BIRT Runtime -Report Engine 2.2 Error [message #247551] |
Thu, 12 July 2007 07:37 |
Originally posted by: hijaysh.gmail.com
I have been using BIRT Runtime 2.1.2 for my web appln and currently
migrating to 2.2.
In my web app, I have included all the jars from
birt-runtime-2_2_0\ReportEngine\lib to my proj library and also used the
latest plugins and configuration folders in my webapp's WEB-INF/platform.
But while running the report from my web app, i get the standard
exception: "Unhandled exception when executing script".
The same report runs in the latest Eclipse (3.3) with BIRT 2_2_0 though!!
Is there any thing else that needs to be configured for 2_2_0 runtime
engine?!
Also, I notice that HTMLRenderContext and PDFRenderContext are deprecated
in the latest(2.2.0) release! Does that imply that there is some other api
by which we can generate HTML and PDF reports using runtime BIRT engine.
Please do let me know.
Thanks in Advance.
Re: BIRT Runtime -Report Engine 2.2 Error [message #247606 is a reply to message #247551] |
Thu, 12 July 2007 13:28 |
Can you post the full report error? Hit the "+" to see the full exception.
RenderContext operations are now in the RenderOptions classes.
Jason
Jayashree wrote:
> Hi
> migrating to 2.2.
> engine?!
> deprecated in the latest(2.2.0) release! Does that imply that there is
> some other api by which we can generate HTML and PDF reports using
> Thanks in Advance.
Re: BIRT Runtime -Report Engine 2.2 Error [message #247743 is a reply to message #247606] |
Fri, 13 July 2007 01:34 |
Hi Jason
PF below the full error.
The following items have errors:
ReportDesign (id = 1):
+ There are errors evaluating script "reportClass = new
Packages.sconce.pdmrep.dal.generics.ScriptCall();
vect = reportClass.getUsers();
totalrows= vect.size() ;
currentrow=0 ;":{1}.
Error.ScriptEvaluationError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
Packages.sconce.pdmrep.dal.generics.ScriptCall();vect =
reportClass.getUsers();totalrows= vect.size() ;currentrow=0 ;":{1}. at
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:77)
org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:159)
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:6 6)
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:79)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:244)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :220)
org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:761)
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:216)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:152)
org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:83)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:155)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:115)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:178)
org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1678)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:82)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:61)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 5)
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:42)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:33)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:126)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:84)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:90)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:148)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:71)
pdmreport.reportGeneration.ReportGeneration.generateReportBu tton_action(ReportGeneration.java:1421)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
at java.lang.reflect.Method.invoke(Method.java:585) at
com.sun.faces.el.MethodBindingImpl.invoke(MethodBindingImpl. java:146) at
com.sun.faces.application.ActionListenerImpl.processAction(A ctionListenerImpl.java:92)
com.sun.rave.web.ui.appbase.faces.ActionListenerImpl.process Action(ActionListenerImpl.java:57)
at javax.faces.component.UICommand.broadcast(UICommand.java:332 ) at
javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot. java:287) at
javax.faces.component.UIViewRoot.processApplication(UIViewRo ot.java:401)
com.sun.faces.lifecycle.InvokeApplicationPhase.execute(Invok eApplicationPhase.java:95)
at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.ja va:245) at
com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl. java:110) at
javax.faces.webapp.FacesServlet.service(FacesServlet.java:21 3) at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
at com.sun.rave.web.ui.util.UploadFilter.doFilter(UploadFilter. java:198)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:202)
at pdmreport.SessionCheckFilter.doFilter(SessionCheckFilter.jav a:45) at
org.netbeans.modules.web.monitor.server.MonitorFilter.doFilt er(MonitorFilter.java:368)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:869)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:664)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:80)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)Caused by:
org.eclipse.birt.data.engine.core.DataException: A BIRT exception
occurred: Error evaluating Javascript expression. Script engine error:
TypeError: [JavaPackage sconce.pdmrep.dal.generics.ScriptCall] is not a
function. (DataSet[Data Set].__bm_OPEN#2) Script source: DataSet[Data
Set].__bm_OPEN, line: 1, text:__bm_OPEN(). See next exception for more
information.Error evaluating Javascript expression. Script engine error:
Set].__bm_OPEN, line: 1, text:__bm_OPEN() at
org.eclipse.birt.data.engine.core.DataException.wrap(DataExc eption.java:118)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:582)
org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:79)
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:71)
... 62 moreCaused by: org.eclipse.birt.core.exception.CoreException: Error
evaluating Javascript expression. Script engine error: TypeError:
[JavaPackage sconce.pdmrep.dal.generics.ScriptCall] is not a function.
