Home » Archived » BIRT » IncompatibleClassChangeError with 2.2.0
IncompatibleClassChangeError with 2.2.0 [message #247542] Thu, 12 July 2007 02:55 Go to next message
I migrated my system to 2.2.0. To generate the reports I'm using the BIRT
Runtime.
My first test ends with an exception:
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error
happened while running the report
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:178)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:71)
de.guidecom.birt.reporting.impl.BIRTRunAndRenderTaskImpl.run AndRenderTask(BIRTRunAndRenderTaskImpl.java:133)
de.guidecom.kgiplus3.web.handler.impl.AbstractHandlerImpl.cr eateReport(AbstractHandlerImpl.java:463)
... 28 more
Caused by: java.lang.IncompatibleClassChangeError
org.eclipse.birt.report.engine.css.engine.CSSEngine.parsePro pertyValue(CSSEngine.java:114)
org.eclipse.birt.report.engine.css.dom.AbstractStyle.setCssT ext(AbstractStyle.java:193)
org.eclipse.birt.report.engine.parser.EngineIRVisitor.addRep ortDefaultPropertyValue(EngineIRVisitor.java:2310)
org.eclipse.birt.report.engine.parser.EngineIRVisitor.addRep ortDefaultPropertyValue(EngineIRVisitor.java:2276)
org.eclipse.birt.report.engine.parser.EngineIRVisitor.create ReportDefaultStyles(EngineIRVisitor.java:2329)
org.eclipse.birt.report.engine.parser.EngineIRVisitor.visitR eportDesign(EngineIRVisitor.java:266)
org.eclipse.birt.report.model.api.DesignVisitor$Forwarder.vi sitReportDesign(DesignVisitor.java:1175)
org.eclipse.birt.report.model.elements.ReportDesign.apply(Re portDesign.java:89)
org.eclipse.birt.report.model.api.DesignVisitor.apply(Design Visitor.java:123)
org.eclipse.birt.report.engine.parser.EngineIRVisitor.transl ate(EngineIRVisitor.java:237)
org.eclipse.birt.report.engine.parser.ReportParser.parse(Rep ortParser.java:177)
org.eclipse.birt.report.engine.api.impl.ReportRunnable.getRe portIR(ReportRunnable.java:199)
org.eclipse.birt.report.engine.executor.ExecutionContext.get Report(ExecutionContext.java:694)
org.eclipse.birt.report.engine.executor.ReportExecutor.(Repo rtExecutor.java:78)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:96)
In CSSEngine.java classes from sac are used. But I don't why such an
exception occures.
Can anyone help me?
Daniel
Re: IncompatibleClassChangeError with 2.2.0 [message #247611 is a reply to message #247542] Thu, 12 July 2007 09:30 Go to previous messageGo to next message
Daniel,
Are you using the REAPI to run your reports or the WebViewer? Can you
post your code?
Jason
Daniel Hakenjos wrote:
> Hello,
> BIRT Runtime.
> at
> at
> at
> at
> ... 28 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> exception occures.
> Can anyone help me?
> Thanks
> Daniel
Re: IncompatibleClassChangeError with 2.2.0 [message #248051 is a reply to message #247542] Mon, 16 July 2007 06:55 Go to previous messageGo to next message
Originally posted by: aysonway.gmail.com
I have the same error running report through php-java bridge.
#-11
#-10
#-9 sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
The same report runs without error with birt-runtime-2_2M6.
Re: IncompatibleClassChangeError with 2.2.0 [message #248056 is a reply to message #248051] Mon, 16 July 2007 06:59 Go to previous messageGo to next message
Here is php-java-bridge.log:
16.07.2007 12:58:28 org.eclipse.birt.report.model.metadata.ExtensionLoader
handleError
SCHWERWIEGEND: Message:The element type "BIRT_ROM" is invalid. Error
code:INVALID_ELEMENT_TYPE
16.07.2007 12:58:29 org.eclipse.birt.data.engine.impl.DataEngineImpl <init>
INFO: Data Engine starts up
16.07.2007 12:58:29
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask doRun
SCHWERWIEGEND: Error happened while running the report.
