Home » Eclipse Projects » DTP » No catalogs found for database
No catalogs found for database [message #24451] Mon, 18 December 2006 15:53 Go to next message
Originally posted by: francine.grimmer.ncr.com
We are seeing the console message "No catalogs found for database. Update
catalog loader to support catalogs." when we connection to our database.
Our database does not support catalogs. According to the SQL Model it is
not required to support catalogs. Everything seems to work OK. Will this
message go away before DTP 1.0 final build?
Re: No catalogs found for database [message #24616 is a reply to message #24451] Tue, 19 December 2006 16:11 Go to previous messageGo to next message
Francine,
That message is just debug output that will not appear outside the IDE. As
you have noted, the model works fine without this notion. We weren't
planning to remove it for 1.0, but does it cause a problem for you if
there?
John Graham
Eclipse Data Tools Platform PMC Chair
Re: No catalogs found for database [message #24735 is a reply to message #24616] Tue, 19 December 2006 19:00 Go to previous message
No, we can ignore it. I just wanted to make sure we weren't missing
anything.
thanks,
-francine
Re: No catalogs found for database [message #583603 is a reply to message #24451] Tue, 19 December 2006 16:11 Go to previous message
Francine,
there?
John Graham
Re: No catalogs found for database [message #583654 is a reply to message #24616] Tue, 19 December 2006 19:00 Go to previous message
anything.
thanks,
-francine
Previous Topic:Why does "Driver Definition" include connection properties?
Next Topic:table data editor Sample Content
Current Time: Wed Apr 16 02:44:50 EDT 2025
Powered by FUDForum. Page generated in 0.24738 seconds
