Landscape orientation for PDF not working in servlet [message #247933] |
Sat, 14 July 2007 23:19  |
For my report I have set the orientation to be landscape. When I run the
report from Java Application the pdf is presented correctly as landscape.
However, when I run it in Jboss, it renders as portrait. Am I missing some
setting?
Please help.
Nisha
Re: Landscape orientation for PDF not working in servlet [message #248425 is a reply to message #248290] |
Tue, 17 July 2007 15:20   |
Thanks for looking into it. I have attached my report design:
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.2.v20070205-1728 Build <20070205-1728></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 <<Your Company Name
here>></property>
<property name="theme">General.defaultTheme</property>
<text-property name="displayName">HBSReportsTemplate</text-property>
<list-property name="libraries">
<structure>
<property name="fileName">General.rptlibrary</property>
<property name="namespace">General</property>
</structure>
</list-property>
<parameters>
<scalar-parameter name="Author" id="864" extends="General.Author"/>
<scalar-parameter name="StartDate" id="865"
extends="General.StartDate"/>
<scalar-parameter name="EndDate" id="866"
extends="General.EndDate"/>
<scalar-parameter name="CareManager" id="893">
<property name="hidden">true</property>
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="Physician" id="894">
</structure>
</scalar-parameter>
<scalar-parameter name="Program" id="895">
</structure>
</scalar-parameter>
<scalar-parameter name="Payor" id="896">
</structure>
</scalar-parameter>
<scalar-parameter name="RiskCategory" id="897">
</structure>
</scalar-parameter>
<scalar-parameter name="MedicalGroup" id="898">
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<script-data-source name="CommonScriptedDS" id="862"
extends="General.CommonScriptedDS"/>
<script-data-source name="ComplDS" id="891"/>
</data-sources>
<data-sets>
<script-data-set name="LogoData" id="863"
extends="General.LogoData"/>
<script-data-set name="ComplianceData" id="892">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">FullName</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">DOB</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">HomePhone</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">D1</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">D2</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">D3</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">D4</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">D5</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">D6</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">D7</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">D8</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">D9</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">D10</property>
</structure>
<structure>
<property name="position">14</property>
<property name="name">D11</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">D12</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">D13</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">D14</property>
</structure>
<structure>
<property name="position">18</property>
<property name="name">D15</property>
</structure>
<structure>
<property name="position">19</property>
<property name="name">D16</property>
</structure>
<structure>
<property name="position">20</property>
<property name="name">D17</property>
</structure>
<structure>
<property name="position">21</property>
<property name="name">D18</property>
</structure>
<structure>
<property name="position">22</property>
<property name="name">D19</property>
</structure>
<structure>
<property name="position">23</property>
<property name="name">D20</property>
</structure>
<structure>
<property name="position">24</property>
<property name="name">D21</property>
</structure>
<structure>
<property name="position">25</property>
<property name="name">D22</property>
</structure>
<structure>
<property name="position">26</property>
<property name="name">D23</property>
</structure>
<structure>
<property name="position">27</property>
<property name="name">D24</property>
</structure>
<structure>
<property name="position">28</property>
<property name="name">D25</property>
</structure>
<structure>
<property name="position">29</property>
<property name="name">D26</property>
</structure>
<structure>
<property name="position">30</property>
<property name="name">D27</property>
</structure>
<structure>
<property name="position">31</property>
<property name="name">D28</property>
</structure>
<structure>
<property name="position">32</property>
<property name="name">D29</property>
</structure>
<structure>
<property name="position">33</property>
<property name="name">D30</property>
</structure>
<structure>
<property name="position">34</property>
<property name="name">D31</property>
</structure>
<structure>
<property name="position">35</property>
<property name="name">D32</property>
</structure>
<structure>
<property name="position">36</property>
<property name="name">D33</property>
</structure>
<structure>
<property name="position">37</property>
<property name="name">D34</property>
