possible M9 Issues [message #247667] |
Mon, 31 May 2004 15:47 |
Originally posted by: trond.sausjord.com
I've been checking out M9 for a little while and I like what I see so far,
but found some possible issues.
1) User Library
I added a user library and whenever I do the following eclipse hangs:
Run... -> Classpath -> Advanced -> Add Library -> User Library -> User
Library
Sometimes I get to do 'next' but mostly it just hangs, did this several
times with the same result.
2) System.out
This is a problem also in 2.1.3, but whenever I write large texts to
System.out nothing happens,
calling flush() don't help either. The scenario is typically using JABX to
marshal an XML file to
System.out for debugging purposes. System.err works fine though.
3) Debugging
Whenever a breakpoint is reached I have to manually look for it and click on
it to get the code
into the editor pane. This is a huge inconvenience. Often I run 5-6
programs simulating a distributed
system and have break points in all of them to trace the communication. Not
being visually notified
that a breakpoint has been reached is making debugging large event based
systems very hard
compared to 2.1.3.
FUDForum. Page generated in 0.02524 seconds
