Home » Archived » BIRT » Application Context getting empty for CrossTab Report
Application Context getting empty for CrossTab Report [message #247401] Wed, 11 July 2007 15:18 Go to next message
venkat is currently offline venkatFriend
I am setting SpringContext and having my own plugin to get the
connection.Every thing is going fine for normal reports, but for reports
which are having Cubes (Crosstab) its making the appcontext getting empty.
please help me any one on this
for Cross tab reports only i have this issue (Overwriting the appcontext
which i passed)
This is Happening with Both Birt2.2RC0 and Birt2.2 release .
***********************Logs when i run the a CrossTab
Report*********************************
Jul 5, 2007 10:55:28 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
prepare
FINE: Finished preparing query.
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager
addProfileProviderService( Map )
INFO: Added default property service:
org.eclipse.datatools.connectivity.oda.profile.connectionPro pertyService
http-8080-Processor25 : The context
is{OdaConsumerId=org.eclipse.datatools.connectivity.oda.prof ile.connectionPropertyService}
********************** Logs when i run a Normal Report (other than Cross
Tab)********************
Jul 5, 2007 10:56:36 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
prepare
is{OdaConsumerId=org.eclipse.datatools.connectivity.oda.prof ile.connectionPropertyService,
SPRING_DATA_SOURCE=org.apache.commons.dbcp.BasicDataSource@adcbab,
APPLICATION_CONTEXT=org.springframework.context.support.Clas sPathXmlApplicationContext:
display name
[org.springframework.context.support.ClassPathXmlApplication Context;hashCode=13027913];
startup date [Thu Jul 05 05:56:48 GMT 2007]; root of context hierarchy,
HTML_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.HTMLRenderContext@c98b6b}
**************************** End Of Logs
Can some one Give an Work around solution for this..
... thanks in advance
Venkat
Re: Application Context getting empty for CrossTab Report [message #247501 is a reply to message #247401] Thu, 12 July 2007 01:27 Go to previous message
Tianli Zhang is currently offline Tianli ZhangFriend
Hi Venkat
It is a known issue.
See bug#195617(https://bugs.eclipse.org/bugs/show_bug.cgi?id=195617).
We have already add your email in the cc list, so if we find the
workaround solution we will add comments in the Bugzilla.
Best Regards!
Previous Topic:Problems displaying report in report designer
Next Topic:LogLevel for viewer started with WebViewer.startup()
Current Time: Fri Dec 27 03:39:41 GMT 2024
Powered by FUDForum. Page generated in 0.03241 seconds
