Error when final fields (constants) not initialized at declaration [message #247433] |
Wed, 05 September 2007 15:13 |
Originally posted by: gerold.broser.easyklick.com
Java allows the following (at least till v1.4), but JDT marks both lines with errors, without the possibility to suppress it in
Preferences -> Java -> Compiler -> Errors/Warnings:
MyClass
private final String MY_CONSTANT; // msg: "The empty final field MY_CONSTANT is possibly not initialized"
MyClass()
MY_CONSTANT = "MyValue"; // msg: "The final field MyClass.MY_CONSTANT cannot be assigned"
Geri
Re: Error when final fields (constants) not initialized at declaration [message #247442 is a reply to message #247433] |
Wed, 05 September 2007 15:24 |
--------------060504070600050903050301
Geri,
I tried your example without errors as follows (hopefully you get the
image).
Are you sure you haven't left something out of the example you've copied
here? E.g., the keyword static on your constant; you can't initialize a
static constant in the constructor, you'd have to do it in a static block:
public class A
final static String x;
static
x = "";
public A()
> MyClass
> MyClass()
> Geri
Content-Type: multipart/related;
boundary="------------040206070106050504020409"
--------------040206070106050504020409
<html>
<head>
http-equiv="Content-Type">
</head>
Geri,<br>
<br>
image).<br>
<blockquote><img src="cid:part1.05010204.00070008@ca.ibm.com" alt=""><br>
</blockquote>
<br>
copied here?
Re: Error when final fields (constants) not initialized at declaration [message #247457 is a reply to message #247433] |
Wed, 05 September 2007 15:30 |
Originally posted by: wharley.bea.com
"Geri Broser" <gerold.broser@easyklick.com> wrote in message
news:fbmh1a$1fe$1@build.eclipse.org...
> with errors, without the possibility to suppress it in Preferences ->
> MyClass
> MyClass()
> cannot be assigned"
If I add the keyword "class" before the first "MyClass", that code compiles
with no errors for me in Eclipse.
Have you tried this in a project with default compiler settings? What are
your compiler settings? What version of Eclipse are you using?
Re: Error when final fields (constants) not initialized at declaration [message #247462 is a reply to message #247442] |
Wed, 05 September 2007 16:15 |
Thanks, Ed, it was actually the "static". (Of course, silly me, statics have to be available regardless of constructor execution.)
However, what I really want to do is the following, but:
class MyClass
private final static Class clazz; // msg: "The empty final field clazz is possibly not initialized"
static
try
clazz = Class.forName( "my.package.MyClass" );
catch( ClassNotFoundException cnfe )
.... or ...
class MyClass
static // no "throws ClassNotFoundException"-clause here
Geri
Ed Merks wrote:
> Geri,
> image).
> public class A
> static
> x = "";
> public A()
>> MyClass
>> MyClass()
>> Geri
Re: Error when final fields (constants) not initialized at declaration [message #247467 is a reply to message #247462] |
Wed, 05 September 2007 16:35 |
--------------000607020301090905040900
Geri,
I thought so! :-)
You can use this type of approach:
class MyClass
private final static Class CLASS;
static
Class clazz = null;
try
CLASS = clazz;
I.e., compute the value and assign it once you've decided what the final
value should be.
> class MyClass
> static
> try
> ... or ...
> class MyClass
> Geri
> Ed Merks wrote:
>> Geri,
>> image).
>> copied here? E.g., the keyword static on your constant; you can't
>> initialize a static constant in the constructor, you'd have to do it
>> in a static block:
>> public class A
>> static
>> x = "";
>> public A()
>>> MyClass
>>> MyClass()
>>> Geri
<html>
<head>
</head>
Geri,<br>
<br>
I thought so!
FUDForum. Page generated in 0.05047 seconds
