Home » Archived » BIRT » Error in reading rptdesign files from v2.1
Error in reading rptdesign files from v2.1 [message #247496] Thu, 12 July 2007 00:59 Go to next message
Donald A. Lobo is currently offline Donald A. LoboFriend
I've downloaded Eclipse 3.3 and BIRT 2.2 and managed to get it working
after a bit of a struggle. Might help to let people who use the download
new install feature of Eclipse that its missing a dependency that you
need to download separately on the front page of BIRT / Wiki etc
( http://dev.eclipse.org/newslists/news.eclipse.birt/msg21107. html)
Onto my next problem :)
1. I can create a new report and it works fine
2. I try importing a 2.1 rptdesign file and I get the below exception.
Do i need to do anything special to upgrade a 2.1 file?
thanx for any and all help. We'd like to ship CiviCRM v1.8
(http://civicrm.org) with BIRT 2.2 / Eclipse 3.3 support and so this is
kinda important :)
thanx
lobo
org.eclipse.birt.report.designer.ui.editors.MultiPageReportE ditor.addPages(MultiPageReportEditor.java:222)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:146)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
org.eclipse.birt.report.designer.ui.editors.ReportEditorProx y.createPartControl(ReportEditorProxy.java:121)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2721)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2539)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1090)
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:105)
org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:75)
Re: Error in reading rptdesign files from v2.1 [message #247524 is a reply to message #247496] Thu, 12 July 2007 06:13 Go to previous messageGo to next message
Wang Qiangsheng is currently offline Wang QiangshengFriend
Member
> kinda important :)
> thanx
> lobo
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
could you attach the design file?
Qs
Re: Error in reading rptdesign files from v2.1 [message #247536 is a reply to message #247524] Thu, 12 July 2007 06:17 Go to previous messageGo to next message
--------------020204070402050008000307
Content-Type: text/plain; charset=ISO-8859-1
atrached is the design file from 2.1 which croaks in 2.2. Am attaching 2
design files, both of them result in the same null error
lobo
Content-Type: text/xml; x-mac-type="0"; x-mac-creator="0";
name="contactReport.rptdesign"
Content-Disposition: inline;
filename="contactReport.rptdesign"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPCEtLSBX cml0dGVuIGJ5
IEVjbGlwc2UgQklSVCAyLjAgLS0+DQo8cmVwb3J0IHhtbG5zPSJodHRwOi8v d3d3LmVjbGlw
c2Uub3JnL2JpcnQvMjAwNS9kZXNpZ24iIHZlcnNpb249IjMuMi42IiBpZD0i MSI+CiAgICA8
cHJvcGVydHkgbmFtZT0iY3JlYXRlZEJ5Ij5FY2xpcHNlIEJJUlQgRGVzaWdu ZXIgVmVyc2lv
biAyLjEuMC5OMjAwNjA2MjgtMTM1MSBCdWlsZCAmbHQ7MjAwNjA2MjgtMTUz Nz48L3Byb3Bl
cnR5PgogICAgPHByb3BlcnR5IG5hbWU9InVuaXRzIj5pbjwvcHJvcGVydHk+ CiAgICA8cHJv
cGVydHkgbmFtZT0iY29tbWVudHMiPkNvcHlyaWdodCAoYykgMjAwNiAmbHQ7 Jmx0O1lvdXIg
Q29tcGFueSBOYW1lIGhlcmU+PjwvcHJvcGVydHk+CiAgICA8cGFyYW1ldGVy cz4KICAgICAg
ICA8cGFyYW1ldGVyLWdyb3VwIG5hbWU9ImNvbnRhY3RHcm91cCIgaWQ9IjEy NyI+CiAgICAg
ICAgICAgIDx0ZXh0LXByb3BlcnR5IG5hbWU9ImRpc3BsYXlOYW1lIj5QYXJh bWV0ZXIgZ3Jv
dXAgZm9yIGNvbnRhY3QgVHlwZSBhbmQgR3JvdXAgbmFtZTwvdGV4dC1wcm9w ZXJ0eT4KICAg
ICAgICAgICAgPHBhcmFtZXRlcnM+CiAgICAgICAgICAgICAgICA8c2NhbGFy LXBhcmFtZXRl
ciBuYW1lPSJSUF9jb250YWN0VHlwZSIgaWQ9IjEyOCI+CiAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9InZhbHVlVHlwZSI+c3RhdGljPC9wcm9wZXJ0eT4K ICAgICAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPnN0cmluZzwv cHJvcGVydHk+
CiAgICAgICAgICAgICAgICAgICAgPHRleHQtcHJvcGVydHkgbmFtZT0icHJv bXB0VGV4dCI+
RW50ZXIgQ29udGFjdCBUeXBlPC90ZXh0LXByb3BlcnR5PgogICAgICAgICAg ICAgICAgICAg
IDxwcm9wZXJ0eSBuYW1lPSJhbGxvd051bGwiPmZhbHNlPC9wcm9wZXJ0eT4K ICAgICAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iY29udHJvbFR5cGUiPmxpc3Qt Ym94PC9wcm9w
ZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibXVz dE1hdGNoIj50
cnVlPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkg bmFtZT0iZGVm
YXVsdFZhbHVlIj5JbmRpdmlkdWFsPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICA8
c3RydWN0dXJlIG5hbWU9ImZvcm1hdCI+CiAgICAgICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJjYXRlZ29yeSI+VW5mb3JtYXR0ZWQ8L3Byb3BlcnR5Pgog ICAgICAgICAg
ICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxs aXN0LXByb3Bl
cnR5IG5hbWU9InNlbGVjdGlvbkxpc3QiPgogICAgICAgICAgICAgICAgICAg ICAgICA8c3Ry
dWN0dXJlPgogICAgICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5 IG5hbWU9InZh
bHVlIj5JbmRpdmlkdWFsPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAg ICAgICAgICAg
IDxwcm9wZXJ0eSBuYW1lPSJsYWJlbCI+SW5kaXZpZHVhbDwvcHJvcGVydHk+ CiAgICAgICAg
ICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAg ICAgICAgICA8
c3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgICAgICAgICAgPHByb3Bl cnR5IG5hbWU9
InZhbHVlIj5Ib3VzZWhvbGQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgPHByb3BlcnR5IG5hbWU9ImxhYmVsIj5Ib3VzZWhvbGQ8L3Byb3BlcnR5 PgogICAgICAg
ICAgICAgICAgICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAg ICAgICAgICAg
PHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9w ZXJ0eSBuYW1l
PSJ2YWx1ZSI+T3JnYW5pemF0aW9uPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJsYWJlbCI+T3JnYW5pemF0aW9uPC9w cm9wZXJ0eT4K
ICAgICAgICAgICAgICAgICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAg ICAgICAgICAg
ICAgPC9saXN0LXByb3BlcnR5PgogICAgICAgICAgICAgICAgPC9zY2FsYXIt cGFyYW1ldGVy
PgogICAgICAgICAgICAgICAgPHNjYWxhci1wYXJhbWV0ZXIgbmFtZT0iUlBf Z3JvdXAiIGlk
PSIxMjkiPgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJ2 YWx1ZVR5cGUi
PmR5bmFtaWM8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9w ZXJ0eSBuYW1l
PSJkYXRhVHlwZSI+aW50ZWdlcjwvcHJvcGVydHk+CiAgICAgICAgICAgICAg ICAgICAgPHRl
eHQtcHJvcGVydHkgbmFtZT0icHJvbXB0VGV4dCI+U2VsZWN0IGEgR3JvdXA8 L3RleHQtcHJv
cGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImFs bG93TnVsbCI+
ZmFsc2U8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0 eSBuYW1lPSJj
b250cm9sVHlwZSI+bGlzdC1ib3g8L3Byb3BlcnR5PgogICAgICAgICAgICAg ICAgICAgIDxw
cm9wZXJ0eSBuYW1lPSJkYXRhU2V0TmFtZSI+RFNfZ3JvdXBJZDwvcHJvcGVy dHk+CiAgICAg
ICAgICAgICAgICAgICAgPGV4cHJlc3Npb24gbmFtZT0idmFsdWVFeHByIj5k YXRhU2V0Um93
WyJpZCJdPC9leHByZXNzaW9uPgogICAgICAgICAgICAgICAgICAgIDxleHBy ZXNzaW9uIG5h
bWU9ImxhYmVsRXhwciI+ZGF0YVNldFJvd1sibmFtZSJdPC9leHByZXNzaW9u PgogICAgICAg
ICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJtdXN0TWF0Y2giPnRydWU8 L3Byb3BlcnR5
PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJmaXhlZE9y ZGVyIj5mYWxz
ZTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5h bWU9ImRlZmF1
bHRWYWx1ZSI+MjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHN0 cnVjdHVyZSBu
YW1lPSJmb3JtYXQiPgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
Y2F0ZWdvcnkiPlVuZm9ybWF0dGVkPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICA8
L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgIDwvc2NhbGFyLXBhcmFtZXRl cj4KICAgICAg
ICAgICAgPC9wYXJhbWV0ZXJzPgogICAgICAgIDwvcGFyYW1ldGVyLWdyb3Vw PgogICAgPC9w
YXJhbWV0ZXJzPgogICAgPGRhdGEtc291cmNlcz4KICAgICAgICA8b2RhLWRh dGEtc291cmNl
IGV4dGVuc2lvbklEPSJvcmcuZWNsaXBzZS5iaXJ0LnJlcG9ydC5kYXRhLm9k YS5qZGJjIiBu
YW1lPSJjaXZpY3JtIiBpZD0iNCI+CiAgICAgICAgICAgIDx0ZXh0LXByb3Bl cnR5IG5hbWU9
ImRpc3BsYXlOYW1lIj5jaXZpY3JtPC90ZXh0LXByb3BlcnR5PgogICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0ib2RhRHJpdmVyQ2xhc3MiPmNvbS5teXNxbC5qZGJjLkRy aXZlcjwvcHJv
cGVydHk+CiAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJvZGFVUkwiPmpk YmM6bXlzcWw6
Ly9sb2NhbGhvc3QvY2l2aWNybTwvcHJvcGVydHk+CiAgICAgICAgICAgIDxw cm9wZXJ0eSBu
YW1lPSJvZGFVc2VyIj5jaXZpY3JtPC9wcm9wZXJ0eT4KICAgICAgICAgICAg PGVuY3J5cHRl
ZC1wcm9wZXJ0eSBuYW1lPSJvZGFQYXNzd29yZCI+WTJsMmFXTnliUT09PC9l bmNyeXB0ZWQt
cHJvcGVydHk+CiAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJvZGFKbmRp TmFtZSI+amRi
YzpteXNxbDovL2xvY2FsaG9zdC9jaXZpY3JtPC9wcm9wZXJ0eT4KICAgICAg ICA8L29kYS1k
YXRhLXNvdXJjZT4KICAgIDwvZGF0YS1zb3VyY2VzPgogICAgPGRhdGEtc2V0 cz4KICAgICAg
ICA8b2RhLWRhdGEtc2V0IGV4dGVuc2lvbklEPSJvcmcuZWNsaXBzZS5iaXJ0 LnJlcG9ydC5k
YXRhLm9kYS5qZGJjLkpkYmNTZWxlY3REYXRhU2V0IiBuYW1lPSJjb250YWN0 RGF0YXNldCIg
aWQ9IjUiPgogICAgICAgICAgICA8dGV4dC1wcm9wZXJ0eSBuYW1lPSJkaXNw bGF5TmFtZSI+
Y29udGFjdERhdGFzZXQ8L3RleHQtcHJvcGVydHk+CiAgICAgICAgICAgIDxz dHJ1Y3R1cmUg
bmFtZT0iY2FjaGVkTWV0YURhdGEiPgogICAgICAgICAgICAgICAgPGxpc3Qt cHJvcGVydHkg