org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoExc eption(JavascriptEvalUtil.java:281)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:105)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:137)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:578)
... 64 moreCaused by: org.mozilla.javascript.EcmaError: TypeError:
(DataSet[Data Set].__bm_OPEN#2) at
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
org.mozilla.javascript.ScriptRuntime.typeError1(ScriptRuntim e.java:3258)
org.mozilla.javascript.ScriptRuntime.notFunctionError(Script Runtime.java:3317)
org.mozilla.javascript.ScriptRuntime.notFunctionError(Script Runtime.java:3308)
at org.mozilla.javascript.ScriptRuntime.newObject(ScriptRuntime .java:2057)
at org.mozilla.javascript.gen.c6._c1(DataSet[Data Set].__bm_OPEN:2) at
org.mozilla.javascript.gen.c6.call(DataSet[Data Set].__bm_OPEN) at
org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:105)
at org.mozilla.javascript.gen.c7._c0(DataSet[Data Set].__bm_OPEN:1) at
org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_OPEN) at
org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_OPEN) at
org.mozilla.javascript.gen.c7.exec(DataSet[Data Set].__bm_OPEN) at
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:98)
... 66 more
+ There are errors evaluating script "if (totalrows>currentrow)
var obj = vect.get(currentrow);
var name = obj[0];
var email = obj[1];
var telephone = obj[2];
var org = obj[3];
var fax = obj[4];
var web = obj[5];
var add = obj[6];
row["Name"]=name;
row["Email"]=email;
row["Phone"]=telephone;
row["Organization"]=org;
row["Fax"]=fax;
row["Address"]=add;
row["Website"]=web;
currentrow=currentrow+1;
return ( true );
return ( false );":{1}.
errors evaluating script "if (totalrows>currentrow){ var obj =
vect.get(currentrow); var name = obj[0]; var email = obj[1]; var
telephone = obj[2]; var org = obj[3]; var fax = obj[4]; var web = obj[5];
var add = obj[6]; row["Name"]=name; row["Email"]=email;
row["Phone"]=telephone; row["Organization"]=org; row["Fax"]=fax;
row["Address"]=add; row["Website"]=web; currentrow=currentrow+1; return
( true );} return ( false );":{1}. at
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 100)
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch (ScriptDataSetRuntime.java:102)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery. java:257)
org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:150)
org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:91)
org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next(ExpandableRowResultSet.java:62)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .populateData(SmartCacheHelper.java:268)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initInstance(SmartCacheHelper.java:241)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .getResultSetCache(SmartCacheHelper.java:204)
org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.java:68)
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.populateOdiResultSet(PassUtil.java:113)
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.pass(PassUtil.java:66)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.doSinglePass(PassManager.java:185)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.pass(PassManager.java:90)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSet(PassManager.java:72)
org.eclipse.birt.data.engine.executor.transform.ResultSetPop ulator.populateResultSet(ResultSetPopulator.java:208)
org.eclipse.birt.data.engine.executor.transform.CachedResult Set. <init>(CachedResultSet.java:132)
org.eclipse.birt.data.engine.executor.CandidateQuery.execute (CandidateQuery.java:106)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :223)
