatting of
expressions and instead do OTHER formatting tasks, such as converting
spaces to tabs (or vice versa) and formatting brackets.
Is there a way to disable certain parts of the formatter?
Alternate question: Is there a way to invoke only certain
micro-formattings, such as converting tabs to spaces?
Previous Topic:IJavaElement from ITextSelection
Next Topic:ASTParser on a JSP page
Current Time: Mon Sep 15 22:19:11 EDT 2025
Powered by FUDForum. Page generated in 0.02651 seconds