bmFtZT0icmVzdWx0U2V0Ij4KICAgICAgICAgICAgICAgICAgICA8c3RydWN0 dXJlPgogICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24i PjE8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i bmFtZSI+Y29u
dGFjdF9pZDwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxw cm9wZXJ0eSBu
YW1lPSJkYXRhVHlwZSI+aW50ZWdlcjwvcHJvcGVydHk+CiAgICAgICAgICAg ICAgICAgICAg
PC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgPHN0cnVjdHVyZT4K ICAgICAgICAg
ICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj4yPC9w cm9wZXJ0eT4K
ICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hbWUi PmNvbnRhY3Rf
dHlwZTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9w ZXJ0eSBuYW1l
PSJkYXRhVHlwZSI+c3RyaW5nPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICA8L3N0
cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8c3RydWN0dXJlPgogICAg ICAgICAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24iPjM8L3Byb3Bl cnR5PgogICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+Y29u dGFjdF9zdWJf
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24iPjQ8L3Byb3Bl cnR5PgogICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+c29y dF9uYW1lPC9w
cm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5h bWU9ImRhdGFU
eXBlIj5zdHJpbmc8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDwv c3RydWN0dXJl
PgogICAgICAgICAgICAgICAgICAgIDxzdHJ1Y3R1cmU+CiAgICAgICAgICAg ICAgICAgICAg
ICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlvbiI+NTwvcHJvcGVydHk+CiAg ICAgICAgICAg
ICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYW1lIj5kaXNwbGF5X25h bWU8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i ZGF0YVR5cGUi
PnN0cmluZzwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPC9zdHJ1 Y3R1cmU+CiAg
ICAgICAgICAgICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj42PC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hbWUiPmJpcnRoX2RhdGU8L3By b3BlcnR5Pgog
ICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5 cGUiPmRhdGUt
dGltZTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPC9zdHJ1Y3R1 cmU+CiAgICAg
ICAgICAgICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAg ICAgICAgPHBy
b3BlcnR5IG5hbWU9InBvc2l0aW9uIj43PC9wcm9wZXJ0eT4KICAgICAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9Im5hbWUiPmdlbmRlcl9pZDwvcHJvcGVy dHk+CiAgICAg
ICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+ aW50ZWdlcjwv
cHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAg ICAgICAgICAg
ICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICAgICAg PHByb3BlcnR5
IG5hbWU9InBvc2l0aW9uIj44PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9Im5hbWUiPmdlbmRlcjwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+c3RyaW5nPC9w cm9wZXJ0eT4K
ICAgICAgICAgICAgICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAg ICAgICAgICA8
c3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkg bmFtZT0icG9z
aXRpb24iPjk8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8 cHJvcGVydHkg
bmFtZT0ibmFtZSI+bG9jYXRpb25faWQ8L3Byb3BlcnR5PgogICAgICAgICAg ICAgICAgICAg
ICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPmludGVnZXI8L3Byb3Bl cnR5PgogICAg
ICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAg ICAgIDxzdHJ1
Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1l PSJwb3NpdGlv
biI+MTA8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0ibmFtZSI+YWRkcmVzc19pZDwvcHJvcGVydHk+CiAgICAgICAgICAgICAg ICAgICAgICAg
IDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+aW50ZWdlcjwvcHJvcGVydHk+ CiAgICAgICAg
ICAgICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAg PHN0cnVjdHVy
ZT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBv c2l0aW9uIj4x
MTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0 eSBuYW1lPSJu
YW1lIj5zdHJlZXRfYWRkcmVzczwvcHJvcGVydHk+CiAgICAgICAgICAgICAg ICAgICAgICAg
IDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+c3RyaW5nPC9wcm9wZXJ0eT4K ICAgICAgICAg
ICAgICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8 c3RydWN0dXJl
PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9z aXRpb24iPjEy
PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5 IG5hbWU9Im5h
bWUiPnN1cHBsZW1lbnRhbF9hZGRyZXNzXzE8L3Byb3BlcnR5PgogICAgICAg ICAgICAgICAg
ICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPnN0cmluZzwvcHJv cGVydHk+CiAg
ICAgICAgICAgICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgICAg ICAgICAgPHN0
cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5h bWU9InBvc2l0
aW9uIj4xMzwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxw cm9wZXJ0eSBu
YW1lPSJuYW1lIj5zdXBwbGVtZW50YWxfYWRkcmVzc18yPC9wcm9wZXJ0eT4K ICAgICAgICAg
ICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5zdHJp bmc8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAg ICAgICAgICAg
ICAgIDxzdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9w ZXJ0eSBuYW1l
PSJwb3NpdGlvbiI+MTQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0ibmFtZSI+Y2l0eTwvcHJvcGVydHk+CiAgICAgICAgICAg ICAgICAgICAg
ICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+c3RyaW5nPC9wcm9wZXJ0 eT4KICAgICAg
ICAgICAgICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAg ICA8c3RydWN0
dXJlPgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i cG9zaXRpb24i
PjE1PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3Bl cnR5IG5hbWU9
Im5hbWUiPnBvc3RhbF9jb2RlX3N1ZmZpeDwvcHJvcGVydHk+CiAgICAgICAg ICAgICAgICAg
ICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+c3RyaW5nPC9wcm9w ZXJ0eT4KICAg
ICAgICAgICAgICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAg ICAgICA8c3Ry
dWN0dXJlPgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFt ZT0icG9zaXRp
b24iPjE2PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICAgICAgPHBy b3BlcnR5IG5h
bWU9Im5hbWUiPnBvc3RhbF9jb2RlPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICAg
ICAgPHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5zdHJpbmc8L3Byb3BlcnR5 PgogICAgICAg
ICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAg IDxzdHJ1Y3R1
cmU+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJw b3NpdGlvbiI+
MTc8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
bmFtZSI+Z2VvX2NvZGVfMTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAg ICAgICAgIDxw
cm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+ZmxvYXQ8L3Byb3BlcnR5PgogICAg ICAgICAgICAg
ICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxzdHJ1 Y3R1cmU+CiAg
ICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlv biI+MTg8L3By
b3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFt ZT0ibmFtZSI+
Z2VvX2NvZGVfMjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBuYW1lPSJkYXRhVHlwZSI+ZmxvYXQ8L3Byb3BlcnR5PgogICAgICAgICAg ICAgICAgICAg
IDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxzdHJ1Y3R1cmU+ CiAgICAgICAg
ICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlvbiI+MTk8 L3Byb3BlcnR5
PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFt ZSI+c3RhdGVf
cHJvdmluY2VfaWQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAg ICA8cHJvcGVy
dHkgbmFtZT0iZGF0YVR5cGUiPmludGVnZXI8L3Byb3BlcnR5PgogICAgICAg ICAgICAgICAg
ICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxzdHJ1Y3R1 cmU+CiAgICAg
ICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlvbiI+ MjA8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i bmFtZSI+c3Rh
dGVfcHJvdmluY2U8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAg ICA8cHJvcGVy
dHkgbmFtZT0iZGF0YVR5cGUiPnN0cmluZzwvcHJvcGVydHk+CiAgICAgICAg ICAgICAgICAg
ICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgPHN0cnVjdHVy ZT4KICAgICAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj4y MTwvcHJvcGVy
dHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJu YW1lIj5zdGF0
ZV9wcm92aW5jZV9uYW1lPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAg ICAgICAgPHBy
b3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5zdHJpbmc8L3Byb3BlcnR5PgogICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlv biI+MjI8L3By
Y291bnRyeV9pZDwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBuYW1lPSJkYXRhVHlwZSI+aW50ZWdlcjwvcHJvcGVydHk+CiAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj4y MzwvcHJvcGVy
dHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJu YW1lIj5jb3Vu
dHJ5PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3Bl cnR5IG5hbWU9
ImRhdGFUeXBlIj5zdHJpbmc8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgIDwvc3Ry
dWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxzdHJ1Y3R1cmU+CiAgICAg ICAgICAgICAg
ICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlvbiI+MjQ8L3Byb3Bl cnR5PgogICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+cGhv bmVfaWQ8L3By
b3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFt ZT0iZGF0YVR5
cGUiPmludGVnZXI8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDwv c3RydWN0dXJl
ICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlvbiI+MjU8L3Byb3BlcnR5Pgog ICAgICAgICAg
ICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+cGhvbmVfdHlw ZTwvcHJvcGVy
dHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJk YXRhVHlwZSI+
c3RyaW5nPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8L3N0cnVj dHVyZT4KICAg
ICAgICAgICAgICAgICAgICA8c3RydWN0dXJlPgogICAgICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0icG9zaXRpb24iPjI2PC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hbWUiPnBob25lPC9wcm9wZXJ0 eT4KICAgICAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5z dHJpbmc8L3By
b3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAg ICAgICAgICAg
ICAgICAgIDxzdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgICAgIDxw cm9wZXJ0eSBu
YW1lPSJwb3NpdGlvbiI+Mjc8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0ibmFtZSI+ZW1haWxfaWQ8L3Byb3BlcnR5PgogICAg ICAgICAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPmludGVnZXI8 L3Byb3BlcnR5
PgogICAgICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAg ICAgICAgICAg
IDxzdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0 eSBuYW1lPSJw
b3NpdGlvbiI+Mjg8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAg ICA8cHJvcGVy
dHkgbmFtZT0ibmFtZSI+ZW1haWw8L3Byb3BlcnR5PgogICAgICAgICAgICAg ICAgICAgICAg
ICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPnN0cmluZzwvcHJvcGVydHk+ CiAgICAgICAg
ZT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBv c2l0aW9uIj4y
OTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0 eSBuYW1lPSJu
YW1lIj5vbl9ob2xkPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICAg ICAgPHByb3Bl
cnR5IG5hbWU9ImRhdGFUeXBlIj5pbnRlZ2VyPC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8c3RydWN0 dXJlPgogICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24i PjMwPC9wcm9w
ZXJ0eT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9 Im5hbWUiPmxl
Z2FsX2lkZW50aWZpZXI8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0iZGF0YVR5cGUiPnN0cmluZzwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgPHN0cnVj dHVyZT4KICAg
ICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9u Ij4zMTwvcHJv
cGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1l PSJuYW1lIj5l
eHRlcm5hbF9pZGVudGlmaWVyPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5zdHJpbmc8L3Byb3BlcnR5Pgog ICAgICAgICAg
ICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxz dHJ1Y3R1cmU+
CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3Np dGlvbiI+MzI8
L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkg bmFtZT0ibmFt
ZSI+aG9tZV9VUkw8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAg ICA8cHJvcGVy
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj4z MzwvcHJvcGVy
dHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJu YW1lIj5wcmVm
ZXJyZWRfbWFpbF9mb3JtYXQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPnN0cmluZzwvcHJvcGVydHk+CiAg ICAgICAgICAg
ICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgPHN0 cnVjdHVyZT4K
ICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0 aW9uIj4zNDwv
cHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBu YW1lPSJuYW1l
Ij5ncm91cF9jb250YWN0X2lkPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5pbnRlZ2VyPC9wcm9wZXJ0eT4K ICAgICAgICAg
PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9z aXRpb24iPjM1
bWUiPnN0YXR1czwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBuYW1lPSJkYXRhVHlwZSI+c3RyaW5nPC9wcm9wZXJ0eT4KICAgICAgICAg ICAgICAgICAg
ICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgIDwvbGlzdC1wcm9wZXJ0 eT4KICAgICAg
ICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1l PSJkYXRhU291
cmNlIj5jaXZpY3JtPC9wcm9wZXJ0eT4KICAgICAgICAgICAgPGxpc3QtcHJv cGVydHkgbmFt
ZT0icGFyYW1ldGVycyI+CiAgICAgICAgICAgICAgICA8c3RydWN0dXJlPgog ICAgICAgICAg
ICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYW1lIj5EU1BfZ3JvdXA8L3By b3BlcnR5Pgog
ICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVOYW1l Ij5ncnBOYW1l
PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFt ZT0iZGF0YVR5
cGUiPnN0cmluZzwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHBy b3BlcnR5IG5h
bWU9Im5hdGl2ZURhdGFUeXBlIj4xMjwvcHJvcGVydHk+CiAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj4xPC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICA8ZXhwcmVzc2lvbiBuYW1lPSJkZWZhdWx0VmFsdWUiPnBhcmFtc1si UlBfZ3JvdXAi
XTwvZXhwcmVzc2lvbj4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkg bmFtZT0iaXNP
cHRpb25hbCI+ZmFsc2U8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBuYW1lPSJpc0lucHV0Ij50cnVlPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0iaXNPdXRwdXQiPmZhbHNlPC9wcm9wZXJ0eT4KICAg ICAgICAgICAg
ICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgPHN0cnVjdHVyZT4K ICAgICAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+RFNQX2NvbnRhY3RU eXBlPC9wcm9w
ZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmF0 aXZlTmFtZSI+
dHlwZTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5 IG5hbWU9ImRh
dGFUeXBlIj5zdHJpbmc8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBuYW1lPSJuYXRpdmVEYXRhVHlwZSI+MTI8L3Byb3BlcnR5PgogICAgICAg ICAgICAgICAg
ICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlvbiI+MjwvcHJvcGVydHk+CiAg ICAgICAgICAg
ICAgICAgICAgPGV4cHJlc3Npb24gbmFtZT0iZGVmYXVsdFZhbHVlIj5wYXJh bXNbIlJQX2Nv
bnRhY3RUeXBlIl08L2V4cHJlc3Npb24+CiAgICAgICAgICAgICAgICAgICAg PHByb3BlcnR5
IG5hbWU9ImlzT3B0aW9uYWwiPmZhbHNlPC9wcm9wZXJ0eT4KICAgICAgICAg ICAgICAgICAg
ICA8cHJvcGVydHkgbmFtZT0iaXNJbnB1dCI+dHJ1ZTwvcHJvcGVydHk+CiAg ICAgICAgICAg
ICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImlzT3V0cHV0Ij5mYWxzZTwvcHJv cGVydHk+CiAg
ICAgICAgICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgPC9saXN0 LXByb3BlcnR5
PgogICAgICAgICAgICA8bGlzdC1wcm9wZXJ0eSBuYW1lPSJyZXN1bHRTZXQi PgogICAgICAg
ICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0icG9zaXRpb24iPjE8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBuYW1lPSJuYW1lIj5jb250YWN0X2lkPC9wcm9wZXJ0eT4KICAgICAgICAg ICAgICAgICAg
ICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlTmFtZSI+Y29udGFjdF9pZDwvcHJv cGVydHk+CiAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5p bnRlZ2VyPC9w
cm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i bmF0aXZlRGF0
YVR5cGUiPjQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgPC9zdHJ1Y3R1 cmU+CiAgICAg
ICAgICAgICAgICA8c3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxw cm9wZXJ0eSBu
YW1lPSJwb3NpdGlvbiI+MjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAg ICAgPHByb3Bl
cnR5IG5hbWU9Im5hbWUiPmNvbnRhY3RfdHlwZTwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPmNvbnRhY3RfdHlw ZTwvcHJvcGVy
dHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImRhdGFU eXBlIj5zdHJp
bmc8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBu YW1lPSJuYXRp
dmVEYXRhVHlwZSI+MTI8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgPC9z dHJ1Y3R1cmU+
CiAgICAgICAgICAgICAgICA8c3RydWN0dXJlPgogICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJwb3NpdGlvbiI+MzwvcHJvcGVydHk+CiAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9Im5hbWUiPmNvbnRhY3Rfc3ViX3R5cGU8L3Byb3Bl cnR5PgogICAg
ICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVOYW1lIj5j b250YWN0X3N1
Yl90eXBlPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
ZGF0YVR5cGUiPnN0cmluZzwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAg ICAgPHByb3Bl
cnR5IG5hbWU9Im5hdGl2ZURhdGFUeXBlIj4xMjwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgIDxzdHJ1Y3R1cmU+CiAg ICAgICAgICAg
ICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj40PC9wcm9wZXJ0 eT4KICAgICAg
ICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+c29ydF9uYW1l PC9wcm9wZXJ0
eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZl TmFtZSI+c29y
dF9uYW1lPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
ICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj41PC9wcm9wZXJ0 eT4KICAgICAg
ICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+ZGlzcGxheV9u YW1lPC9wcm9w
ZGlzcGxheV9uYW1lPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8 cHJvcGVydHkg
bmFtZT0iZGF0YVR5cGUiPnN0cmluZzwvcHJvcGVydHk+CiAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9Im5hdGl2ZURhdGFUeXBlIj4xMjwvcHJvcGVydHk+ CiAgICAgICAg
ICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgIDxzdHJ1Y3R1 cmU+CiAgICAg
ICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj42PC9w cm9wZXJ0eT4K
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+Ymly dGhfZGF0ZTwv
cHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9 Im5hdGl2ZU5h
bWUiPmJpcnRoX2RhdGU8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBuYW1lPSJkYXRhVHlwZSI+ZGF0ZS10aW1lPC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlRGF0YVR5cGUiPjkxPC9wcm9w ZXJ0eT4KICAg
ICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgPHN0 cnVjdHVyZT4K
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24i Pjc8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYW1l Ij5nZW5kZXJf
aWQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBu YW1lPSJuYXRp
dmVOYW1lIj5nZW5kZXJfaWQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJkYXRhVHlwZSI+aW50ZWdlcjwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZURhdGFUeXBlIj40PC9wcm9w ZXJ0eT4KICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24i Pjg8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYW1l Ij5nZW5kZXI8
L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1l PSJuYXRpdmVO
YW1lIj5nZW5kZXI8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxw cm9wZXJ0eSBu
YW1lPSJkYXRhVHlwZSI+c3RyaW5nPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0ibmF0aXZlRGF0YVR5cGUiPjEyPC9wcm9wZXJ0eT4K ICAgICAgICAg
ICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAgPHN0cnVjdHVy ZT4KICAgICAg
ICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24iPjk8L3By b3BlcnR5Pgog
ICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYW1lIj5sb2Nh dGlvbl9pZDwv
bWUiPmxvY2F0aW9uX2lkPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAg ICA8cHJvcGVy
ICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVEYXRhVHlwZSI+NDwvcHJvcGVy dHk+CiAgICAg
ICAgICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgIDxzdHJ1 Y3R1cmU+CiAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj4x MDwvcHJvcGVy
dHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hbWUi PmFkZHJlc3Nf
dmVOYW1lIj5hZGRyZXNzX2lkPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0iZGF0YVR5cGUiPmludGVnZXI8L3Byb3BlcnR5PgogICAg ICAgICAgICAg
ICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVEYXRhVHlwZSI+NDwvcHJv cGVydHk+CiAg
ICAgICAgICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgIDxz dHJ1Y3R1cmU+
CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9u Ij4xMTwvcHJv
cGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5h bWUiPnN0cmVl
dF9hZGRyZXNzPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0ibmF0aXZlTmFtZSI+c3RyZWV0X2FkZHJlc3M8L3Byb3BlcnR5PgogICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlRGF0YVR5 cGUiPjEyPC9w
cm9wZXJ0eT4KICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAg ICAgICAgICAg
PHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFt ZT0icG9zaXRp
b24iPjEyPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
bmFtZSI+c3VwcGxlbWVudGFsX2FkZHJlc3NfMTwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPnN1cHBsZW1lbnRh bF9hZGRyZXNz
XzE8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBu YW1lPSJkYXRh
VHlwZSI+c3RyaW5nPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8 cHJvcGVydHkg
bmFtZT0ibmF0aXZlRGF0YVR5cGUiPjEyPC9wcm9wZXJ0eT4KICAgICAgICAg ICAgICAgIDwv
c3RydWN0dXJlPgogICAgICAgICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAg ICAgICAgICAg
ICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24iPjEzPC9wcm9wZXJ0eT4K ICAgICAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+c3VwcGxlbWVudGFs X2FkZHJlc3Nf
MjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5h bWU9Im5hdGl2
ZU5hbWUiPnN1cHBsZW1lbnRhbF9hZGRyZXNzXzI8L3Byb3BlcnR5PgogICAg ICAgICAgICAg
b24iPjE0PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
bmFtZSI+Y2l0eTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHBy b3BlcnR5IG5h
bWU9Im5hdGl2ZU5hbWUiPmNpdHk8L3Byb3BlcnR5PgogICAgICAgICAgICAg ICAgICAgIDxw
cm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+c3RyaW5nPC9wcm9wZXJ0eT4KICAg ICAgICAgICAg
ICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlRGF0YVR5cGUiPjEyPC9w cm9wZXJ0eT4K
ICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAgICAg PHN0cnVjdHVy
ZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRp b24iPjE1PC9w
cm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i bmFtZSI+cG9z
dGFsX2NvZGVfc3VmZml4PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAg ICA8cHJvcGVy
dHkgbmFtZT0ibmF0aXZlTmFtZSI+cG9zdGFsX2NvZGVfc3VmZml4PC9wcm9w ZXJ0eT4KICAg
ICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPnN0 cmluZzwvcHJv
cGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5h dGl2ZURhdGFU
eXBlIj4xMjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICA8L3N0cnVjdHVy ZT4KICAgICAg
ICAgICAgICAgIDxzdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgPHBy b3BlcnR5IG5h
bWU9InBvc2l0aW9uIj4xNjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAg ICAgPHByb3Bl
cnR5IG5hbWU9Im5hbWUiPnBvc3RhbF9jb2RlPC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlTmFtZSI+cG9zdGFsX2NvZGU8 L3Byb3BlcnR5
PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlw ZSI+c3RyaW5n
PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFt ZT0ibmF0aXZl
RGF0YVR5cGUiPjEyPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgIDwvc3Ry dWN0dXJlPgog
ICAgICAgICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAg ICA8cHJvcGVy
dHkgbmFtZT0icG9zaXRpb24iPjE3PC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0ibmFtZSI+Z2VvX2NvZGVfMTwvcHJvcGVydHk+CiAg ICAgICAgICAg
ICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPmdlb19jb2Rl XzE8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRh VHlwZSI+Zmxv
YXQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBu YW1lPSJuYXRp
dmVEYXRhVHlwZSI+ODwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICA8L3N0 cnVjdHVyZT4K
ICAgICAgICAgICAgICAgIDxzdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAg ICAgPHByb3Bl
cnR5IG5hbWU9InBvc2l0aW9uIj4xODwvcHJvcGVydHk+CiAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9Im5hbWUiPmdlb19jb2RlXzI8L3Byb3BlcnR5Pgog ICAgICAgICAg
ICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVOYW1lIj5nZW9fY29k ZV8yPC9wcm9w
ZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0 YVR5cGUiPmZs
b2F0PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkg bmFtZT0ibmF0
aXZlRGF0YVR5cGUiPjg8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgPC9z dHJ1Y3R1cmU+
ZXJ0eSBuYW1lPSJwb3NpdGlvbiI+MTk8L3Byb3BlcnR5PgogICAgICAgICAg ICAgICAgICAg
IDxwcm9wZXJ0eSBuYW1lPSJuYW1lIj5zdGF0ZV9wcm92aW5jZV9pZDwvcHJv cGVydHk+CiAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUi PnN0YXRlX3By
b3ZpbmNlX2lkPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0iZGF0YVR5cGUiPmludGVnZXI8L3Byb3BlcnR5PgogICAgICAgICAgICAg ICAgICAgIDxw
cm9wZXJ0eSBuYW1lPSJuYXRpdmVEYXRhVHlwZSI+NDwvcHJvcGVydHk+CiAg ICAgICAgICAg
ICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgIDxzdHJ1Y3R1cmU+ CiAgICAgICAg
ICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj4yMDwvcHJv cGVydHk+CiAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hbWUiPnN0YXRl X3Byb3ZpbmNl
TmFtZSI+c3RhdGVfcHJvdmluY2U8L3Byb3BlcnR5PgogICAgICAgICAgICAg ICAgICAgIDxw
ZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRp b24iPjIxPC9w
cm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i bmFtZSI+c3Rh
dGVfcHJvdmluY2VfbmFtZTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAg ICAgPHByb3Bl
cnR5IG5hbWU9Im5hdGl2ZU5hbWUiPnN0YXRlX3Byb3ZpbmNlX25hbWU8L3By b3BlcnR5Pgog
ICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+ c3RyaW5nPC9w
YVR5cGUiPjEyPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgIDwvc3RydWN0 dXJlPgogICAg
ICAgICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8 cHJvcGVydHkg
bmFtZT0icG9zaXRpb24iPjIyPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0ibmFtZSI+Y291bnRyeV9pZDwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPmNvdW50cnlfaWQ8 L3Byb3BlcnR5
PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlw ZSI+aW50ZWdl
cjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5h bWU9Im5hdGl2
ZURhdGFUeXBlIj40PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgIDwvc3Ry dWN0dXJlPgog
dHkgbmFtZT0icG9zaXRpb24iPjIzPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0ibmFtZSI+Y291bnRyeTwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPmNvdW50cnk8L3By b3BlcnR5Pgog
