Home » Eclipse Projects » DTP » Why does "Driver Definition" include connection properties?
Why does "Driver Definition" include connection properties? [message #24494] Tue, 19 December 2006 04:04 Go to next message
Originally posted by: joerg.von.frantzius.artnology.com
I didn't have a look yet into the DTP EMF models, but at least in the UI
it seems that a Driver Definition includes properties of the actual
connection, like connection URL, database name etc.
Shouldn't these be two seperate things, the Driver Definition and the
Connection Definition? Currently, if I want to connect to two different
databases using the same JDBC driver, I have to specify JDBC driver jar
+ class name for each connection. That's redundant (something that
should ring a bell in the ears of DB vendors' employees, shouldn't it ;-)
Jörg
Re: Why does "Driver Definition" include connection properties? [message #24656 is a reply to message #24494] Tue, 19 December 2006 16:16 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi Jorg!
The "redundant" properties you see in the driver definition are there to
provide defaults to the profile wizard. Once you've defined a driver
definition for your driver type (let's use Derby as an example), any time
you create a new Derby profile, you can reuse the driver definition and not
have to provide the same details over again.
Does that help?
--Brian Fitzpatrick
Sybase, Inc.
DTP/Connectivity Committer
"J
Re: Why does "Driver Definition" include connection properties? [message #24696 is a reply to message #24494] Tue, 19 December 2006 16:29 Go to previous messageGo to next message
Hi Jorg...
One more thing... You might check out our Usability Wiki and provide some
feedback there if you would like to...
http://wiki.eclipse.org/index.php/Connectivity:Usability
"J
Re: Why does "Driver Definition" include connection properties? [message #24808 is a reply to message #24656] Wed, 20 December 2006 05:07 Go to previous message
--------------070109070103040804020807
Hello Brian,
that helps, unfortunately a different bug had kept me from finding that
out.
Maybe the labels could say something like "Example URL" or "Default
URL", "Default User ID" and "Default Password" so that this becomes
clear? At the first look it seems these properties will be fixed just as
the "Driver Class", which cannot be changed per connection profile.
J
Re: Why does "Driver Definition" include connection properties? [message #583617 is a reply to message #24494] Tue, 19 December 2006 16:16 Go to previous message
Hi Jorg!
Does that help?
--Brian Fitzpatrick
Sybase, Inc.
"J
Re: Why does "Driver Definition" include connection properties? [message #583642 is a reply to message #24494] Tue, 19 December 2006 16:29 Go to previous message
Hi Jorg...
"J
Re: Why does "Driver Definition" include connection properties? [message #583683 is a reply to message #24656] Wed, 20 December 2006 05:07 Go to previous message
Hello Brian,
out.
J
Previous Topic:table data editor Sample Content
Next Topic:DTP 1.0 released
Current Time: Wed Apr 16 02:44:15 EDT 2025
Powered by FUDForum. Page generated in 0.03805 seconds
