C++ Compilers which work with Eclipse [message #249601] |
Thu, 21 February 2008 06:38 |
Originally posted by: volunteer.bokss.org.hk
What is your personal choice of C++ compiler(s) which work(s) with Eclipse?
MingGW, gnu or any others? Can I use MS Visual compilers with Eclipse?
Jack
Re: C++ Compilers which work with Eclipse [message #249927 is a reply to message #249601] |
Sat, 23 February 2008 03:14 |
Originally posted by: irbull.cs.uvic.ca
Hi Jacky, I think you can use the MS compilers, however, this question
is probably better addressed on the CDT newsgroup. That newsgroup is
only about C/C++ tooling for eclipse.
cheers
ian
Jacky Luk wrote:
> Thanks
> Jack
Re: C++ Compilers which work with Eclipse [message #249935 is a reply to message #249601] |
Sat, 23 February 2008 05:33 |
Originally posted by: jim.marshall.wbemsolutions.com
Jacky Luk wrote:
> Thanks
> Jack
CDT is designed to use GCC (MinGW or Cygwin). Out of the "box" CDT will
not use MS compilers.
FUDForum. Page generated in 0.07347 seconds
