Home » Archived » BIRT » NullPointerException Encountered When Loading A Report Design File
NullPointerException Encountered When Loading A Report Design File [message #249576] Tue, 24 July 2007 15:17 Go to next message
Originally posted by: ryan.tidwell.level3.com
I'm puzzled by the following NullPointerException that I encounter
whenever I try to open a report design file. Currently, BIRT is useless
because I can't open reports to edit them or create new ones. Any ideas as
to what might be causing this?
-Ryan
org.eclipse.birt.report.designer.ui.editors.MultiPageReportE ditor.addPages(MultiPageReportEditor.java:222)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:146)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
org.eclipse.birt.report.designer.ui.editors.ReportEditorProx y.createPartControl(ReportEditorProxy.java:121)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2719)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2539)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1090)
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:105)
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:75)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: NullPointerException Encountered When Loading A Report Design File [message #249769 is a reply to message #249576] Wed, 25 July 2007 11:59 Go to previous messageGo to next message
Ryan,
What version of Birt are you using?
Can you try the allinone download?
Jason
> as to what might be causing this?
> -Ryan
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: NullPointerException Encountered When Loading A Report Design File [message #249806 is a reply to message #249769] Wed, 25 July 2007 14:58 Go to previous messageGo to next message
Jason,
I'm using BIRT 2.1.2. I'm using the pre-packaged report designer, and
it runs fine on my machine. The EXACT same setup on a different machine is
what has been giving me headaches. I thought maybe Java 1.6 was the
problem, but even after going back to Java 1.5, I was still encountering
these same problems.
-Ryan
Re: NullPointerException Encountered When Loading A Report Design File [message #249813 is a reply to message #249806] Wed, 25 July 2007 15:15 Go to previous messageGo to next message
It appears to be having an issue on this line:
if ( !MessageDialog.openConfirm( UIUtil.getDefaultShell( ),
Messages.getString(
"MultiPageReportEditor.CheckVersion.Dialog.Title" ), //$NON-NLS-1$
info.getLocalizedMessage( ) ) )
Can you log a bugzilla entry for this? Also does it matter if you
download the allinone and put in a different directory? Try that and
create a new report.
Jaosn
Ryan Tidwell wrote:
> Jason,
> is what has been giving me headaches. I thought maybe Java 1.6 was the
> -Ryan
Re: NullPointerException Encountered When Loading A Report Design File [message #249870 is a reply to message #249806] Wed, 25 July 2007 20:52 Go to previous messageGo to next message
Ryan Tidwell wrote:
> Jason,
> -Ryan
Did you use a old version of design file with the new 2.2 version of
Eclipse? Please file a bug and attach the design file as well.
Qiangsheng
Re: NullPointerException Encountered When Loading A Report Design File [message #249908 is a reply to message #249813] Wed, 25 July 2007 23:39 Go to previous messageGo to next message
I can't reproduce this bug.
After studying the error log, I found that the error should be:
List message = ModuleUtil.checkVersion( fileName );
if ( message.size( ) > 0 )
IVersionInfo info = (IVersionInfo) message.get( 0 ); // Error on this
line.
Whether I open an old file with 2.2 or open a newer file with 2.1.2, it
works.
Though from the error log and code, I guess there're some errors in the
function ModuleUtil.checkVersion( fileName ), I suggest Ryan file a bug and
decribe it in detail, so that BIRT developers can fix it soon.
Frank.
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:f887dk$71m$1@build.eclipse.org...
> Messages.getString( "MultiPageReportEditor.CheckVersion.Dialog.Title" ),
> //$NON-NLS-1$
> Jaosn
> Ryan Tidwell wrote:
>> Jason,
>> -Ryan
Re: NullPointerException Encountered When Loading A Report Design File [message #249917 is a reply to message #249576] Thu, 26 July 2007 01:13 Go to previous message
> -Ryan
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Please add your comments on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197907.
Previous Topic:Data cube problem
Next Topic:Getting Started with Pie Chart
Current Time: Tue Sep 16 15:22:37 EDT 2025
Powered by FUDForum. Page generated in 0.04940 seconds
