high priority :Quarey problem in BIRT and thanks for Tianli [message #249161] |
Fri, 20 July 2007 14:33 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi All & Tianli
First thanks for Tianli for the providing sound result.
yes i am using BIRT sample database. now i can able to run the report with
date parameter.
But:
My Problem in query like:
select * from sas_received_faxes
where sas_received_faxes.RECEIVED_DATE between ? and ?
or sas_received_faxes.FILE_NAME like ?
In this case the 3 parameters are optional, i need any either date vise
or particular fax_name,
but i am getting following error:
OdaDataSet Data Set:
- Error evaluating Javascript expression. Script engine error: missing ;
before statement
Script source: property binding, line: 0, text:
params["From_Date"]params["To_Date"]
Data (id = 67):
- There are errors evaluating script "row["FILE_NAME"]".
could you please assist me in this this is high priority task for me.
JP
FUDForum. Page generated in 0.03238 seconds
