Home » Archived » BIRT » Barcode Fonts Support, Status?
Re: Barcode Fonts Support, Status? [message #249857 is a reply to message #249794] |
Thu, 26 July 2007 00:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Wang Qiangsheng![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=qwang%40actuate.com) Messages: 76 Registered: July 2009 |
Member |
Raishad wrote:
> I've looked through the newsgroup looking at the posts concerning
> barcode fonts. I saw a post mentioning that barcode fonts should be
> supported as of v2.1.0 RC4 due to this bugfix,
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=140666
> But I'm still not able to use barcode fonts correctly.
> I'm using the free barcode font "Free 3 of 9" from here
> http://www.squaregear.net/fonts/free3of9.shtml
> When I change a data field's font to "Free 3 of 9", I'm able to see it
> at design time in BIRT Report Designer. But when I run the report,
> either by deploying it to jboss or from the "View Report as ... " Menu,
> the font reverts back to the default report font.
> I am using BIRT 2.2 on JDK 1.5.0_12. When I deploy to Jboss, I'm using
> the standard Report Viewer that comes with the Runtime.
> Any help would be appreciated
> Raishad
Could you open the design file with a text editor and make sure if the
font name was quoted or not? If not, feel free to reopen that
bug.Attach the design file is helpful as well.
Qiangsheng
Re: Barcode Fonts Support, Status? [message #250033 is a reply to message #249857] |
Thu, 26 July 2007 15:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Raishad![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=rincewind1013%40gmail.com) Messages: 77 Registered: July 2009 |
Member |
WangQS wrote:
> Raishad wrote:
>> Thanks,
>> Raishad
> Regards
> Qiangsheng
I updated the bug, https://bugs.eclipse.org/bugs/show_bug.cgi?id=140666#c10
But I'm not able to reopen it. I went ahead and attached a test report
as well
Raishad
Re: Barcode Fonts Support, Status? [message #250105 is a reply to message #250033] |
Fri, 27 July 2007 00:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
Raishad wrote:
> WangQS wrote:
>> Raishad wrote:
>>> Hi,
>>> Thanks,
>>> Raishad
>> Regards
>> Qiangsheng
> as well
> Raishad
I reopened the bug. Please keep tracing.
Qiangsheng
Current Time: Sun Sep 01 06:24:19 GMT 2024
Powered by FUDForum. Page generated in 0.03585 seconds