ReferenceError: "totalrows" is not defined. (DataSet[Data
Set].__bm_FETCH#2) Script source: DataSet[Data Set].__bm_FETCH, line: 1,
text:__bm_FETCH(). See next exception for more information.Error
evaluating Javascript expression. Script engine error: ReferenceError:
"totalrows" is not defined. (DataSet[Data Set].__bm_FETCH#2) Script
source: DataSet[Data Set].__bm_FETCH, line: 1, text:__bm_FETCH() at
... 77 moreCaused by: org.eclipse.birt.core.exception.CoreException: Error
... 79 moreCaused by: org.mozilla.javascript.EcmaError: ReferenceError:
"totalrows" is not defined. (DataSet[Data Set].__bm_FETCH#2) at
org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRun time.java:3303)
org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu ntime.java:1632)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1571) at
org.mozilla.javascript.gen.c8._c1(DataSet[Data Set].__bm_FETCH:2) at
org.mozilla.javascript.gen.c8.call(DataSet[Data Set].__bm_FETCH) at
at org.mozilla.javascript.gen.c9._c0(DataSet[Data Set].__bm_FETCH:1) at
org.mozilla.javascript.gen.c9.call(DataSet[Data Set].__bm_FETCH) at
at org.mozilla.javascript.gen.c9.call(DataSet[Data Set].__bm_FETCH) at
org.mozilla.javascript.gen.c9.exec(DataSet[Data Set].__bm_FETCH) at
... 81 more
- Unhandled exception when executing script
Error.UnhandledScriptError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Unhandled
exception when executing script at
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:141)
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:131)
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 119)
data.engine.BadFetchScriptReturnType at
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 109)
... 75 more
Re: BIRT Runtime -Report Engine 2.2 Error [message #247771 is a reply to message #247606] |
Fri, 13 July 2007 07:53 |
Hi Jason,
The exception shows a reference error for 'totalrows' a variable that i
have used in the script.
Actual Exception:
vect = reportClass.getSample();
totalrows= vect.size();
reportClass.getSample();totalrows= vect.size();currentrow=0 ;":{1}. at
at test.Page1.button1_action(Page1.java:272) at
... 59 moreCaused by: org.eclipse.birt.core.exception.CoreException: Error
... 61 moreCaused by: org.mozilla.javascript.EcmaError: TypeError:
at org.mozilla.javascript.gen.c4._c1(DataSet[Data Set].__bm_OPEN:2) at
org.mozilla.javascript.gen.c4.call(DataSet[Data Set].__bm_OPEN) at
at org.mozilla.javascript.gen.c5._c0(DataSet[Data Set].__bm_OPEN:1) at
org.mozilla.javascript.gen.c5.call(DataSet[Data Set].__bm_OPEN) at
at org.mozilla.javascript.gen.c5.call(DataSet[Data Set].__bm_OPEN) at
org.mozilla.javascript.gen.c5.exec(DataSet[Data Set].__bm_OPEN) at
... 63 more
- There are errors evaluating script "if (totalrows>currentrow)
var one = obj[0];
var two = obj[1];
row["one"]=one;
row["two"]=two;
return ( true );
vect.get(currentrow); var one = obj[0]; var two = obj[1];
row["one"]=one; row["two"]=two; currentrow=currentrow+1; return ( true
... 74 moreCaused by: org.eclipse.birt.core.exception.CoreException: Error
... 76 moreCaused by: org.mozilla.javascript.EcmaError: ReferenceError:
org.mozilla.javascript.gen.c6._c1(DataSet[Data Set].__bm_FETCH:2) at
org.mozilla.javascript.gen.c6.call(DataSet[Data Set].__bm_FETCH) at
at org.mozilla.javascript.gen.c7._c0(DataSet[Data Set].__bm_FETCH:1) at
org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_FETCH) at
at org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_FETCH) at
org.mozilla.javascript.gen.c7.exec(DataSet[Data Set].__bm_FETCH) at
... 78 more
... 72 more
Re: BIRT Runtime -Report Engine 2.2 Error [message #247792 is a reply to message #247771] |
Fri, 13 July 2007 14:45 |
Jayashree,
Where is this class located sconce.pdmrep.dal.generics.ScriptCall?
