Home » Language IDEs » Java Development Tools (JDT) » Problem: Class after creation not found in model
| Problem: Class after creation not found in model [message #247739] |
Wed, 12 September 2007 10:12  |
Originally posted by: mail.nicetoeatyou.de
we are working on some Tests for our Plugin.
There we need to build some classes from scratch:
IPackageFragmentRoot packageFragmentRoot = javaProject.getPackageFragmentRoot(javaProject.getResource() );
IPackageFragment packageFragment = packageFragmentRoot.createPackageFragment("de.unikassel.janus.tests.autocompletion ", true, null);
ICompilationUnit compilationUnit = packageFragment.createCompilationUnit("Simple.java",
"class Simple {" +
true, null);
After creation, the .java and .class files are found where expected and with right content,
but if try to find the class via SearchEngine.searchAllTypeNames i dont find it?
What did we miss? And what do we need to do, to get the new created classes into the model?
We experimented with getProject().build(IncrementalProjectBuilder.FULL_BUILD,..
and Platform.getJobManager().join(ResourcesPlugin.FAMILY_MANUAL_ BUILD,...
but no results.
Kind regards,
Dennis Keßler
| Re: Problem: Class after creation not found in model [message #247753 is a reply to message #247739] |
Thu, 13 September 2007 09:27   |
Dennis Keßler wrote:
> Hello,
> true, null);
> "class Simple {" +
> true, null);
> with right content,
> find it?
Could it be that the source of Simple.java doesn't contain a package
declaration ? e.g.
"package de.unikassel.janus.tests.autocompletion;" +
"public class Simple {" +
Also how do you use the SearchEngine ? What waiting policy do you use ?
| Re: Problem: Class after creation not found in model [message #247766 is a reply to message #247753] |
Fri, 14 September 2007 16:13   |
> declaration ? e.g.
i have added the package, but still no results.
Waht iam doing is:
packageFragment = packageFragmentRoot.createPackageFragment("de.unikassel.janus.tests.autocompletion2 ", true, null);
"package de.unikassel.janus.tests.autocompletion2;\n" +
"class Simple {\n" +
true, null);
javaProject.getProject().build(IncrementalProjectBuilder.FUL L_BUILD, null);
Platform.getJobManager().join(ResourcesPlugin.FAMILY_AUTO_BU ILD, null);
Platform.getJobManager().join(ResourcesPlugin.FAMILY_MANUAL_ BUILD, null);
After that i use basicly the SearchEngine like this:
searchEngine.searchAllTypeNames(
packageName.toCharArray(),//final char[] packageName,
SearchPattern.R_PATTERN_MATCH,//final int packageMatchRule,
"Simpl".toCharArray(),
SearchPattern.R_PREFIX_MATCH | SearchPattern.R_CAMELCASE_MATCH,//final int typeMatchRule,
IJavaSearchConstants.TYPE,//int searchFor,
scope,//IJavaSearchScope scope,
typeInfoRequestor,//final TypeNameMatchRequestor nameMatchRequestor,
IJavaSearchConstants.WAIT_UNTIL_READY_TO_SEARCH,//int waitingPolicy,
null//IProgressMonitor progressMonitor
But still no results.
If i try it in the working code, like opening our graphical editor,
rightclick on src folder in Package View, create class Simple and use then
an autocompletion in any of our type-autocompletion-enabled elements,
Simple is found and inserted correctly.
I tried it also with IJavaSearchConstants.FORCE_IMMEDIATE_SEARCH
Kind regards,
Dennis Keßler
| Re: Problem: Class after creation not found in model [message #247783 is a reply to message #247766] |
Tue, 18 September 2007 12:54   |
There must be something else going on with your code. I ran the following test successfully
(ie. it printed "de.unikassel.janus.tests.autocompletion2.Simple" to the console):
IJavaProject javaProject = createJavaProject("P");
IPackageFragmentRoot packageFragmentRoot = getPackageFragmentRoot("/P");
String packageName = "de.unikassel.janus.tests.autocompletion2";
IPackageFragment packageFragment = packageFragmentRoot.createPackageFragment(packageName, true, null);
true, null);
SearchEngine searchEngine = new SearchEngine();
IJavaSearchScope scope = SearchEngine.createWorkspaceScope();
TypeNameMatchRequestor typeInfoRequestor = new TypeNameMatchRequestor(){
public void acceptTypeNameMatch(TypeNameMatch match) {
System.out.println(match.getFullyQualifiedName());
| Re: Problem: Class after creation not found in model [message #247864 is a reply to message #247783] |
Wed, 19 September 2007 10:11   |
I just realized that you forced the project to be built. This is not necessary since the Java indexing
is independent from the Java builder.
So the following code also works for me:
true, null);
| Re: Problem: Class after creation not found in model [message #248503 is a reply to message #248488] |
Tue, 09 October 2007 09:55  |
> back from holidays.
> And good news :-)
> It finaly works, but to say what was all wrong... too many!
> Best Thanks for your help
> Kind regards,
> Dennis Keßler
I'm glad it now works. However it would be good to understand what
went wrong for future reference. Was it a misunderstanding of the API ?
In this case, what wasn't clear ? We might be able to clarify things.
Jerome
Current Time: Mon Nov 03 11:19:32 EST 2025
Powered by FUDForum. Page generated in 0.05716 seconds