bmFtZT0icG9zaXRpb24iPjI0PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0ibmFtZSI+cGhvbmVfaWQ8L3Byb3BlcnR5PgogICAgICAg ICAgICAgICAg
ICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVOYW1lIj5waG9uZV9pZDwvcHJv cGVydHk+CiAg
YW1lPSJwb3NpdGlvbiI+MjU8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJuYW1lIj5waG9uZV90eXBlPC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlTmFtZSI+cGhvbmVfdHlwZTwv cHJvcGVydHk+
CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImRhdGFUeXBl Ij5zdHJpbmc8
L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1l PSJuYXRpdmVE
YXRhVHlwZSI+MTI8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgPC9zdHJ1 Y3R1cmU+CiAg
ICAgICAgICAgICAgICA8c3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAg IDxwcm9wZXJ0
eSBuYW1lPSJwb3NpdGlvbiI+MjY8L3Byb3BlcnR5PgogICAgICAgICAgICAg ICAgICAgIDxw
cm9wZXJ0eSBuYW1lPSJuYW1lIj5waG9uZTwvcHJvcGVydHk+CiAgICAgICAg ICAgICAgICAg
ICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPnBob25lPC9wcm9wZXJ0 eT4KICAgICAg
ICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPnN0cmlu ZzwvcHJvcGVy
dHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2 ZURhdGFUeXBl
Ij4xMjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICA8L3N0cnVjdHVyZT4K ICAgICAgICAg
ICAgICAgIDxzdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICAgICAgPHByb3Bl cnR5IG5hbWU9
InBvc2l0aW9uIj4yNzwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAg PHByb3BlcnR5
IG5hbWU9Im5hbWUiPmVtYWlsX2lkPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0ibmF0aXZlTmFtZSI+ZW1haWxfaWQ8L3Byb3BlcnR5 PgogICAgICAg
ICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+aW50ZWdl cjwvcHJvcGVy
Ij40PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgog ICAgICAgICAg
ICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
cG9zaXRpb24iPjI4PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8 cHJvcGVydHkg
bmFtZT0ibmFtZSI+ZW1haWw8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJuYXRpdmVOYW1lIj5lbWFpbDwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5zdHJpbmc8L3Byb3Bl cnR5PgogICAg
ICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVEYXRhVHlw ZSI+MTI8L3By
b3BlcnR5PgogICAgICAgICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAg ICAgICAgICA8
c3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1l PSJwb3NpdGlv
biI+Mjk8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0 eSBuYW1lPSJu
YW1lIj5vbl9ob2xkPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8 cHJvcGVydHkg
bmFtZT0ibmF0aXZlTmFtZSI+b25faG9sZDwvcHJvcGVydHk+CiAgICAgICAg ICAgICAgICAg
ICAgPHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5pbnRlZ2VyPC9wcm9wZXJ0 eT4KICAgICAg
ICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlRGF0YVR5cGUi Pi02PC9wcm9w
ZXJ0eT4KICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAg ICAgICAgPHN0
cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i cG9zaXRpb24i
PjMwPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkg bmFtZT0ibmFt
ZSI+bGVnYWxfaWRlbnRpZmllcjwvcHJvcGVydHk+CiAgICAgICAgICAgICAg ICAgICAgPHBy
b3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPmxlZ2FsX2lkZW50aWZpZXI8L3By b3BlcnR5Pgog
bmFtZT0icG9zaXRpb24iPjMxPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0ibmFtZSI+ZXh0ZXJuYWxfaWRlbnRpZmllcjwvcHJvcGVy dHk+CiAgICAg
ICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPmV4 dGVybmFsX2lk
ZW50aWZpZXI8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9w ZXJ0eSBuYW1l
PSJkYXRhVHlwZSI+c3RyaW5nPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0ibmF0aXZlRGF0YVR5cGUiPjEyPC9wcm9wZXJ0eT4KICAg ICAgICAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icG9zaXRpb24iPjMyPC9wcm9w ZXJ0eT4KICAg
ICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+aG9tZV9V Ukw8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRp dmVOYW1lIj5o
b21lX1VSTDwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3Bl cnR5IG5hbWU9
ImRhdGFUeXBlIj5zdHJpbmc8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJuYXRpdmVEYXRhVHlwZSI+MTI8L3Byb3BlcnR5PgogICAg ICAgICAgICAg
ICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICA8c3RydWN0dXJlPgog ICAgICAgICAg
ICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlvbiI+MzM8L3Byb3Bl cnR5PgogICAg
ICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYW1lIj5wcmVmZXJy ZWRfbWFpbF9m
b3JtYXQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0 eSBuYW1lPSJu
YXRpdmVOYW1lIj5wcmVmZXJyZWRfbWFpbF9mb3JtYXQ8L3Byb3BlcnR5Pgog ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlRGF0 YVR5cGUiPjEy
PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAg ICAgICAgICAg
ICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkg bmFtZT0icG9z
aXRpb24iPjM0PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0ibmFtZSI+Z3JvdXBfY29udGFjdF9pZDwvcHJvcGVydHk+CiAgICAgICAg ICAgICAgICAg
ICAgPHByb3BlcnR5IG5hbWU9Im5hdGl2ZU5hbWUiPmdyb3VwX2NvbnRhY3Rf aWQ8L3Byb3Bl
cnR5PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRh VHlwZSI+aW50
ZWdlcjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5 IG5hbWU9Im5h
dGl2ZURhdGFUeXBlIj40PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgIDwv c3RydWN0dXJl
PgogICAgICAgICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAg ICAgICA8cHJv
cGVydHkgbmFtZT0icG9zaXRpb24iPjM1PC9wcm9wZXJ0eT4KICAgICAgICAg ICAgICAgICAg
ICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+c3RhdHVzPC9wcm9wZXJ0eT4KICAg ICAgICAgICAg
ICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmF0aXZlTmFtZSI+c3RhdHVzPC9w cm9wZXJ0eT4K
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUi PnN0cmluZzwv
cHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9 Im5hdGl2ZURh
dGFUeXBlIj4xMjwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICA8L3N0cnVj dHVyZT4KICAg
ICAgICAgICAgPC9saXN0LXByb3BlcnR5PgogICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
cXVlcnlUZXh0Ij5TRUxFQ1QgIERJU1RJTkNUKGNvbnRhY3RfYS5pZCkgYXMg Y29udGFjdF9p
ZCwKICAgICAgICBjb250YWN0X2EuY29udGFjdF90eXBlIGFzIGNvbnRhY3Rf dHlwZSwKICAg
ICAgICBjb250YWN0X2EuY29udGFjdF9zdWJfdHlwZSAgYXMgYGNvbnRhY3Rf c3ViX3R5cGVg
LAogICAgICAgIGNvbnRhY3RfYS5zb3J0X25hbWUgYXMgYHNvcnRfbmFtZWAs CiAgICAgICAg
Y29udGFjdF9hLmRpc3BsYXlfbmFtZSBhcyBkaXNwbGF5X25hbWUsCiAgICAg ICAgY2l2aWNy
bV9pbmRpdmlkdWFsLmJpcnRoX2RhdGUgYXMgYGJpcnRoX2RhdGVgLAogICAg ICAgIGdlbmRl
ci52YWx1ZSBhcyBnZW5kZXJfaWQsCiAgICAgICAgZ2VuZGVyLmxhYmVsIGFz IGdlbmRlciwK
ICAgICAgICBjaXZpY3JtX2xvY2F0aW9uLmlkIGFzIGxvY2F0aW9uX2lkLAog ICAgICAgIGNp
dmljcm1fYWRkcmVzcy5pZCBhcyBhZGRyZXNzX2lkLAogICAgICAgIGNpdmlj cm1fYWRkcmVz
cy5zdHJlZXRfYWRkcmVzcyBhcyBgc3RyZWV0X2FkZHJlc3NgLAogICAgICAg IGNpdmljcm1f
YWRkcmVzcy5zdXBwbGVtZW50YWxfYWRkcmVzc18xIGFzIGBzdXBwbGVtZW50 YWxfYWRkcmVz
c18xYCwKICAgICAgICBjaXZpY3JtX2FkZHJlc3Muc3VwcGxlbWVudGFsX2Fk ZHJlc3NfMiBh
cyBgc3VwcGxlbWVudGFsX2FkZHJlc3NfMmAsCiAgICAgICAgY2l2aWNybV9h ZGRyZXNzLmNp
dHkgYXMgYGNpdHlgLAogICAgICAgIGNpdmljcm1fYWRkcmVzcy5wb3N0YWxf Y29kZV9zdWZm
aXggYXMgYHBvc3RhbF9jb2RlX3N1ZmZpeGAsCiAgICAgICAgY2l2aWNybV9h ZGRyZXNzLnBv
c3RhbF9jb2RlIGFzIGBwb3N0YWxfY29kZWAsCiAgICAgICAgY2l2aWNybV9h ZGRyZXNzLmdl
b19jb2RlXzEgYXMgYGdlb19jb2RlXzFgLAogICAgICAgIGNpdmljcm1fYWRk cmVzcy5nZW9f
Y29kZV8yIGFzIGBnZW9fY29kZV8yYCwKICAgICAgICBjaXZpY3JtX3N0YXRl X3Byb3ZpbmNl
LmlkIGFzIHN0YXRlX3Byb3ZpbmNlX2lkLAogICAgICAgIGNpdmljcm1fc3Rh dGVfcHJvdmlu
Y2UuYWJicmV2aWF0aW9uIGFzIGBzdGF0ZV9wcm92aW5jZWAsCiAgICAgICAg Y2l2aWNybV9z
dGF0ZV9wcm92aW5jZS5uYW1lIGFzIHN0YXRlX3Byb3ZpbmNlX25hbWUsCiAg ICAgICAgY2l2
aWNybV9jb3VudHJ5LmlkIGFzIGNvdW50cnlfaWQsCiAgICAgICAgY2l2aWNy bV9jb3VudHJ5
Lm5hbWUgYXMgYGNvdW50cnlgLAogICAgICAgIGNpdmljcm1fcGhvbmUuaWQg YXMgcGhvbmVf
aWQsCiAgICAgICAgY2l2aWNybV9waG9uZS5waG9uZV90eXBlIGFzIHBob25l X3R5cGUsCiAg
ICAgICAgY2l2aWNybV9waG9uZS5waG9uZSBhcyBgcGhvbmVgLAogICAgICAg IGNpdmljcm1f
ZW1haWwuaWQgYXMgZW1haWxfaWQsCiAgICAgICAgY2l2aWNybV9lbWFpbC5l bWFpbCBhcyBg
ZW1haWxgLCAKICAgICAgICBjaXZpY3JtX2VtYWlsLm9uX2hvbGQgYXMgYG9u X2hvbGRgLAog
ICAgICAgIGNvbnRhY3RfYS5sZWdhbF9pZGVudGlmaWVyICBhcyBgbGVnYWxf aWRlbnRpZmll
cmAsCiAgICAgICAgY29udGFjdF9hLmV4dGVybmFsX2lkZW50aWZpZXIgIGFz IGBleHRlcm5h
bF9pZGVudGlmaWVyYCwKICAgICAgICBjb250YWN0X2EuaG9tZV9VUkwgIGFz IGBob21lX1VS
TGAsCiAgICAgICAgY29udGFjdF9hLnByZWZlcnJlZF9tYWlsX2Zvcm1hdCAg YXMgYHByZWZl
cnJlZF9tYWlsX2Zvcm1hdGAsCiAgICAgICAgYGNpdmljcm1fZ3JvdXBfY29u dGFjdC0zYC5p
ZCBhcyBncm91cF9jb250YWN0X2lkLAogICAgICAgIGBjaXZpY3JtX2dyb3Vw X2NvbnRhY3Qt
M2Auc3RhdHVzIGFzIHN0YXR1cyAKRlJPTSBjaXZpY3JtX2NvbnRhY3QgY29u dGFjdF9hCiAg
ICAgICAgTEVGVCBKT0lOIGNpdmljcm1faW5kaXZpZHVhbCBPTiAoY29udGFj dF9hLmlkID0g
