Getting multiple rows from XML file into a Birt report [message #247455] |
Wed, 11 July 2007 19:54 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wesolowski.maciej.gmail.com
I'm building a report in Birt getting data from XML file. There are sets of
actors, use cases and some others in that file. I would like to get every
actor (xsi-type: actor) into the report. In the column selection (while
creating a Data Set) I have an access to xsi-type only (I can't pick a
specific type). That would not be a problem if I could get all rows into the
report but I only get the very first one. How can I get them all (to select
the correct ones in the expression builder)?
Re: Getting multiple rows from XML file into a Birt report [message #247577 is a reply to message #247547] |
Thu, 12 July 2007 11:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Sure. I attach a zip file with the XML and some screenshots of what I see
when importing that file into Birt.
"Tianli" <tzhang@actuate.com> wrote in message
news:6fdec23ff97e7885c86bf140158c7223$1@www.eclipse.org...
> Hi Maciej
> Can you attache your xml file? I have tried as you said it work. I can
> retrive all the values. Have you use the //actor in table mapping?
> Below is my example xml file
> <?xml version="1.0"?>
> <ipo:purchaseOrder
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ipo="http://www.example.com/IPO"
> orderDate="1999-12-01">
> <shipTo exportCode="1" xsi:type="ipo:UKAddress">
> <name>Helen Zoe1</name>
> </shipTo>
> <name>Helen Zoe2</name>
> </shipTo>
> <billTo xsi:type="ipo:USAddress">
> <shipTo exportCode="2" xsi:type="ipo:UKAddress">
> <name>Helen Zoe3</name>
> </shipTo>
> <name>Robert Smith</name>
> </billTo>
> </ipo:purchaseOrder>
> table mapping: //shipTo
> column mapping: @xsi:type
> name
> Regards!
Attachment: birt.zip
(Size: 181.59KB, Downloaded 90 times)
Re: Getting multiple rows from XML file into a Birt report [message #247784 is a reply to message #247455] |
Fri, 13 July 2007 11:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Can anyone help me? It's quite important. I'd be very thankful...
"Maciej" <wesolowski.maciej@gmail.com> wrote in message
news:f73ch5$dbt$1@build.eclipse.org...
> of actors, use cases and some others in that file. I would like to get
> every actor (xsi-type: actor) into the report. In the column selection
> (while creating a Data Set) I have an access to xsi-type only (I can't
> pick a specific type). That would not be a problem if I could get all rows
> into the report but I only get the very first one. How can I get them all
> (to select the correct ones in the expression builder)?
Re: Getting multiple rows from XML file into a Birt report [message #247952 is a reply to message #247911] |
Sun, 15 July 2007 17:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi :)
I can't check it right now but it looks like it works :) Thanks a lot, if I
have any more problems I'll shoot an email ;). Thank you once again :)
"Tianli Zhang" <tzhang@actuate.com> wrote in message
news:f792ad$reu$1@build.eclipse.org...
> Hi Maciej
> Attached the print screen of what I specified in table mapping and column
> mapping, I hope my solution can solve your problem, if any question
> welcome to ask
> Regards
> news:f77n3i$rnd$1@build.eclipse.org...
>>> rows
>>> all
FUDForum. Page generated in 0.04074 seconds
