Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench". [message #24448] |
Fri, 01 April 2005 23:51  |
Originally posted by: changxh.huirensoft.com
I have used eclipse-SDK-3.1M5a-win32 、birt-designer-S20050328, I follow
the the birt tutorial,when I create New Report,push the button "Finish",
see the following errors. Please Help me,thanks.
Message
Exception Stack Trace
org.eclipse.gef.ui.actions.ActionBarContributor.setActiveEdi tor(ActionBarContributor.java:141)
org.eclipse.ui.internal.EditorActionBars.partChanged(EditorA ctionBars.java:310)
at org.eclipse.ui.internal.WorkbenchPage$4.run(WorkbenchPage.ja va:580)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1015)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:570)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2806)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:559)
org.eclipse.ui.views.markers.internal.ActionOpenMarker.run(A ctionOpenMarker.java:69)
org.eclipse.ui.views.markers.internal.MarkerView.handleOpenE vent(MarkerView.java:516)
org.eclipse.ui.views.markers.internal.TableView$2.open(Table View.java:169)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:659)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:657)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:876)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:975)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2908)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2541)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Session Data
eclipse.buildId=I20050219-1500
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86
FUDForum. Page generated in 0.04246 seconds