Y2l2aWNybV9pbmRpdmlkdWFsLmNvbnRhY3RfaWQpIAogICAgICAgIExFRlQg Sk9JTiBjaXZp
Y3JtX2xvY2F0aW9uIE9OIChjaXZpY3JtX2xvY2F0aW9uLmVudGl0eV90YWJs ZSA9ICdjaXZp
Y3JtX2NvbnRhY3QnIEFORAogICAgICAgICAgICAgICAgICBjb250YWN0X2Eu aWQgPSBjaXZp
Y3JtX2xvY2F0aW9uLmVudGl0eV9pZCBBTkQKICAgICAgICAgICAgICAgICAg Y2l2aWNybV9s
b2NhdGlvbi5pc19wcmltYXJ5ID0gMSkKICAgICAgICBMRUZUIEpPSU4gY2l2 aWNybV9hZGRy
ZXNzIE9OIGNpdmljcm1fbG9jYXRpb24uaWQgPSBjaXZpY3JtX2FkZHJlc3Mu bG9jYXRpb25f
aWQgCiAgICAgICAgTEVGVCBKT0lOIGNpdmljcm1fc3RhdGVfcHJvdmluY2Ug T04gY2l2aWNy
bV9hZGRyZXNzLnN0YXRlX3Byb3ZpbmNlX2lkID0gY2l2aWNybV9zdGF0ZV9w cm92aW5jZS5p
ZCAKICAgICAgICBMRUZUIEpPSU4gY2l2aWNybV9jb3VudHJ5IE9OIGNpdmlj cm1fYWRkcmVz
cy5jb3VudHJ5X2lkID0gY2l2aWNybV9jb3VudHJ5LmlkIAogICAgICAgIExF RlQgSk9JTiBj
aXZpY3JtX2VtYWlsIE9OIChjaXZpY3JtX2xvY2F0aW9uLmlkID0gY2l2aWNy bV9lbWFpbC5s
b2NhdGlvbl9pZCBBTkQgY2l2aWNybV9lbWFpbC5pc19wcmltYXJ5ID0gMSkg CiAgICAgICAg
TEVGVCBKT0lOIGNpdmljcm1fcGhvbmUgT04gKGNpdmljcm1fbG9jYXRpb24u aWQgPSBjaXZp
Y3JtX3Bob25lLmxvY2F0aW9uX2lkIEFORCBjaXZpY3JtX3Bob25lLmlzX3By aW1hcnkgPSAx
KSAKICAgICAgICBMRUZUIEpPSU4gY2l2aWNybV9pbSBPTiAoY2l2aWNybV9s b2NhdGlvbi5p
ZCA9IGNpdmljcm1faW0ubG9jYXRpb25faWQgQU5EIGNpdmljcm1faW0uaXNf cHJpbWFyeSA9
IDEpICAKICAgICAgICBMRUZUIEpPSU4gY2l2aWNybV9ncm91cF9jb250YWN0 IGBjaXZpY3Jt
X2dyb3VwX2NvbnRhY3QtM2AgT04gY29udGFjdF9hLmlkID0gYGNpdmljcm1f Z3JvdXBfY29u
dGFjdC0zYC5jb250YWN0X2lkICAKICAgICAgICBMRUZUIEpPSU4gY2l2aWNy bV9vcHRpb25f
Z3JvdXAgb3B0aW9uX2dyb3VwX2dlbmRlciBPTiAob3B0aW9uX2dyb3VwX2dl bmRlci5uYW1l
ID0gJ2dlbmRlcicpCiAgICAgICAgTEVGVCBKT0lOIGNpdmljcm1fb3B0aW9u X3ZhbHVlIGdl
bmRlciBPTiAoY2l2aWNybV9pbmRpdmlkdWFsLmdlbmRlcl9pZCA9IGdlbmRl ci52YWx1ZSBB
TkQgb3B0aW9uX2dyb3VwX2dlbmRlci5pZCA9IGdlbmRlci5vcHRpb25fZ3Jv dXBfaWQpIApX
SEVSRSAgKCBgY2l2aWNybV9ncm91cF9jb250YWN0LTNgLmdyb3VwX2lkIElO ICg/KQogICAg
ICAgIEFORCBgY2l2aWNybV9ncm91cF9jb250YWN0LTNgLnN0YXR1cyBJTiAo IkFkZGVkIikg
KQogICAgICAgIEFORCBjb250YWN0X2EuY29udGFjdF90eXBlID0gPwpPUkRF UiBCWSBzb3J0
X25hbWUgYXNjIAo8L3Byb3BlcnR5PgogICAgICAgIDwvb2RhLWRhdGEtc2V0 PgogICAgICAg
IDxvZGEtZGF0YS1zZXQgZXh0ZW5zaW9uSUQ9Im9yZy5lY2xpcHNlLmJpcnQu cmVwb3J0LmRh
dGEub2RhLmpkYmMuSmRiY1NlbGVjdERhdGFTZXQiIG5hbWU9IkRTX2dyb3Vw SWQiIGlkPSIx
MzkiPgogICAgICAgICAgICA8c3RydWN0dXJlIG5hbWU9ImNhY2hlZE1ldGFE YXRhIj4KICAg
ICAgICAgICAgICAgIDxsaXN0LXByb3BlcnR5IG5hbWU9InJlc3VsdFNldCI+ CiAgICAgICAg
ICAgICAgICAgICAgPHN0cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICAg ICAgPHByb3Bl
cnR5IG5hbWU9InBvc2l0aW9uIj4xPC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICAg
ICAgPHByb3BlcnR5IG5hbWU9Im5hbWUiPmlkPC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImRhdGFUeXBlIj5pbnRlZ2VyPC9w cm9wZXJ0eT4K
aXRpb24iPjI8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8 cHJvcGVydHkg
bmFtZT0ibmFtZSI+bmFtZTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAg ICAgICAgIDxw
ICAgICAgICA8L3N0cnVjdHVyZT4KICAgICAgICAgICAgICAgIDwvbGlzdC1w cm9wZXJ0eT4K
ICAgICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgIDxwcm9wZXJ0 eSBuYW1lPSJk
YXRhU291cmNlIj5jaXZpY3JtPC9wcm9wZXJ0eT4KICAgICAgICAgICAgPGxp c3QtcHJvcGVy
dHkgbmFtZT0icmVzdWx0U2V0Ij4KICAgICAgICAgICAgICAgIDxzdHJ1Y3R1 cmU+CiAgICAg
ICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBvc2l0aW9uIj4xPC9w cm9wZXJ0eT4K
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+aWQ8 L3Byb3BlcnR5
PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVO YW1lIj5pZDwv
cHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9 ImRhdGFUeXBl
Ij5pbnRlZ2VyPC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0ibmF0aXZlRGF0YVR5cGUiPjQ8L3Byb3BlcnR5PgogICAgICAgICAgICAg ICAgPC9zdHJ1
Y3R1cmU+CiAgICAgICAgICAgICAgICA8c3RydWN0dXJlPgogICAgICAgICAg ICAgICAgICAg
IDxwcm9wZXJ0eSBuYW1lPSJwb3NpdGlvbiI+MjwvcHJvcGVydHk+CiAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9Im5hbWUiPm5hbWU8L3Byb3BlcnR5Pgog ICAgICAgICAg
ICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYXRpdmVOYW1lIj5uYW1lPC9w cm9wZXJ0eT4K
cXVlcnlUZXh0Ij5zZWxlY3QgaWQsIG5hbWUKZnJvbSBjaXZpY3JtX2dyb3Vw Cm9yZGVyIGJ5
IG5hbWU7PC9wcm9wZXJ0eT4KICAgICAgICAgICAgPHhtbC1wcm9wZXJ0eSBu YW1lPSJkZXNp
Z25lclZhbHVlcyI+PCFbQ0RBVEFbPD94bWwgdmVyc2lvbj0iMS4wIiBlbmNv ZGluZz0iVVRG
LTgiPz4KPG1vZGVsOkRlc2lnblZhbHVlcyB4bWxuczpkZXNpZ249Imh0dHA6 Ly93d3cuZWNs
aXBzZS5vcmcvZGF0YXRvb2xzL2Nvbm5lY3Rpdml0eS9vZGEvZGVzaWduIiB4 bWxuczptb2Rl
bD0iaHR0cDovL3d3dy5lY2xpcHNlLm9yZy9iaXJ0L3JlcG9ydC9tb2RlbC9h ZGFwdGVyL29k
YU1vZGVsIj4KICA8VmVyc2lvbj4xLjA8L1ZlcnNpb24+CiAgPGRlc2lnbjpS ZXN1bHRTZXRz
IGRlcml2ZWRNZXRhRGF0YT0idHJ1ZSI+CiAgICA8ZGVzaWduOnJlc3VsdFNl dERlZmluaXRp
b25zPgogICAgICA8ZGVzaWduOnJlc3VsdFNldENvbHVtbnM+CiAgICAgICAg PGRlc2lnbjpy
ZXN1bHRDb2x1bW5EZWZpbml0aW9ucz4KICAgICAgICAgIDxkZXNpZ246YXR0 cmlidXRlcz4K
ICAgICAgICAgICAgPGRlc2lnbjpuYW1lPm5hbWU8L2Rlc2lnbjpuYW1lPgog ICAgICAgICAg
ICA8ZGVzaWduOnBvc2l0aW9uPjE8L2Rlc2lnbjpwb3NpdGlvbj4KICAgICAg ICAgICAgPGRl
c2lnbjpuYXRpdmVEYXRhVHlwZUNvZGU+MTI8L2Rlc2lnbjpuYXRpdmVEYXRh VHlwZUNvZGU+
CiAgICAgICAgICAgIDxkZXNpZ246cHJlY2lzaW9uPjY0PC9kZXNpZ246cHJl Y2lzaW9uPgog
ICAgICAgICAgICA8ZGVzaWduOnNjYWxlPjA8L2Rlc2lnbjpzY2FsZT4KICAg ICAgICAgICAg
PGRlc2lnbjpudWxsYWJpbGl0eT5OdWxsYWJsZTwvZGVzaWduOm51bGxhYmls aXR5PgogICAg
ICAgICAgPC9kZXNpZ246YXR0cmlidXRlcz4KICAgICAgICAgIDxkZXNpZ246 dXNhZ2VIaW50
cz4KICAgICAgICAgICAgPGRlc2lnbjpsYWJlbD5uYW1lPC9kZXNpZ246bGFi ZWw+CiAgICAg
ICAgICAgIDxkZXNpZ246Zm9ybWF0dGluZ0hpbnRzPgogICAgICAgICAgICAg IDxkZXNpZ246
ZGlzcGxheVNpemU+NjQ8L2Rlc2lnbjpkaXNwbGF5U2l6ZT4KICAgICAgICAg ICAgPC9kZXNp
Z246Zm9ybWF0dGluZ0hpbnRzPgogICAgICAgICAgPC9kZXNpZ246dXNhZ2VI aW50cz4KICAg
ICAgICA8L2Rlc2lnbjpyZXN1bHRDb2x1bW5EZWZpbml0aW9ucz4KICAgICAg PC9kZXNpZ246
cmVzdWx0U2V0Q29sdW1ucz4KICAgIDwvZGVzaWduOnJlc3VsdFNldERlZmlu aXRpb25zPgog
IDwvZGVzaWduOlJlc3VsdFNldHM+CjwvbW9kZWw6RGVzaWduVmFsdWVzPl1d PjwveG1sLXBy
b3BlcnR5PgogICAgICAgIDwvb2RhLWRhdGEtc2V0PgogICAgPC9kYXRhLXNl dHM+CiAgICA8
cGFnZS1zZXR1cD4KICAgICAgICA8c2ltcGxlLW1hc3Rlci1wYWdlIG5hbWU9 IlNpbXBsZSBN
YXN0ZXJQYWdlIiBpZD0iMiI+CiAgICAgICAgICAgIDxwYWdlLWZvb3Rlcj4K ICAgICAgICAg
ICAgICAgIDx0ZXh0IGlkPSIzIj4KICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0iY29udGVudFR5cGUiPmh0bWw8L3Byb3BlcnR5PgogICAgICAgICAgICAg ICAgICAgIDx0
ZXh0LXByb3BlcnR5IG5hbWU9ImNvbnRlbnQiPjwhW0NEQVRBWzx2YWx1ZS1v Zj5uZXcgRGF0
ZSgpPC92YWx1ZS1vZj5dXT48L3RleHQtcHJvcGVydHk+CiAgICAgICAgICAg ICAgICA8L3Rl
eHQ+CiAgICAgICAgICAgIDwvcGFnZS1mb290ZXI+CiAgICAgICAgPC9zaW1w bGUtbWFzdGVy
LXBhZ2U+CiAgICA8L3BhZ2Utc2V0dXA+CiAgICA8Ym9keT4KICAgICAgICA8 dGFibGUgaWQ9
IjciPgogICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZm9udEZhbWlseSI+ c2Fucy1zZXJp
ZjwvcHJvcGVydHk+CiAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJjb2xv ciI+IzEzMUI2
RDwvcHJvcGVydHk+CiAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJ0ZXh0 QWxpZ24iPmxl
ZnQ8L3Byb3BlcnR5PgogICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0id2lk dGgiPjEwMCU8
L3Byb3BlcnR5PgogICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVNl dCI+Y29udGFj
dERhdGFzZXQ8L3Byb3BlcnR5PgogICAgICAgICAgICA8bGlzdC1wcm9wZXJ0 eSBuYW1lPSJi
b3VuZERhdGFDb2x1bW5zIj4KICAgICAgICAgICAgICAgIDxzdHJ1Y3R1cmU+ CiAgICAgICAg
ICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9Im5hbWUiPnN0cmVldF9hZGRy ZXNzPC9wcm9w
ZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8ZXhwcmVzc2lvbiBuYW1lPSJl eHByZXNzaW9u
Ij5kYXRhU2V0Um93WyJzdHJlZXRfYWRkcmVzcyJdPC9leHByZXNzaW9uPgog ICAgICAgICAg
ZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFtZSI+ Z2VuZGVyPC9w
cm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8ZXhwcmVzc2lvbiBuYW1l PSJleHByZXNz
aW9uIj5kYXRhU2V0Um93WyJnZW5kZXIiXTwvZXhwcmVzc2lvbj4KICAgICAg ICAgICAgICAg
ICAgICA8cHJvcGVydHkgbmFtZT0iZGF0YVR5cGUiPnN0cmluZzwvcHJvcGVy dHk+CiAgICAg
PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICA8ZXhwcmVzc2lvbiBu YW1lPSJleHBy
ZXNzaW9uIj5kYXRhU2V0Um93WyJzdGF0ZV9wcm92aW5jZSJdPC9leHByZXNz aW9uPgogICAg
ICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+c3Ry aW5nPC9wcm9w
cnVjdHVyZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i bmFtZSI+Y291
bnRyeTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPGV4cHJlc3Np b24gbmFtZT0i
ZXhwcmVzc2lvbiI+ZGF0YVNldFJvd1siY291bnRyeSJdPC9leHByZXNzaW9u PgogICAgICAg
ICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJkYXRhVHlwZSI+c3RyaW5n PC9wcm9wZXJ0
eT4KICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAgICAgICAgICAg ICAgPHN0cnVj
dHVyZT4KICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0ibmFt ZSI+cGhvbmU8
