Re: Reusing JDT's code [message #248616 is a reply to message #248548] |
Wed, 10 October 2007 20:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: wharley.bea.com
"Ary Manzana" <ary@esperanto.org.ar> wrote in message
news:fehamc$bms$1@build.eclipse.org...
> I'm working on an eclipse plugin that is an IDE for a language, and for
> that I'm reusing some of JDT's code. Do I have to license the plugin as
> EPL?
> The problem is, the project also contains a port of a compiler's front-end
> which is licensed with the Artistic License, so If license the port with
> EPL... problems.
> What do you suggest?
You're right that incompatibility between various open-source licenses is a
big problem.
In general, folks on the Eclipse newsgroups are not lawyers, and even
lawyers have a hard time understanding what some of these licenses do or
don't permit. In fact some licenses seem to be intentionally written to
produce that effect. Therefore you are very unlikely to get a definitive
"yes" or "no" here, and if you do, you shouldn't trust it.
There is a FAQ on the Eclipse license (EPL) at
http://www.eclipse.org/legal/eplfaq.php. You might be interested in item
14. Also, hunting on the web for information on the Artistic License I see
that there is more than one version of it, so you probably need to pay
careful attention to which version you are using.
Personally, if it were me, I'd contact the author of the compiler and ask
them what their actual intent is.
FUDForum. Page generated in 0.02835 seconds
