Home » Modeling » M2T (model-to-text transformation) » get a JET variable in a scriptlet
get a JET variable in a scriptlet [message #24433] Thu, 28 June 2007 10:02 Go to next message
I would like to simply access a variable value in a scriptlet but Im stuck.
<c:setVariable var="varName" select="$person/@name" />
if(context.hasVariable("varName"))
String tmp = (String)context.getVariable("varName");
System.out.println("varName is : "+ varName);
But this doesn't work. There is a problem during the parsing to a
String. What is the right way ?
Tex.
Re: get a JET variable in a scriptlet [message #24514 is a reply to message #24433] Thu, 28 June 2007 10:22 Go to previous message
This works better :
<c:setVariable var="varName" select="string($person/@name)" />
Tex Twil wrote:
> Tex.
Previous Topic:simple IF .. ELSE statement
Next Topic:Re: invoke template from java with string return?
Current Time: Sat Nov 01 13:26:50 EDT 2025
Powered by FUDForum. Page generated in 0.03625 seconds