Also can you post your scripts for the open and fetch methods?
Jason
Jayashree wrote:
> Hi Jason,
> Actual Exception:
> ReportDesign (id = 1): + There are errors evaluating script "reportClass
> = new Packages.sconce.pdmrep.dal.generics.ScriptCall();
> currentrow=0 ;":{1}. Error.ScriptEvaluationError ( 1 time(s) )
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl. java:110)
> at javax.faces.webapp.FacesServlet.service(FacesServlet.java:21 3) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Error evaluating Javascript expression. Script engine error: TypeError:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 63 more
> var one = obj[0];
> var two = obj[1];
> row["one"]=one;
> row["two"]=two;
> return ( true );
> return ( false );":{1}. Error.ScriptEvaluationError ( 1 time(s) )
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 78 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 72 more
Re: BIRT Runtime -Report Engine 2.2 Error [message #247917 is a reply to message #247792] |
Sat, 14 July 2007 02:22 |
Hi Jason,
The open and fetch scripts are present in the exception too.
open:
reportClass = new Packages.sconce.pdmrep.dal.generics.ScriptCall();
currentrow=0 ;
fetch:
var one = obj[0];
var two = obj[1];
row["one"]=one;
row["two"]=two;
return ( true );
Method:
public static Vector getSample(){
Vector vec = new Vector();
String[]a=new String[]{"1","2"};
vec.add(a);
return vec;
rptdesign:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build <2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company Name
here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<script-data-source name="Data Source" id="6"/>
</data-sources>
<data-sets>
<script-data-set name="Data Set" id="7">
<list-property name="resultSetHints">
<structure>
<property name="position">0</property>
<property name="name">one</property>
<property name="dataType">any</property>
</structure>
<structure>
<property name="position">1</property>
<property name="name">two</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">one</property>
</structure>
<structure>
<property name="columnName">two</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
<property name="position">2</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<method name="open"><![CDATA[reportClass = new
currentrow=0 ;]]></method>
<method name="fetch"><![CDATA[if (totalrows>currentrow)
var one = obj[0];
var two = obj[1];
row["one"]=one;
row["two"]=two;
return ( true );
return ( false );]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="8">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["one"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["two"]</expression>
</structure>
</list-property>
<column id="21"/>
<column id="22"/>
<header>
<row id="9">
<cell id="10">
<label id="24">
<text-property name="text">one</text-property>
</label>
</cell>
<cell id="11">
<label id="26">
<text-property name="text">two</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="13">
<cell id="14">
<data id="25">
<property name="resultSetColumn">one</property>
</data>
</cell>
<cell id="15">
<data id="27">
<property name="resultSetColumn">two</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="17">
<cell id="18"/>
<cell id="19"/>
</row>
</footer>
</table>
</body>
</report>
==>It is just a simple method that i had written just to test 2_2_0 Report
Engine in my web app.It can actually be present in any class.
==>Scriptcall class is present in a jar, in my web-app's WEB-INF/lib folder.
Even in 2.1.2 Report Engine, it was present in the same location and it worked
fine. For 2.2, I also tried placing it in <webappln>/scriptlib/<name>.jar but
it still didnt work.
==> Initially it gave a Reference Error : org.mozilla.javascript.EcmaError:
But I used the code in 'open' script again in 'fetch' to define vect,
totalrows and currentrow , and the error was fixed.
Re: BIRT Runtime -Report Engine 2.2 Error [message #247982 is a reply to message #247792] |
Mon, 16 July 2007 07:18 |
Hi Jason,
I was able to resolve the error by using the code below which i noticed
from an earlier post about similar exception.
runAndRenderTask.getAppContext().put(EngineConstants.APPCONT EXT_CLASSLOADER_KEY,
ReportEngineService.class.getClassLoader());
Aneways,thanks for your help :)!
Jayashree
FUDForum. Page generated in 0.03759 seconds
