Home » Archived » BIRT » Problems with 2.2 WebViewer example and MacOSX ...
Problems with 2.2 WebViewer example and MacOSX ... [message #249347] Sun, 22 July 2007 19:56 Go to next message
I know BIRT does not support MacOSX. But for the future and for folks
who run into this issue:
1. installing birt-viewer on macosx works fine. The top page is
displayed properly along with the right version numbers
2. Clicking on the report will give you an error, the catalina.err file
has the following output:
SEVERE: Servlet.service() for servlet ViewerServlet threw exception
java.lang.NoClassDefFoundError
sun.print.UnixPrintServiceLookup.getPrintServices(UnixPrintS erviceLookup.java:340)
javax.print.PrintServiceLookup.getServices(PrintServiceLooku p.java:359)
javax.print.PrintServiceLookup.lookupPrintServices(PrintServ iceLookup.java:105)
3. You can workaround the above by editing your web.xml and changing the
print variable to OFF
<context-param>
<param-name>BIRT_VIEWER_PRINT_SERVERSIDE</param-name>
<param-value>OFF</param-value>
</context-param>
4. I cannot run test1.rptdesign though, i get the following error:
SEVERE: Error happened while running the report.java.lang.InternalError:
Can't connect to window server - not enough permissions. at
java.lang.ClassLoader$NativeLibrary.load(Native Method) at
java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751) at
java.lang.ClassLoader.loadLibrary(ClassLoader.java:1668)
5. I get the same error when trying to do a PDF printout of a report
Hope this helps someone and let me know if there are fixes/resolutions
for the above. Our java knowledge is a bit weak at the moment, we hope
to improve this soon
lobo
Re: Problems with 2.2 WebViewer example and MacOSX ... [message #249362 is a reply to message #249347] Mon, 23 July 2007 06:25 Go to previous messageGo to next message
> at
> at
> at
> <context-param>
> </context-param>
> lobo
could you file a bug for this under Mac OS?
thanks
Qs
Re: Problems with 2.2 WebViewer example and MacOSX ... [message #249377 is a reply to message #249347] Mon, 23 July 2007 12:24 Go to previous messageGo to next message
Donald,
Thanks for trying to run BIRT on MAC. Our hope is to provide better support
for additional operating systems through a community certification process.
The bugzilla entry is https://bugs.eclipse.org/bugs/show_bug.cgi?id=183645.
The plan is for bugs to be submitted through the standard process and tested
by community members. You may want to follow the Bugzilla if you are interested.
Scott Rosenbaum
> file has the following output:
> at
> up.java:340)
> at
> at
> java:105)
> the print variable to OFF
> <context-param>
> </context-param>
> lobo
Re: Problems with 2.2 WebViewer example and MacOSX ... [message #249389 is a reply to message #249362] Mon, 23 July 2007 15:47 Go to previous messageGo to next message
done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197538
lobo
>> at
>> at
>> at
>> <context-param>
>> </context-param>
>> lobo
> thanks
> Qs
Re: Problems with 2.2 WebViewer example and MacOSX ... [message #249391 is a reply to message #249377] Mon, 23 July 2007 16:13 Go to previous messageGo to next message
Originally posted by: mackingzone.gmail.com
Speaking of supporting platforms, could somebody here kindly provide the
complete list or are there any links out there for this information?
Ethan
Scott Rosenbaum wrote:
> Donald,
tested
interested.
> Scott Rosenbaum
>> at
>> up.java:340)
>> at
>> at
>> java:105)
>> <context-param>
>> </context-param>
>> lobo
Re: Problems with 2.2 WebViewer example and MacOSX ... [message #249393 is a reply to message #249391] Mon, 23 July 2007 16:45 Go to previous messageGo to next message
Ethan,
Here is a link to the 2.2.1 Development Plan which lists the supported platforms.
The only new support in 2.2.1 is for Windows Vista.
http://www.eclipse.org/birt/phoenix/project/project_plan_R2_ 2_1.php
Scott Rosenbaum
> the complete list or are there any links out there for this
> information?
> Ethan
>> Donald,
>> support for additional operating systems through a community
>> certification process. The bugzilla entry is
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=183645. The plan is for
> tested
> interested.
>> Scott Rosenbaum
>>> folks who run into this issue:
>>> at
>>> ok
>>> up.java:340)
>>> at
>>> 59
>>> at
>>> p.
>>> java:105)
>>> <context-param>
>>> </context-param>
>>> fixes/resolutions for the above. Our java knowledge is a bit weak at
>>> the moment, we hope to improve this soon
>>> lobo
Re: Problems with 2.2 WebViewer example and MacOSX ... [message #249881 is a reply to message #249389] Wed, 25 July 2007 21:02 Go to previous message
Qiangsheng
Donald Lobo wrote:
> done:
> lobo
>>> at
>>> at
>>> at
>>> <context-param>
>>> </context-param>
>>> lobo
>> thanks
>> Qs
Previous Topic:Birt Report Message... The following items have errors...
Next Topic:How to make the text-box parameter read-only?
Current Time: Sat Oct 18 12:02:47 EDT 2025
Powered by FUDForum. Page generated in 0.05004 seconds