</structure>
<structure>
<property name="position">38</property>
<property name="name">D35</property>
</structure>
<structure>
<property name="position">39</property>
<property name="name">R1</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">40</property>
<property name="name">R2</property>
</structure>
<structure>
<property name="position">41</property>
<property name="name">R3</property>
</structure>
<structure>
<property name="position">42</property>
<property name="name">R4</property>
</structure>
<structure>
<property name="position">43</property>
<property name="name">R5</property>
</structure>
<structure>
<property name="position">44</property>
<property name="name">R6</property>
</structure>
<structure>
<property name="position">45</property>
<property name="name">R7</property>
</structure>
<structure>
<property name="position">46</property>
<property name="name">R8</property>
</structure>
<structure>
<property name="position">47</property>
<property name="name">R9</property>
</structure>
<structure>
<property name="position">48</property>
<property name="name">R10</property>
</structure>
<structure>
<property name="position">49</property>
<property name="name">R11</property>
</structure>
<structure>
<property name="position">50</property>
<property name="name">R12</property>
</structure>
<structure>
<property name="position">51</property>
<property name="name">R13</property>
</structure>
<structure>
<property name="position">52</property>
<property name="name">R14</property>
</structure>
<structure>
<property name="position">53</property>
<property name="name">R15</property>
</structure>
<structure>
<property name="position">54</property>
<property name="name">R16</property>
</structure>
<structure>
<property name="position">55</property>
<property name="name">R17</property>
</structure>
<structure>
<property name="position">56</property>
<property name="name">R18</property>
</structure>
<structure>
<property name="position">57</property>
<property name="name">R19</property>
</structure>
<structure>
<property name="position">58</property>
<property name="name">R20</property>
</structure>
<structure>
<property name="position">59</property>
<property name="name">R21</property>
</structure>
<structure>
<property name="position">60</property>
<property name="name">R22</property>
</structure>
<structure>
<property name="position">61</property>
<property name="name">R23</property>
</structure>
<structure>
<property name="position">62</property>
<property name="name">R24</property>
</structure>
<structure>
<property name="position">63</property>
<property name="name">R25</property>
</structure>
<structure>
<property name="position">64</property>
<property name="name">R26</property>
</structure>
<structure>
<property name="position">65</property>
<property name="name">R27</property>
</structure>
<structure>
<property name="position">66</property>
<property name="name">R28</property>
</structure>
<structure>
<property name="position">67</property>
<property name="name">R29</property>
</structure>
<structure>
<property name="position">68</property>
<property name="name">R30</property>
</structure>
<structure>
<property name="position">69</property>
<property name="name">R31</property>
</structure>
<structure>
<property name="position">70</property>
<property name="name">R32</property>
</structure>
<structure>
<property name="position">71</property>
<property name="name">R33</property>
</structure>
<structure>
<property name="position">72</property>
<property name="name">R34</property>
</structure>
<structure>
<property name="position">73</property>
<property name="name">R35</property>
</structure>
<structure>
<property name="position">74</property>
<property name="name">M1</property>
</structure>
<structure>
<property name="position">75</property>
<property name="name">M2</property>
</structure>
<structure>
<property name="position">76</property>
<property name="name">M3</property>
</structure>
<structure>
<property name="position">77</property>
<property name="name">M4</property>
</structure>
<structure>
<property name="position">78</property>
<property name="name">M5</property>
</structure>
<structure>
<property name="position">79</property>
<property name="name">M6</property>
</structure>
<structure>
<property name="position">80</property>
<property name="name">M7</property>
</structure>
<structure>
<property name="position">81</property>
<property name="name">M8</property>
</structure>
<structure>
<property name="position">82</property>
<property name="name">M9</property>
</structure>
<structure>
<property name="position">83</property>
<property name="name">M10</property>
</structure>
<structure>
<property name="position">84</property>
<property name="name">M11</property>
</structure>
<structure>
<property name="position">85</property>
<property name="name">M12</property>
</structure>
<structure>
<property name="position">86</property>
<property name="name">M13</property>
</structure>
<structure>
<property name="position">87</property>
<property name="name">M14</property>
</structure>
<structure>
<property name="position">88</property>
<property name="name">M15</property>
