Home » Archived » Maven Integration (M2E) » How to import a module project?
How to import a module project? [message #24389] Mon, 30 March 2009 09:11 Go to next message
Yves Schumann is currently offline Yves SchumannFriend
Member
Maybe I can't see the wood because of the huge amount of trees, but how
can I import a module project into Eclipse? If I try to import an
existing project into workspace, then only the module project is
importet but not the modules itself!?
Otherwise it works to import at first the modules and after that the
module project itself. But that's really time-consuming and not
practicable.
So is it my failure or something else went wrong?
Yves
"Walking on water and developing software from a specification are easy
if both are frozen" -- Edward V. Berard
Re: How to import a module project? [message #24431 is a reply to message #24389] Mon, 30 March 2009 11:21 Go to previous messageGo to next message
Eugene Kuleshov is currently offline Eugene KuleshovFriend
http://docs.codehaus.org/display/M2ECLIPSE/Importing+Maven+p rojects
Yves Schumann wrote:
> Hi
> practicable.
> Yves
Re: How to import a module project? [message #24472 is a reply to message #24431] Mon, 30 March 2009 12:39 Go to previous message
Member
Hi Eugene
You made my day! It's so easy... Unbelievable... Thx a lot!
Yves
"Ich werde nie behaupten, dass ich die Nummer 1 bin, doch ich werde auch
nie zugeben, Nummer 2 zu sein." -- Bruce Lee
Previous Topic:Add Dependecy?
Next Topic:Can child modules be mutually dependent?
Current Time: Fri Nov 08 23:04:34 GMT 2024
Powered by FUDForum. Page generated in 0.02910 seconds
