Home » Eclipse Projects » GEF » To print the GEF diagram without viewing in the screen!
To print the GEF diagram without viewing in the screen! [message #247696] Wed, 11 March 2009 13:00 Go to next message
Madhu Samuel is currently offline Madhu SamuelFriend
Hello folks,
Currently the diagram we draw in GEF are drawn in the screen since the
'GC' class is attached with 'Display'. I wanted to paint this generated
diagram in an SWT Device other than 'Display', say 'Printer'.
I wanted to send a GEF diagram to a Printer without painting in the
Display.
Is it possible?
Madhu
Re: To print the GEF diagram without viewing in the screen! [message #247736 is a reply to message #247696] Tue, 17 March 2009 03:08 Go to previous messageGo to next message
Ben Vitale is currently offline Ben VitaleFriend
Have a look at PrintGraphicalViewerOperation. If that's not exactly what
you need, there are a lot of threads already posted about dumping a
viewer to an image, etc.
Madhu Samuel wrote:
> Hello folks,
> Display.
> Is it possible?
> Madhu
Re: To print the GEF diagram without viewing in the screen! [message #247740 is a reply to message #247736] Tue, 17 March 2009 08:07 Go to previous messageGo to next message
Hello Ben,
Both the approaches using PrintGraphicalViewerOperation and viewer to
image conversion need the GEF figures to be available in a graphical
viewer. Isn't it?
I wanted to print it even before opening it in the graphical viewer.
Is it possible?
Madhu
> Madhu Samuel wrote:
>> Hello folks,
>> Display.
>> Is it possible?
>> Regards,
>> Madhu
Re: To print the GEF diagram without viewing in the screen! [message #247750 is a reply to message #247740] Tue, 17 March 2009 16:00 Go to previous messageGo to next message
> Is it possible?
Why? Don't you want to just hand off your model input to the viewer, and
have it build up all the figures for you? You can instantiate the viewer
without it being visible on the screen, if that's your concern.
If you are building the figures manually, then you should still be able
to use PrintFigureOperation (the superclass) or some aspects of it.
Re: To print the GEF diagram without viewing in the screen! [message #247780 is a reply to message #247750] Wed, 18 March 2009 03:22 Go to previous messageGo to next message
Ben Vitale wrote:
>> Is it possible?
Yes, This is exactly what I need! How can I instantiate the viewer without
it being visible on the screen?
Re: To print the GEF diagram without viewing in the screen! [message #247802 is a reply to message #247780] Wed, 18 March 2009 22:16 Go to previous messageGo to next message
Madhu Samuel wrote:
> Ben Vitale wrote:
>>> Is it possible?
>> and have it build up all the figures for you? You can instantiate the
>> viewer without it being visible on the screen, if that's your concern.
> without it being visible on the screen?
>> able to use PrintFigureOperation (the superclass) or some aspects of it.
Check out LogicPrintAction in the logic example.
Re: To print the GEF diagram without viewing in the screen! [message #247812 is a reply to message #247802] Thu, 19 March 2009 05:20 Go to previous message
Thanks Ben. I will check this out!
Ben Vitale wrote:
> Madhu Samuel wrote:
>> Ben Vitale wrote:
>>>> Is it possible?
Previous Topic:eclipse draw2d api
Next Topic:Setting fixed width Figure?
Current Time: Tue Jul 16 10:06:43 GMT 2024
Powered by FUDForum. Page generated in 0.03619 seconds