L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxleHByZXNzaW9uIG5h bWU9ImV4cHJl
c3Npb24iPmRhdGFTZXRSb3dbInBob25lIl08L2V4cHJlc3Npb24+CiAgICAg ICAgICAgICAg
ICAgICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAgICAgICAgICAgICA8c3Ry dWN0dXJlPgog
ICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJuYW1lIj5waG9u ZV90eXBlPC9w
aW9uIj4nKCcgKyBkYXRhU2V0Um93WyJwaG9uZV90eXBlIl0gKyAnKSc8L2V4 cHJlc3Npb24+
L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgPC9zdHJ1Y3R1cmU+CiAgICAg ICAgICAgICAg
ICA8c3RydWN0dXJlPgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBu YW1lPSJuYW1l
Ij5zb3J0X25hbWU8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgIDxl eHByZXNzaW9u
IG5hbWU9ImV4cHJlc3Npb24iPmRhdGFTZXRSb3dbInNvcnRfbmFtZSJdPC9l eHByZXNzaW9u
PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgIDwvc3RydWN0dXJlPgogICAg ICAgICAgICA8
L2xpc3QtcHJvcGVydHk+CiAgICAgICAgICAgIDxjb2x1bW4gaWQ9IjI5Ij4K ICAgICAgICAg
ICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJ3aWR0aCI+MS44NDJpbjwvcHJvcGVy dHk+CiAgICAg
ICAgICAgIDwvY29sdW1uPgogICAgICAgICAgICA8Y29sdW1uIGlkPSIzMCI+ CiAgICAgICAg
ICAgICAgICA8cHJvcGVydHkgbmFtZT0id2lkdGgiPjAuNDQ3aW48L3Byb3Bl cnR5PgogICAg
ICAgICAgICA8L2NvbHVtbj4KICAgICAgICAgICAgPGNvbHVtbiBpZD0iMzEi PgogICAgICAg
ICAgICAgICAgPHByb3BlcnR5IG5hbWU9IndpZHRoIj4wLjUxM2luPC9wcm9w ZXJ0eT4KICAg
ICAgICAgICAgPC9jb2x1bW4+CiAgICAgICAgICAgIDxjb2x1bW4gaWQ9IjMy Ij4KICAgICAg
ICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJ3aWR0aCI+MC43MzRpbjwvcHJv cGVydHk+CiAg
ICAgICAgICAgIDwvY29sdW1uPgogICAgICAgICAgICA8Y29sdW1uIGlkPSIz MyI+CiAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0id2lkdGgiPjAuNjVpbjwvcHJv cGVydHk+CiAg
ICAgICAgICAgIDwvY29sdW1uPgogICAgICAgICAgICA8Y29sdW1uIGlkPSIz NCI+CiAgICAg
ICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0id2lkdGgiPjAuNDQ1aW48L3By b3BlcnR5Pgog
ICAgICAgICAgICA8L2NvbHVtbj4KICAgICAgICAgICAgPGNvbHVtbiBpZD0i NTMiPgogICAg
ICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9IndpZHRoIj4wLjQ0NWluPC9w cm9wZXJ0eT4K
ICAgICAgICAgICAgPC9jb2x1bW4+CiAgICAgICAgICAgIDxjb2x1bW4gaWQ9 IjU4Ij4KICAg
ICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJ3aWR0aCI+MC40ODFpbjwv cHJvcGVydHk+
CiAgICAgICAgICAgIDwvY29sdW1uPgogICAgICAgICAgICA8Y29sdW1uIGlk PSI2NCI+CiAg
ICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0id2lkdGgiPjAuNDY5aW48 L3Byb3BlcnR5
PgogICAgICAgICAgICA8L2NvbHVtbj4KICAgICAgICAgICAgPGhlYWRlcj4K ICAgICAgICAg
ICAgICAgIDxyb3cgaWQ9IjM1Ij4KICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0iYmFja2dyb3VuZENvbG9yIj4jOEZDQkQ4PC9wcm9wZXJ0eT4KICAgICAg ICAgICAgICAg
ICAgICA8cHJvcGVydHkgbmFtZT0iY29sb3IiPiMxQjMzMzc8L3Byb3BlcnR5 PgogICAgICAg
ICAgICAgICAgICAgIDxjZWxsIGlkPSIzNiI+CiAgICAgICAgICAgICAgICAg ICAgICAgIDxw
cm9wZXJ0eSBuYW1lPSJjb2xTcGFuIj45PC9wcm9wZXJ0eT4KICAgICAgICAg ICAgICAgICAg
ICAgICAgPHByb3BlcnR5IG5hbWU9InJvd1NwYW4iPjE8L3Byb3BlcnR5Pgog ICAgICAgICAg
ICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0icGFkZGluZ1RvcCI+NXB0 PC9wcm9wZXJ0
eT4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InBh ZGRpbmdMZWZ0
Ij4ycHQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0icGFkZGluZ0JvdHRvbSI+MHB0PC9wcm9wZXJ0eT4KICAgICAgICAgICAg ICAgICAgICAg
ICAgPHByb3BlcnR5IG5hbWU9InBhZGRpbmdSaWdodCI+MnB0PC9wcm9wZXJ0 eT4KICAgICAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InRleHRBbGlnbiI+ bGVmdDwvcHJv
cGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDx0ZXh0IGlkPSI0MiI+ CiAgICAgICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iZm9udFNpemUi Pmxhcmdlcjwv
cHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
Zm9udFdlaWdodCI+Ym9sZDwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICA8cHJvcGVydHkgbmFtZT0iY29sb3IiPiMxQjMzMzc8L3Byb3BlcnR5Pgog ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9InRleHRBbGlnbiI+ Y2VudGVyPC9w
cm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0 eSBuYW1lPSJj
b250ZW50VHlwZSI+cGxhaW48L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgPHRleHQtcHJvcGVydHkgbmFtZT0iY29udGVudCI+PCFbQ0RBVEFbQ29u dGFjdCBEZXRh
aWxzIGJ5IENvbnRhY3QgVHlwZSBhbmQgR3JvdXBdXT48L3RleHQtcHJvcGVy dHk+CiAgICAg
ICAgICAgICAgICAgICAgICAgIDwvdGV4dD4KICAgICAgICAgICAgICAgICAg ICA8L2NlbGw+
CiAgICAgICAgICAgICAgICA8L3Jvdz4KICAgICAgICAgICAgICAgIDxyb3cg aWQ9IjE0MCI+
CiAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImJhY2tncm91 bmRDb2xvciI+
IzhGQ0JEODwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPHByb3Bl cnR5IG5hbWU9
ImNvbG9yIj4jMUIzMzM3PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAg ICA8Y2VsbCBp
ZD0iMTQxIj4KICAgICAgICAgICAgICAgICAgICAgICAgPHByb3BlcnR5IG5h bWU9ImNvbFNw
YW4iPjk8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJv cGVydHkgbmFt
ZT0icm93U3BhbiI+MTwvcHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJwYWRkaW5nVG9wIj4wcHQ8L3Byb3BlcnR5PgogICAgICAg ICAgICAgICAg
ICAgICAgICA8cHJvcGVydHkgbmFtZT0icGFkZGluZ0xlZnQiPjJwdDwvcHJv cGVydHk+CiAg
ICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJwYWRkaW5n Qm90dG9tIj4w
cHQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVy dHkgbmFtZT0i
cGFkZGluZ1JpZ2h0Ij4ycHQ8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAg ICAgICAgICA8
cHJvcGVydHkgbmFtZT0idGV4dEFsaWduIj5sZWZ0PC9wcm9wZXJ0eT4KICAg ICAgICAgICAg
ICAgICAgICAgICAgPHRleHQtZGF0YSBpZD0iMTUwIj4KICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJmb250U2l6ZSI+c21hbGw8L3Byb3Bl cnR5PgogICAg
ICAgICAgICAgICAgICAgICAgICAgICAgPGV4cHJlc3Npb24gbmFtZT0idmFs dWVFeHByIj4i
Jmx0O3N0cm9uZz4mbHQ7dWw+Jmx0O2xpPkNvbnRhY3QgVHlwZSAtICIgKyBw YXJhbXNbIlJQ
X2NvbnRhY3RUeXBlIl0gKyAiJmx0Oy9saT4mbHQ7bGk+R3JvdXAgLSIgKyBw YXJhbXNbIlJQ
X2dyb3VwIl0gKyAiJmx0Oy9saT4mbHQ7L3VsPiZsdDsvc3Ryb25nPiI8L2V4 cHJlc3Npb24+
CiAgICAgICAgICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0i Y29udGVudFR5
cGUiPmh0bWw8L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICA8 L3RleHQtZGF0
YT4KICAgICAgICAgICAgICAgICAgICA8L2NlbGw+CiAgICAgICAgICAgICAg ICA8L3Jvdz4K
ICAgICAgICAgICAgICAgIDxyb3cgaWQ9IjgiPgogICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJiYWNrZ3JvdW5kQ29sb3IiPiNCQUUwRTg8L3Byb3BlcnR5 PgogICAgICAg
ICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJmb250U2l6ZSI+c21hbGw8 L3Byb3BlcnR5
PgogICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJjb2xvciI+ IzFCMzMzNzwv
cHJvcGVydHk+CiAgICAgICAgICAgICAgICAgICAgPGNlbGwgaWQ9IjkiPgog ICAgICAgICAg
ICAgICAgICAgICAgICA8dGV4dCBpZD0iNDMiPgogICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgPHByb3BlcnR5IG5hbWU9Im1hcmdpbkxlZnQiPjVwdDwvcHJvcGVydHk+ CiAgICAgICAg
ICAgICAgICAgICAgICAgICAgICA8cHJvcGVydHkgbmFtZT0iY29udGVudFR5 cGUiPnBsYWlu
PC9wcm9wZXJ0eT4KICAgICAgICAgICAgICAgICAgICAgICAgICAgIDx0ZXh0 LXByb3BlcnR5
IG5hbWU9ImNvbnRlbnQiPjwhW0NEQVRBW05hbWVdXT48L3RleHQtcHJvcGVy dHk+CiAgICAg
CiAgICAgICAgICAgICAgICAgICAgPGNlbGwgaWQ9IjEwIj4KICAgICAgICAg ICAgICAgICAg
ICAgICAgPHRleHQgaWQ9IjQ0Ij4KICAgICAgICAgICAgICAgICAgICAgICAg ICAgIDxwcm9w
ZXJ0eSBuYW1lPSJtYXJnaW5MZWZ0Ij41cHQ8L3Byb3BlcnR5PgogICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgPHByb3BlcnR5IG5hbWU9ImNvbnRlbnRUeXBlIj5wbGFp bjwvcHJvcGVy
dHk+CiAgICAgICAgICAgICAgICAgICAgICAgICAgICA8dGV4dC1wcm9wZXJ0 eSBuYW1lPSJj
b250ZW50Ij48IVtDREFUQVtHZW5kZXJdXT48L3RleHQtcHJvcGVydHk+CiAg ICAgICAgICAg
ICAgICAgICAgICAgIDwvdGV4dD4KICAgICAgICAgICAgICAgICAgICA8L2Nl bGw+CiAgICAg
ICAgICAgICAgICAgICAgPGNlbGwgaWQ9IjExIj4KICAgICAgICAgICAgICAg ICAgICAgICAg
PHByb3BlcnR5IG5hbWU9ImNvbFNwYW4iPjI8L3Byb3BlcnR5PgogICAgICAg ICAgICAgICAg
ICAgICAgICA8cHJvcGVydHkgbmFtZT0icm93U3BhbiI+MTwvcHJvcGVydHk+ CiAgICAgICAg
ICAgICAgICAgICAgICAgIDx0ZXh0IGlkPSI0NiI+CiAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICA8cHJvcGVydHkgbmFtZT0ibWFyZ2luTGVmdCI+NXB0PC9wcm9wZXJ0 eT4KICAgICAg
ICAgICAgICAgICAgICAgICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJjb250ZW50 VHlwZSI+cGxh
aW48L3Byb3BlcnR5PgogICAgICAgICAgICAgICAgICAgICAgICAgICAgPHRl eHQtcHJvcGVy
dHkgbmFtZT0iY29udGVudCI+PCFbQ0RBVEFbU3RyZWV0IEFkZHJlc3NdXT48 L3RleHQtcHJv
cGVydHk+CiAgICAgICAgICAgICAgICAgICAgICAgIDwvdGV4dD4KICAgICAg ICAgICAgICAg
ICAgICA8L2NlbGw+CiAgICAgICAgICAgICAgICAgICAgPGNlbGwgaWQ9IjEz Ij4KICAgICAg
ICAgICAgICAgICAgICAgICAgPHRleHQgaWQ9IjQ3Ij4KICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgIDxwcm9wZXJ0eSBuYW1lPSJtYXJnaW5MZWZ0Ij41cHQ8L3Byb3Bl cnR5PgogICAg
Re: Error in reading rptdesign files from v2.1 [message #247755 is a reply to message #247524] Fri, 13 July 2007 03:57 Go to previous messageGo to next message
qwang/jason:
any thoughts / ideas on this and how we can potentially get around it.
