How do I get Eclipse to run 1.6 annotation processor? [message #249346] |
Thu, 08 November 2007 00:07 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: alexinbeijing.gmail.com
I am sure the answer to this question is very simple but I can't figure
out what it is. Here is my situation:
1. Running a brand new download of Eclipse 3.3, using JRE 1.6.0_03-b05.
2. "Compiler compliance" set to 6.0 in project properties.
3. I have a JAR with an annotation processor in it, which subclasses from
AbstractProcessor.
4. I go into project properties, Java Compiler -> Annotation Processing
and select "Enable Annotation Processing".
5. Go into Java Compiler -> Annotation Processing -> Factory Path and add
the JAR with the JSR 269 annotation processor in it.
6. Click on "Advanced...", and no processors are displayed in the
"Advanced Options" dialog.
How can I get Eclipse to "see" my annotation processor?
Thanks, Alex
Re: How do I get Eclipse to run 1.6 annotation processor? [message #249348 is a reply to message #249346] |
Thu, 08 November 2007 00:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wharley.bea.com
"Alex Dowad" <alexinbeijing@gmail.com> wrote in message
news:b2cf8ac773749ed14abaf48bfa9921d6$1@www.eclipse.org...
> AbstractProcessor.
Do you have a META-INF/services entry?
Re: How do I get Eclipse to run 1.6 annotation processor? [message #249350 is a reply to message #249348] |
Thu, 08 November 2007 00:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
"Walter Harley" <wharley@bea.com> wrote in message
news:fgtla5$j6v$1@build.eclipse.org...
Sorry, I guess I could be a bit less cryptic than that :-)
Processors are declared either in an extension (for plug-ins containing
processors) or in a file in the META-INF/services folder (for a jar), or
both (for plug-ins that also want to be compatible with javac).
The META-INF/services file follows the general protocol for such files: the
file must have the name of the interface being implemented, and then contain
a line of text that is the name of the implementation class (or multiple
such lines, if there are multiple implementations).
In this case, the file would be
META-INF/services/javax.annotation.processing.Processor, and the contents
would be something like:
# A comment, prefixed by the hash symbol
org.xyz.processors.MyFirstProcessor
org.xyz.processors.SomeOtherProcessor
FUDForum. Page generated in 0.03987 seconds
