Home » Eclipse Projects » Eclipse Platform » [RCP M8] NoClassDefFoundError org/eclipse/swt/widgets/Listener
[RCP M8] NoClassDefFoundError org/eclipse/swt/widgets/Listener [message #247377] Sun, 30 May 2004 17:43 Go to next message
Originally posted by: fre_gilbert.yahoo.fr
Hi all,
I'm under Gentoo Linux and I tried the RCP Tutorial Part 1. In eclipse
my plugin works fine but when I running it outside Eclipse, it doesn't
work and I have a NoClassDefFoundError :
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Listener
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:151)
org.eclipse.ui.tutorials.rcp.part1.RcpApplication.run(RcpApp lication.java:26)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:277)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:239)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
The plugins directory contains both org.eclipse.swt_3.0.0 and
org.eclipse.swt.gtk_3.0.0
Any idea ?
Thanks in advance,
Frédéric
Re: [RCP M8] NoClassDefFoundError org/eclipse/swt/widgets/Listener [message #247910 is a reply to message #247377] Tue, 01 June 2004 10:01 Go to previous messageGo to next message
exquisitus wrote:
> Hi all,
> at
> at
> at
> at
> at
> at
> Any idea ?
> Thanks in advance,
> Frédéric
I got a similar error as well. Difference was that
org/eclipse/swt/widgets/Control was the class not found.
The exception occured at the same location in tutorial 1
though and both the swt and swt gtk plugins where under the plugins
directory. I tried this a couple of ways as well, one by using the
RCP runtime download and the other by following the directions in
the tutorial to create the directory structure and copy all of the
plugins over. Neither worked and both gave the same error.
Running under Fedora Core 1, jdk 1.4.2_03.
Rob..
Re: [RCP M8] NoClassDefFoundError org/eclipse/swt/widgets/Listener [message #247935 is a reply to message #247910] Tue, 01 June 2004 10:41 Go to previous message
rob dingwell wrote:
> exquisitus wrote:
>> Hi all,
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Any idea ?
>> Thanks in advance,
>> Frédéric
> Rob..
Also I forgot to mention that this was on M9 not M8.
Rob
Previous Topic:eclipse stopped inserting ${tags}
Next Topic:JBOSS ClassCastException when accessing remote home interface
Current Time: Thu Oct 23 21:47:02 EDT 2025
Powered by FUDForum. Page generated in 0.03749 seconds