we have a few rptdesign files (10-15) that we'd like to reuse from 2.1
rather than have to redo them from scratch in 2.2
a quick response would be great (and much appreciated!)
lobo
>> kinda important :)
>> thanx
>> lobo
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> Thanks
> Qs
Re: Error in reading rptdesign files from v2.1 [message #247767 is a reply to message #247755] Fri, 13 July 2007 07:10 Go to previous messageGo to next message
Member
Donald Lobo wrote:
> qwang/jason:
> lobo
>>> kinda important :)
>>> thanx
>>> lobo
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>> Thanks
>> Qs
I have tested the attached files. It works fine with my eclipse 3.3 +
BIRT 2.2 + winxp professional
Do u use the old workspace? I suggest you create a clean eclipse
environment and try again.
These sorts of problems usually cause by cached meta data with my
experiences.
Qs
Re: Error in reading rptdesign files from v2.1 [message #247882 is a reply to message #247767] Fri, 13 July 2007 19:40 Go to previous messageGo to next message
we've done a few clean install on different platforms (MacOSX and Ubuntu
Edgy) and different machines and we get exactly the same error
One machine had not used BIRT. I've deleted the workspace on my local
machine etc. I'm pretty sure its not metadata caching etc unless it is
stored in a different centralized place on the file system etc
any other thoughts or ideas.
thanx for the help and support :)
lobo
Re: Error in reading rptdesign files from v2.1 [message #247967 is a reply to message #247882] Mon, 16 July 2007 00:58 Go to previous messageGo to next message
Member
> lobo
Which package did you download?
Thanx
Qs
Re: Error in reading rptdesign files from v2.1 [message #248240 is a reply to message #247967] Mon, 16 July 2007 22:55 Go to previous messageGo to next message
In all cases we downloaded:
1. eclipse 3.3 classic from: http://www.eclipse.org/downloads/
2. Using the update manager in eclipse, we downloaded BIRT 2.2 prerequisites
is there a different way we can/should try?
lobo
>> lobo
> Thanx
> Qs
Re: Error in reading rptdesign files from v2.1 [message #249243 is a reply to message #247496] Fri, 20 July 2007 20:21 Go to previous messageGo to next message
Originally posted by: danny.rosenberg.weblayers.com
Same exact problem here. We already integrated the 2.2 runtime, so I'm in a
bit of a pickle here.
Error occurs using the AIO installer (R-R1-2_2_0-200706261010).
Any and all help appreciated.
"Donald Lobo" <lobo@yahoo.com> wrote in message
news:f73ucm$l2l$1@build.eclipse.org...
> kinda important :)
> thanx
> lobo
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Error in reading rptdesign files from v2.1 [message #249345 is a reply to message #249243] Sun, 22 July 2007 22:54 Go to previous messageGo to next message
Donald A. Lobo is currently offline Donald A. LoboFriend
We are on a schedule and cannot wait for a fix / reproduce this bug etc.
We've had multiple people reproduce the same issue.
One potential simple workaround is as follows:
1. Create a new report in BIRT 2.2
2. goto the XML source window
3. copy and paste your xml rptdesign from BIRT 2.1 into this window
4. Do a preview
The above procedure now works for us ..
Some comments about our experience on our blog at:
http://civicrm.org/node/214
I'm now trying to get BIRT Viewer 2.2 to work :)
lobo
>> I've downloaded Eclipse 3.3 and BIRT 2.2 and managed to get it working
>> after a bit of a struggle. Might help to let people who use the download
>> new install feature of Eclipse that its missing a dependency that you
>> need to download separately on the front page of BIRT / Wiki etc
>> ( http://dev.eclipse.org/newslists/news.eclipse.birt/msg21107. html)
>> Onto my next problem :)
>> 1. I can create a new report and it works fine
>> 2. I try importing a 2.1 rptdesign file and I get the below exception.
>> Do i need to do anything special to upgrade a 2.1 file?
>> thanx for any and all help. We'd like to ship CiviCRM v1.8
>> (http://civicrm.org) with BIRT 2.2 / Eclipse 3.3 support and so this is
>> kinda important :)
>> thanx
>> lobo
>> at
>> org.eclipse.birt.report.designer.ui.editors.MultiPageReportE ditor.addPages(MultiPageReportEditor.java:222)
>> at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:146)
>> at
>> org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:283)
>> at
>> org.eclipse.birt.report.designer.ui.editors.ReportEditorProx y.createPartControl(ReportEditorProxy.java:121)
>> at
>> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
>> at
>> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
>> at
>> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
>> at
>> org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2721)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
>> at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
>> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
>> at
>> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2539)
>> at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1090)
>> at
>> org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:105)
>> at
>> org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run( OpenLocalFileAction.java:75)
Re: Error in reading rptdesign files from v2.1 [message #249886 is a reply to message #249345] Thu, 26 July 2007 01:05 Go to previous messageGo to next message
Wang Qiangsheng is currently offline Wang QiangshengFriend
Member
> 4. Do a preview
> lobo
>>> kinda important :)
>>> thanx
>>> lobo
>>> java.lang.NullPointerException
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Thanks for the work around.
I'm debugging the code to see if potential bugs are there. I have found
at least 5 complains about same issue.
thanks
Qiangsheng
Re: Error in reading rptdesign files from v2.1 [message #250167 is a reply to message #249886] Fri, 27 July 2007 14:05 Go to previous messageGo to next message
Alex Krücken is currently offline Alex KrückenFriend
WangQS pravi:
>> 4. Do a preview
>> lobo
>>>> kinda important :)
>>>> thanx
>>>> lobo
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
> thanks
> Qiangsheng
I have the same problem - when I open any of my birt 2.1.2 rptdesign
files in birt 2.2, I get the null pointer exception. Copying the source
code works for now (haven't transformed all of my old birt files yet
though; if hope this trick works for all of them).
Re: Error in reading rptdesign files from v2.1 [message #250277 is a reply to message #249886] Sun, 29 July 2007 22:27 Go to previous messageGo to next message
Some more bad news with regard to this bug. This is quite a big
showstopper for us right now. A quick response / work around would be
great and very much appreciated.
Here's the latest issue. Reports created in 2.2 cannot be read when
copied/renamed/moved to another install. We check all our reports into
svn so we can distribute and share
1. Get a report working in 2.2 (either create from scratch or do a
copy-paste as described previously)
2. Save the report. Move it out of your workspace
3. Delete the workspace and create a new workspace
4. Create a new project and try to read report saved in 2. You get the
multipagereporteditor exception as below. Note that the copy-paste
technique will work in this case also
5. This basically means we cannot really share reports via svn as is in
our 2.2 install. We use a combination of MacOSX, Ubuntu, and fedora
boxes. I believe we can recreate this error on all the above systems.
If you need more information or details please send me email.
lobo
>> 4. Do a preview
>> lobo
>>>> kinda important :)
>>>> thanx
>>>> lobo
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
> thanks
> Qiangsheng
Re: Error in reading rptdesign files from v2.1 [message #253053 is a reply to message #250277] Mon, 20 August 2007 21:04 Go to previous message
Snjezana Peco is currently offline Snjezana PecoFriend
I think this is a bug in BIRT 2.2. BIRT doesn't handle editor inputs
that are FileStoreEditorInput type.
I have tested the attached files and can reproduce your issue.
It occurs when opening a report from the file system (out of a
workspace). If the report has been imported into some project, it is
opened correctly.
The fix is adding the following code to the MultiPageReportEditor.java
class:
// copy from org.eclipse.ui.internal.util.Util.getAdapter()
public static Object getAdapter(Object sourceObject, Class adapterType) {
Assert.isNotNull(adapterType);
if (sourceObject == null) {
return null;
if (adapterType.isInstance(sourceObject)) {
return sourceObject;
if (sourceObject instanceof IAdaptable) {
IAdaptable adaptable = (IAdaptable) sourceObject;
Object result = adaptable.getAdapter(adapterType);
if (result != null) {
// Sanity-check
Assert.isTrue(adapterType.isInstance(result));
return result;
if (!(sourceObject instanceof PlatformObject)) {
Object result =
Platform.getAdapterManager().getAdapter(sourceObject, adapterType);
return result;
return null;
public IEditorInput getEditorInput() {
IEditorInput input = super.getEditorInput();
if (input instanceof IPathEditorInput) {
return super.getEditorInput();
return (IEditorInput) getAdapter(input, IPathEditorInput.class);
Snjeza
> lobo
>>> 4. Do a preview
>>> lobo
>>>>> kinda important :)
>>>>> thanx
>>>>> lobo
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>> thanks
>> Qiangsheng
Previous Topic:Not getting Birt Report Viewer Please help
Next Topic:parameter question
Current Time: Tue Nov 12 19:42:32 GMT 2024
Powered by FUDForum. Page generated in 0.05914 seconds
