Home » Archived » BIRT » DB2 query
DB2 query [message #249171] Fri, 20 July 2007 10:47 Go to next message
Originally posted by: alvin_yeung.otpp.com
I am trying to write a DB query in BIRT that look like this
SELECT *
FROM DBADMIN.TABLENAME AS TABLENAME
WHERE TABLENAME.OBJECTNAME LIKE '%?%'.
Basically, this query should return rows in TABLENAME.OBJECTNAME that
contain my BIRT Report Parameter.
However, eclipse editor do not recognize '%?%' contain any parameter.
How do I do this?
Thanks. Any help is appreciated.
Re: DB2 query [message #249190 is a reply to message #249171] Fri, 20 July 2007 11:15 Go to previous message
Originally posted by: monicaerbes.trascender.com.ar
you can try with :
SELECT *
WHERE TABLENAME.OBJECTNAME LIKE '%'||?||'%'
Luck
"alvin" <alvin_yeung@otpp.com> escribi
Previous Topic:Date/Time axis label localization issue
Next Topic:BIRT & Actuate BIRT
Current Time: Fri Apr 25 22:02:07 EDT 2025
Powered by FUDForum. Page generated in 0.03506 seconds
