Home » Archived » BIRT » Not able to see Report Designer perspective in BIRT 2.2
Not able to see Report Designer perspective in BIRT 2.2 [message #247788] Fri, 13 July 2007 09:01 Go to next message
I have downloaded the BIRT 2.2 all in one zip file. After unziping .. when
i got to windows > perspective > .. i dont see Report Designer. i have
followed all the steps mentioned in the installation instructions on the
BIRT website.
Please note that i was evaluating Actuate 9 and i had installed iServer,
iPortal and actuate's BIRT report designer....
I have uninstalled all Actuate componets but still i am not able to see
the Report Designer.
The same installable works on other machine.
Is their any conflict with the earlier actuate install. Do i need to
modify any PATH or CLASSPATH or any config folder.
Let me know
Thanks a Lot
Kaustubh
Re: Not able to see Report Designer perspective in BIRT 2.2 [message #247794 is a reply to message #247788] Fri, 13 July 2007 11:14 Go to previous messageGo to next message
Kautsubh,
Did you unzip the allinone in a separate directory?
try launching with a -clean.
Jason
> when i got to windows > perspective > .. i dont see Report Designer. i
> have followed all the steps mentioned in the installation instructions
> on the BIRT website.
> Let me know
> Thanks a Lot
> Kaustubh
Re: Not able to see Report Designer perspective in BIRT 2.2 [message #247820 is a reply to message #247788] Fri, 13 July 2007 11:25 Go to previous message
Originally posted by: rermish.carreker.com
One of my co-workers had this problem and discovered that his system
classpath was pointing to incompatible java libraries. I think 2.2 requires
JRE 1.5. You might look at your system classpath and java home.
"Kautsubh Chaporkar" <kaustubh.chaporkar@s1.com> wrote in message
news:1631046b02821e72ccab1012e068561c$1@www.eclipse.org...
>BIRT website.
> Let me know
> Thanks a Lot
> Kaustubh
Previous Topic:problem to run MySQL Aggregate Functions in birt 2.1.1
Next Topic:Postgres 7.4 connections not closing
Current Time: Fri Mar 14 01:27:51 EDT 2025
Powered by FUDForum. Page generated in 0.03349 seconds
