Home » Language IDEs » Java Development Tools (JDT) » What preference controls compile warning about @Override
What preference controls compile warning about @Override [message #247178] Fri, 31 August 2007 16:22 Go to next message
Originally posted by: eclipse5.rizzoweb.com
In my workspace, methods that have the @Override annotation but do not
actually override an inherited method produce a compiler error, The
method XXX must override a superclass method."
On coworkers' workspace this is not marked as an error. I've checked
that my preferences under Java > Compiler > Errors & Warnings >
Annotations are the same.
Any ideas what is making this an error instead of a warning or ignore?
Eric
Re: What preference controls compile warning about @Override [message #247184 is a reply to message #247178] Fri, 31 August 2007 16:55 Go to previous messageGo to next message
Eric,
Are you sure? I think an @Override that's not really an @Override must
be treated as an error and there is no way to turn that off. Is it
possible that the other guy is using Java 6.0 and you're using Java
5.0. I believe (but I'm not sure) that in 6.0 that @Override can also
be used to indicate that you implement a method in an interface even
when you don't actually override a method declaration in another class...
> Eric
Re: What preference controls compile warning about @Override [message #247188 is a reply to message #247184] Fri, 31 August 2007 17:27 Go to previous messageGo to next message
Ed Merks a écrit :
> Eric,
That is right. @Override in 1.6 is less restrictive than in 1.5.
Olivier
Re: What preference controls compile warning about @Override [message #247197 is a reply to message #247184] Fri, 31 August 2007 23:28 Go to previous messageGo to next message
Ed Merks wrote:
> Eric,
That could very well be the case - I am definitely set up to JDK 1.5 and
at least some of my coworkers are running Eclipse under 1.6 so their
default is likely 1.6. I'll test out that theory next week.
Eric
>> Eric
Re: What preference controls compile warning about @Override [message #247416 is a reply to message #247188] Wed, 05 September 2007 09:31 Go to previous messageGo to next message
Originally posted by: adam.giemza.gmx.de
Olivier Thomann schrieb:
> Ed Merks a écrit :
>> Eric,
>> must be treated as an error and there is no way to turn that off. Is
>> it possible that the other guy is using Java 6.0 and you're using Java
> Olivier
Thanks for this hint. This is exactly the same problem, we had here. But
I am running Eclipse with Java 1.6, but I use 1.5 for my projects. My
compiler compliance level is also set to 5.0.
Now if I set the cleanup properties to add missing "@Overrides", it adds
the also to implemented interface methodes, that does not work with 1.5.
Is it a bug or a feature?
Greets,
Adam
Re: What preference controls compile warning about @Override [message #247530 is a reply to message #247416] Thu, 06 September 2007 09:31 Go to previous message
>> Ed Merks a écrit :
>>> Eric,
>>> Java 5.0. I believe (but I'm not sure) that in 6.0 that @Override
>>> can also be used to indicate that you implement a method in an
>>> interface even when you don't actually override a method declaration
>>> in another class...
>> Olivier
You should enter a bug for that, since Java 5 projects will immediately
mark such annotations as an error. Clean-up should not produce compile
errors, obviously.
http://bugs.eclipse.org/bugs
Eric
Previous Topic:def-use-chain
Next Topic:Programmatically switching to a view
Current Time: Wed Oct 15 06:41:49 EDT 2025
Powered by FUDForum. Page generated in 0.06499 seconds
