Home » Eclipse Projects » GEF » drag and drop between to editors
drag and drop between to editors [message #248377] Fri, 17 April 2009 12:20 Go to next message
hi all,
i m trying to implement a drag and drop between to gef editors.
Therefore i added a DragSourceListener and DropTargetListener to my
GraphicalViewer.
Code:
protected void initializeGraphicalViewer() {
viewer.addDropTargetListener(new MyDropTargetListener(viewer));
viewer.addDragSourceListener(new MyDragSourceListener(viewer));
MyDragSourceListener extends from AbstractTransferDragSourceListener and
looks like this:
Code:
public MyDragSourceListener(EditPartViewer viewer) {
super(viewer,MyTransfer.getInstance());
@SuppressWarnings("unchecked")
public void dragStart(DragSourceEvent event) {
event.doit = false;
if (MyTransfer.getInstance().isDragAllowed()) {
List selectedEditParts = getViewer().getSelectedEditParts();
if (selectedEditParts.size() == 1) {
EditPart selectedPart = (EditPart) selectedEditParts.get(0);
if (selectedPart instanceof ComponentEditPart) {
MyTransfer.getInstance().setObject(selectedPart);
event.doit = true;
public void dragSetData(DragSourceEvent event) {
event.data = selectedEditPart; //class member
MyTransfer extends from SimpleObjectTransfer and i added a method to
determine a condition. This is because there was a problem moving
elements of the diagram after adding the DragSourceListener to my
GraphicalViewer ( see for details
http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg1 6123.html ).
When i start dragging a diagram element the dragStart-method would
invoked and all the code will executed. But then nothing happen anymore.
My mouse cursor in the application shows the blocking icon and the
setDragData-method will not invoked.
Whats wrong? Is there maybe an tutorial which describes the how to
implement a editor as drag source? For the other way (the editor as drop
target) several tutorials and news group entries exist but i cant find
some for my case.
Please help me.
Thanks in advance and best regards,
René
Re: drag and drop between to editors [message #248436 is a reply to message #248377] Mon, 20 April 2009 10:28 Go to previous message
hi all,
for further investigation of my problem override the method
isSupportedType(TransferData) in MyTransfer. So i could see that this
method is always false. That brings me to the suggestion that something
must be wrong with the transfer type.
In detail MyTransfer looks like this:
public class MyTransfer extends SimpleObjectTransfer {
private final static ComponentReferenceTransfer INSTANCE = new
MyTransfer ();
private boolean isDragAllowed = false;
private static final String TYPE_NAME =
"template_reference_transfer"//$NON-NLS-1$
+ System.currentTimeMillis() + ":"
+ INSTANCE.hashCode();//$NON-NLS-1$
private static final int TYPEID = registerType(TYPE_NAME);
private ComponentReferenceTransfer() {
public static ComponentReferenceTransfer getInstance() {
return INSTANCE;
protected int[] getTypeIds() {
return new int[] { TYPEID };
protected String[] getTypeNames() {
return new String[] { TYPE_NAME };
public boolean isDragAllowed() {
return isDragAllowed;
public void setDragAllowed(boolean isDragAllowed) {
this.isDragAllowed = isDragAllowed;
Is there anything wrong with that? Or i have to do more to determine the
transfer type correctly?
I hope you can help me. Thanks in advance.
René
René wrote:
> hi all,
> GraphicalViewer.
> Code:
> looks like this:
> Code:
> @Override
> event.doit = false;
> event.doit = true;
> @Override
> some for my case.
> Please help me.
> René
Previous Topic:[zest] how to draw bends in connections
Next Topic:drawing shapes
Current Time: Fri Apr 25 21:47:29 EDT 2025
Powered by FUDForum. Page generated in 0.03072 seconds
