Re: How to find out what editor is opened? [message #247480 is a reply to message #247389] |
Sat, 02 February 2008 17:01 |
Originally posted by: dcarver.starstandard.org
Orod wrote:
> Hi Everyone,
> How can I find out what the currently opened editor is? For example when
> I have opened an HTML page in an editor, given that I have multiple
> editors which could open an HTML file, then how can I find out what that
> particular editor that I have opened is?
> Thanks in Advance For your reply
You might want to try right mouse clicking on the file, and select Open
With. That will give you a list of possible editors, the one that is
selected is the one that it will open with. If you need the file to
open with a different editor, you can select the editor from that list.
The next time you open that particular file, it'll open with your
last selection.
Mark's suggestion on the File Association is also good, as you can
select to make a particular editor the default editor based on the
extension.
Re: How to find out what editor is opened? [message #247514 is a reply to message #247509] |
Sun, 03 February 2008 01:42 |
Orod wrote:
> Thanks for your replies. I do know about the default editor and how to
> open a file using different editors. What I actually was looking for
> was some easy way of knowing what the active editor is without having a
> prior knowledge of what editor was used to open the file. For example,
> when you look at a file that is opened with Ms Word, then you can see
> "Microsoft Word" at the top and know what editor is being used without
> having prior knowledge. I go from computer to computer and help people
> with their problems, and I thought there might be an easy way of
Well, if the editor has it's own Icon, then that should give you a
visual clue, but not a verbal clue.
Dave
FUDForum. Page generated in 0.07586 seconds
