Home » Archived » BIRT » Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench". [message #24448] Fri, 01 April 2005 23:51 Go to next message
Originally posted by: changxh.huirensoft.com
I have used eclipse-SDK-3.1M5a-win32 、birt-designer-S20050328, I follow
the the birt tutorial,when I create New Report,push the button "Finish",
see the following errors. Please Help me,thanks.
Message
Exception Stack Trace
org.eclipse.gef.ui.actions.ActionBarContributor.setActiveEdi tor(ActionBarContributor.java:141)
org.eclipse.ui.internal.EditorActionBars.partChanged(EditorA ctionBars.java:310)
at org.eclipse.ui.internal.WorkbenchPage$4.run(WorkbenchPage.ja va:580)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1015)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:570)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2806)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:559)
org.eclipse.ui.views.markers.internal.ActionOpenMarker.run(A ctionOpenMarker.java:69)
org.eclipse.ui.views.markers.internal.MarkerView.handleOpenE vent(MarkerView.java:516)
org.eclipse.ui.views.markers.internal.TableView$2.open(Table View.java:169)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:659)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:657)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:876)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:975)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:243)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:238)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:277)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2908)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2541)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Session Data
eclipse.buildId=I20050219-1500
java.version=1.5.0_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86
Re: Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench". [message #24692 is a reply to message #24448] Sun, 03 April 2005 18:54 Go to previous message
BIRT has not been tested on the Eclipse 3.1 build and known problems exist.
We recommend using Eclipse 3.0.1 with BIRT.
That said, the team is fixes 3.1 problems as they are found. Can you please
add a Bugzilla entry for the problem you discovered? There is a link to
Bugzilla on the "community" page on the BIRT web site.
- Paul
Paul Rogers
BIRT PMC
Previous Topic:Using BIRT Engine
Next Topic:Comments & case studies needed for article
Current Time: Wed Apr 16 02:44:35 EDT 2025
Powered by FUDForum. Page generated in 0.03095 seconds