</structure>
<structure>
<property name="position">89</property>
<property name="name">M16</property>
</structure>
<structure>
<property name="position">90</property>
<property name="name">M17</property>
</structure>
<structure>
<property name="position">91</property>
<property name="name">M18</property>
</structure>
<structure>
<property name="position">92</property>
<property name="name">M19</property>
</structure>
<structure>
<property name="position">93</property>
<property name="name">M20</property>
</structure>
<structure>
<property name="position">94</property>
<property name="name">M21</property>
</structure>
<structure>
<property name="position">95</property>
<property name="name">M22</property>
</structure>
<structure>
<property name="position">96</property>
<property name="name">M23</property>
</structure>
<structure>
<property name="position">97</property>
<property name="name">M24</property>
</structure>
<structure>
<property name="position">98</property>
<property name="name">M25</property>
</structure>
<structure>
<property name="position">99</property>
<property name="name">M26</property>
</structure>
<structure>
<property name="position">100</property>
<property name="name">M27</property>
</structure>
<structure>
<property name="position">101</property>
<property name="name">M28</property>
</structure>
<structure>
<property name="position">102</property>
<property name="name">M29</property>
</structure>
<structure>
<property name="position">103</property>
<property name="name">M30</property>
</structure>
<structure>
<property name="position">104</property>
<property name="name">M31</property>
</structure>
<structure>
<property name="position">105</property>
<property name="name">M32</property>
</structure>
<structure>
<property name="position">106</property>
<property name="name">M33</property>
</structure>
<structure>
<property name="position">107</property>
<property name="name">M34</property>
</structure>
<structure>
<property name="position">108</property>
<property name="name">M35</property>
</structure>
<structure>
<property name="position">109</property>
<property name="name">LastCall</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">FullName</property>
</structure>
<structure>
<property name="columnName">DOB</property>
</structure>
<structure>
<property name="columnName">HomePhone</property>
</structure>
<structure>
<property name="columnName">D1</property>
</structure>
<structure>
<property name="columnName">D2</property>
</structure>
<structure>
<property name="columnName">D3</property>
</structure>
<structure>
<property name="columnName">D4</property>
</structure>
<structure>
<property name="columnName">D5</property>
</structure>
<structure>
<property name="columnName">D6</property>
</structure>
<structure>
<property name="columnName">D7</property>
</structure>
<structure>
<property name="columnName">D8</property>
</structure>
<structure>
<property name="columnName">D9</property>
</structure>
<structure>
<property name="columnName">D10</property>
</structure>
<structure>
<property name="columnName">D11</property>
</structure>
<structure>
<property name="columnName">D12</property>
</structure>
<structure>
<property name="columnName">D13</property>
</structure>
<structure>
<property name="columnName">D14</property>
</structure>
<structure>
<property name="columnName">D15</property>
</structure>
<structure>
<property name="columnName">D16</property>
</structure>
<structure>
<property name="columnName">D17</property>
</structure>
<structure>
<property name="columnName">D18</property>
</structure>
<structure>
<property name="columnName">D19</property>
</structure>
<structure>
<property name="columnName">D20</property>
</structure>
<structure>
<property name="columnName">D21</property>
</structure>
<structure>
<property name="columnName">D22</property>
</structure>
<structure>
<property name="columnName">D23</property>
</structure>
<structure>
<property name="columnName">D24</property>
</structure>
<structure>
<property name="columnName">D25</property>
</structure>
<structure>
<property name="columnName">D26</property>
</structure>
<structure>
<property name="columnName">D27</property>
</structure>
<structure>
<property name="columnName">D29</property>
</structure>
<structure>
<property name="columnName">D30</property>
</structure>
<structure>
<property name="columnName">D31</property>
</structure>
<structure>
<property name="columnName">D32</property>
</structure>
<structure>
<property name="columnName">D33</property>
</structure>
<structure>
<property name="columnName">D34</property>
</structure>
<structure>
<property name="columnName">D35</property>
</structure>
<structure>
<property name="columnName">R1</property>
</structure>
<structure>
<property name="columnName">R2</property>
</structure>
<structure>
<property name="columnName">R3</property>
</structure>
<structure>
<property name="columnName">R4</property>
</structure>
<structure>
<property name="columnName">R5</property>
</structure>
<structure>
<property name="columnName">R6</property>
</structure>
<structure>
<property name="columnName">R7</property>
</structure>
<structure>
