Home » Newcomers » Newcomers » Proxy Settings ... plugincustomization, core.net.prefs
Proxy Settings ... plugincustomization, core.net.prefs [message #247557] Sun, 03 February 2008 17:18 Go to next message
As it is my first post i don't know if i'm really in the good newsgroups
section. Anyway it seems broad enough for my question.
I'm actually packaging a relocatable eclipse/maven/tomcat distro (and it
works pretty fine ;)) thanks to the plugincustomization option of the
eclipse runtime. But I'm still having a problem with the proxy settings.
When I export my preferences I can see the proxy options in my preference
file. But when I launch eclipse with the pluginoptimization option ...
nothing in the proxy preferences window.
I've found out that the proxy properties where actually stored in the
workspace metadata in the
plugins/org.eclipse.core.runtime/.settings/org.eclipse.core. net.prefs
file.
So I tried, as a guess, to put this file in the configuration folder of my
eclipse folder (hope you follow). I tried in configuration/.settings and
in configuration/org.eclipse.net.prefs/.settings ... No results either.
Is there any way I can set proxy settings in eclipse once and for all ? Is
it possible to edit one the eclipse .jar to store the proxy preferences
for good ? Is it possible to copy by default a proxy pref file when a
workspace is created ?
Thanks in advance for any reply
Manu
Re: Proxy Settings ... plugincustomization, core.net.prefs [message #248041 is a reply to message #247557] Wed, 06 February 2008 07:31 Go to previous message
Originally posted by: pouet.pouet.com
Up
Previous Topic:Key binding for "Terminate" outside of Debug Perspective
Next Topic:how to see the command that eclipse executes?
Current Time: Tue Apr 29 01:35:50 EDT 2025
Powered by FUDForum. Page generated in 0.08724 seconds