java.lang.NoSuchMethodError:
org.eclipse.birt.report.model.api.ComputedColumnHandle.argum entsIterator()Ljava/util/Iterator;
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$Q ueryBuilderVisitor.addColumBinding(ReportQueryBuilder.java:8 48)
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$Q ueryBuilderVisitor.createQuery(ReportQueryBuilder.java:986)
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$Q ueryBuilderVisitor.visitTableItem(ReportQueryBuilder.java:60 9)
org.eclipse.birt.report.engine.ir.TableItemDesign.accept(Tab leItemDesign.java:44)
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.b uild(ReportQueryBuilder.java:246)
org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.b uild(ReportQueryBuilder.java:228)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.p repare(AbstractDataEngine.java:135)
org.eclipse.birt.report.engine.executor.ReportExecutor.execu te(ReportExecutor.java:94)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportExecutor.execute(WrappedReportExecutor.java:59)
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplciateReportExecutor.execute(SuppressDuplciateReportExec utor.java:50)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:146)
at php.java.bridge.JavaBridge.Invoke(JavaBridge.java:1124)
at php.java.bridge.Request.handleRequest(Request.java:342)
at php.java.bridge.Request.handleRequests(Request.java:388)
at php.java.bridge.JavaBridge.run(JavaBridge.java:215)
at php.java.bridge.BaseThreadPool$Delegate.run(BaseThreadPool.j ava:66)
Jul 16 12:58:29 JavaBridge ERROR: An exception occured:
org.eclipse.birt.report.engine.api.EngineException: Error happened while
running the report
running the report
Caused by: java.lang.NoSuchMethodError:
... 10 more
Re: IncompatibleClassChangeError with 2.2.0 [message #248090 is a reply to message #248056] Mon, 16 July 2007 10:20 Go to previous messageGo to next message
Sam,
Did you update all the jars and plugins in the Bridge? The code
developed for the php bridge has not been upgrated to 2.2 yet.
Jason
> 16.07.2007 12:58:28
> org.eclipse.birt.report.model.metadata.ExtensionLoader handleError
> code:INVALID_ELEMENT_TYPE 16.07.2007 12:58:29
> 16.07.2007 12:58:29
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> running the report
> running the report
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 10 more
Re: IncompatibleClassChangeError with 2.2.0 [message #248093 is a reply to message #248090] Mon, 16 July 2007 10:32 Go to previous messageGo to next message
Ups, I forgot it. Now it works. Thank you!
Re: IncompatibleClassChangeError with 2.2.0 [message #249085 is a reply to message #247611] Fri, 20 July 2007 02:35 Go to previous messageGo to next message
I'm using thr birt-runtime-2_2_0 to render my reports in PDF.
To access the Runtime I'm using the REAPI.
For every BIRT I deploy the jar-Files in
birt-runtime-2_2_0\ReportEngine\lib
into my Maven-Repository. So I have no idea why the class should be
incompatible!
Daniel
Re: IncompatibleClassChangeError with 2.2.0 [message #249091 is a reply to message #247611] Fri, 20 July 2007 02:39 Go to previous messageGo to next message
Here is my code:
IRunAndRenderTask renderTask =
getReportEngine().createRunAndRenderTask(getReportRunnable() );
RenderOption renderOption=renderData.getRenderOption();
if (renderOption==null){
renderOption=getRenderOption();
boolean embeddable=(renderOption instanceof HTMLRenderOption) &&
((HTMLRenderOption) renderOption).getEmbeddable();
Map<Object,Object> appContext=renderTask.getAppContext();
if (appContext==null){
appContext=new HashMap<Object,Object>();
if (renderData.addScriptObjectsToTask()){
appContext.putAll(renderData.getScriptObjectMap());
renderTask.setAppContext(appContext);
// Set rendering options - such as file or stream output,
// output format, whether it is embeddable, etc
File tempFile=File.createTempFile("report","output");
FileOutputStream stream = new FileOutputStream(tempFile);
if (embeddable){
renderData.onBeforeRender(stream);
renderOption.setOutputStream(stream);
renderTask.setRenderOption(renderOption);
if (renderData.getParameterMap()!=null){
renderTask.setParameterValues(renderData.getParameterMap());
renderTask.run();
renderTask.close();
stream.close();
if (embeddable){
stream = new FileOutputStream(tempFile,true);
renderData.onAfterRender(stream);
stream.close();
Re: IncompatibleClassChangeError with 2.2.0 [message #249094 is a reply to message #249091] Fri, 20 July 2007 03:35 Go to previous message
Now I removed org.w3s.css.sac from the dependencies and I got no error!
That's it!?
Daniel
Previous Topic:Landscape orientation for PDF not working in servlet
Next Topic:simple Date display question
Current Time: Thu Apr 24 00:19:02 EDT 2025
Powered by FUDForum. Page generated in 0.02304 seconds