<property name="columnName">R8</property>
</structure>
<structure>
<property name="columnName">R9</property>
</structure>
<structure>
<property name="columnName">R10</property>
</structure>
<structure>
<property name="columnName">R11</property>
</structure>
<structure>
<property name="columnName">R12</property>
</structure>
<structure>
<property name="columnName">R13</property>
</structure>
<structure>
<property name="columnName">R14</property>
</structure>
<structure>
<property name="columnName">R15</property>
</structure>
<structure>
<property name="columnName">R16</property>
</structure>
<structure>
<property name="columnName">R17</property>
</structure>
<structure>
<property name="columnName">R18</property>
</structure>
<structure>
<property name="columnName">R19</property>
</structure>
<structure>
<property name="columnName">R20</property>
</structure>
<structure>
<property name="columnName">R21</property>
</structure>
<structure>
<property name="columnName">R22</property>
</structure>
<structure>
<property name="columnName">R23</property>
</structure>
<structure>
<property name="columnName">R24</property>
</structure>
<structure>
<property name="columnName">R25</property>
</structure>
<structure>
<property name="columnName">R26</property>
</structure>
<structure>
<property name="columnName">R27</property>
</structure>
<structure>
<property name="columnName">R28</property>
</structure>
<structure>
<property name="columnName">R29</property>
</structure>
<structure>
<property name="columnName">R30</property>
</structure>
<structure>
<property name="columnName">R31</property>
</structure>
<structure>
<property name="columnName">R32</property>
</structure>
<structure>
<property name="columnName">R33</property>
</structure>
<structure>
<property name="columnName">R34</property>
</structure>
<structure>
<property name="columnName">R35</property>
</structure>
<structure>
<property name="columnName">D28</property>
</structure>
<structure>
<property name="columnName">M1</property>
</structure>
<structure>
<property name="columnName">M2</property>
</structure>
<structure>
<property name="columnName">M3</property>
</structure>
<structure>
<property name="columnName">M4</property>
</structure>
<structure>
<property name="columnName">M5</property>
</structure>
<structure>
<property name="columnName">M6</property>
</structure>
<structure>
<property name="columnName">M7</property>
</structure>
<structure>
<property name="columnName">M8</property>
</structure>
<structure>
<property name="columnName">M9</property>
</structure>
<structure>
<property name="columnName">M10</property>
</structure>
<structure>
<property name="columnName">M11</property>
</structure>
<structure>
<property name="columnName">M12</property>
</structure>
<structure>
<property name="columnName">M13</property>
</structure>
<structure>
<property name="columnName">M14</property>
</structure>
<structure>
<property name="columnName">M15</property>
</structure>
<structure>
<property name="columnName">M16</property>
</structure>
<structure>
<property name="columnName">M17</property>
</structure>
<structure>
<property name="columnName">M18</property>
</structure>
<structure>
<property name="columnName">M19</property>
</structure>
<structure>
<property name="columnName">M20</property>
</structure>
<structure>
<property name="columnName">M21</property>
</structure>
<structure>
<property name="columnName">M22</property>
</structure>
<structure>
<property name="columnName">M23</property>
</structure>
<structure>
<property name="columnName">M24</property>
</structure>
<structure>
<property name="columnName">M25</property>
</structure>
<structure>
<property name="columnName">M26</property>
</structure>
<structure>
<property name="columnName">M27</property>
</structure>
<structure>
<property name="columnName">M28</property>
</structure>
<structure>
<property name="columnName">M29</property>
</structure>
<structure>
<property name="columnName">M30</property>
</structure>
<structure>
<property name="columnName">M31</property>
</structure>
<structure>
<property name="columnName">M32</property>
</structure>
<structure>
<property name="columnName">M33</property>
</structure>
<structure>
<property name="columnName">M34</property>
</structure>
<structure>
<property name="columnName">M35</property>
</structure>
<structure>
<property name="columnName">LastCall</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
Re: Landscape orientation for PDF not working in servlet [message #249071 is a reply to message #248425] |
Fri, 20 July 2007 02:20  |
I designed a report and using grid and master page from library.
Still I cannot reproduce the issue, am I missing something?
Please try my report attached. Or try to refresh your reports in latest
build.
If still find this issue, suggest you to submit a bug in bugzilla
https://bugs.eclipse.org/bugs
thanks.
"Nisha" <nagarwal@healthhero.com> wrote in message
news:768af21c407221246086560f5dd449ff$1@www.eclipse.org...
> id="1">
> here>></property>
> <structure>
> </structure>
> </list-property>
> <parameters>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
FUDForum. Page generated in 0.03844 seconds
