| Re: Programmatically rebuilding the configuration folder [message #248197 is a reply to message #247872] |
Tue, 01 June 2004 23:47  |
Originally posted by: dorian.birsan.net
"Martin Klinke" <martin.klinke@xavo.de> wrote in message
news:c9ht75$fr2$1@eclipse.org...
> Sorry, hit the send button too fast...
> So here's the question:
> When launching the eclipse platform the folder configuration is created
> which holds information about the installed plugins and so on. But what if
> you install a new plugin or a new version of an already installed plugin?
Is
> there a way to tell eclipse to rebuild its configuration folder despite of
> deleting it manually?
> Background: I have a plugin that introduces a new view in a new version,
> which isn't found after the update before deleting the configuration
folder.
A new plugin should be detected. What driver are you using?
You may want to touch the plugin directory, so its timestamp is current, and
will be picked up when you launch eclipse.
> TIA for your answers!
> Martin Klinke
FUDForum. Page generated in 0.04810 seconds
