What is the meaning of "mapsTo"? [message #24559] |
Mon, 19 March 2007 12:37  |
Hi Dennis,
in some of your transformations, I see the keyword "mapsTo":
rule DurationInterval {
from s : UML2!uml::DurationInterval (thisModule.inElements->includes(s))
to t : UML2!uml::DurationInterval mapsTo s ( ... )
What does this keyword do?
Cheers
Matthias
[ATL] Re: What is the meaning of "mapsTo"? [message #24829 is a reply to message #24559] |
Tue, 20 March 2007 12:32   |
Matthias Bohlen schreef:
> Hi Dennis,
> Cheers
> Matthias
Short answer:
The keyword currently does nothing. You may ignore it.
Long answer:
The "mapsTo" keyword is meant to specify that "s" is replaced by "t" for
every reference to "s". The current behaviour of ATL is to always
replace the source element by the first target element. Consider the
following example:
rule A {
from s : UML!Class
to t : RDB!Table (
columns <- s.ownedAttribute)
rule B {
from s : UML!Attribute
to t : RDB!Column (
name <- s.name),
index : RDB!Index (
name <- s.name)
RDB!Table cannot contain UML!Attribute elements as columns (rule A).
That's why s.ownedAttribute is replaced with what it "mapsTo". This is
defined in rule B: each UML!Attribute is mapped to a RDB!Column. So,
what happens when I change the order of "t" and "index" in rule B?
Remember that only the first target element in each rule gets this
special "mapsTo" treatment: if each UML!Attribute maps to an RDB!Index,
rule A becomes invalid: it tries to assign a Sequence of RDB!Index to
columns.
I found this special treatment of the first target element too
significant to remain implicit and I've added the "mapsTo" keyword to
make it explicit.
I'm not sure if this was a wise decision, since it likely makes you
believe that you can use "mapsTo" on other target elements as well. This
is not true, since "mapsTo" does nothing at the moment. It also provokes
questions like "What does this keyword do?" ;-). I suppose Frédéric
should just take it out of the parser and force me to update my
transformations, so I can stop shooting myself in the foot with this ;-).
Dennis
Re: [ATL] Re: What is the meaning of "mapsTo"? [message #25295 is a reply to message #24829] |
Fri, 23 March 2007 18:11  |
Hi Dennis,
> I suppose Frédéric
Well, taking mapsTo out of the parser would create some compatibility
issues (at least for your transformations ;-)).
Another solution would be to detect any use of mapsTo that attempts to
change the implemented behavior (e.g., using mapsTo on another element
than the first), and to report an error when this happens.
This way, using mapsTo the way you do would remain possible.
Frédéric Jouault
FUDForum. Page generated in 0.07021 seconds
