Error when final fields (constants) not initialized at declaration [message #247433] |
Wed, 05 September 2007 11:13  |
Originally posted by: gerold.broser.easyklick.com
Java allows the following (at least till v1.4), but JDT marks both lines with errors, without the possibility to suppress it in
Preferences -> Java -> Compiler -> Errors/Warnings:
MyClass
private final String MY_CONSTANT; // msg: "The empty final field MY_CONSTANT is possibly not initialized"
MyClass()
MY_CONSTANT = "MyValue"; // msg: "The final field MyClass.MY_CONSTANT cannot be assigned"
Geri
Re: Error when final fields (constants) not initialized at declaration [message #247462 is a reply to message #247442] |
Wed, 05 September 2007 12:15   |
Thanks, Ed, it was actually the "static". (Of course, silly me, statics have to be available regardless of constructor execution.)
However, what I really want to do is the following, but:
class MyClass
private final static Class clazz; // msg: "The empty final field clazz is possibly not initialized"
static
try
clazz = Class.forName( "my.package.MyClass" );
catch( ClassNotFoundException cnfe )
.... or ...
class MyClass
static // no "throws ClassNotFoundException"-clause here
Geri
Ed Merks wrote:
> Geri,
> I tried your example without errors as follows (hopefully you get the
> image).
> Are you sure you haven't left something out of the example you've copied
> here? E.g., the keyword static on your constant; you can't initialize a
> static constant in the constructor, you'd have to do it in a static block:
> public class A
> final static String x;
> static
> x = "";
> public A()
>> MyClass
>> MyClass()
>> Geri
Re: Error when final fields (constants) not initialized at declaration [message #247467 is a reply to message #247462] |
Wed, 05 September 2007 12:35   |
--------------000607020301090905040900
Geri,
I thought so! :-)
You can use this type of approach:
class MyClass
private final static Class CLASS;
static
Class clazz = null;
try
CLASS = clazz;
I.e., compute the value and assign it once you've decided what the final
value should be.
> class MyClass
> static
> try
> ... or ...
> class MyClass
> Geri
> Ed Merks wrote:
>> Geri,
>> image).
>> copied here? E.g., the keyword static on your constant; you can't
>> initialize a static constant in the constructor, you'd have to do it
>> in a static block:
>> public class A
>> static
>> x = "";
>> public A()
>>> MyClass
>>> MyClass()
>>> Geri
<html>
<head>
http-equiv="Content-Type">
</head>
Geri,<br>
<br>
I thought so!
FUDForum. Page generated in 0.06161 seconds
