CISCO - Reporting [message #246887] |
Mon, 09 July 2007 09:48  |
Originally posted by: sendo.atlas.sk
hi all, i want to know, if there is somebody, who uses birt for cisco
router reporting? i want to know if it is possible to report host tables,
network traffic .... .thanks
Re: CISCO - Reporting [message #247021 is a reply to message #246887] |
Mon, 09 July 2007 21:55  |
Hello Andrej,
Great idea, but I don't know anyone that is doing that. This would make
a nice ODA extension. Within the the Data Source you would specify which
router to connect to. Then in the Data Set you would specify what calls
you make to the router for data. Since many people won't know the appropriate
router commands, you could create a list of common commands that a user could
then select from a drop down.
Scott Rosenbaum
> tables, network traffic .... .thanks
FUDForum. Page generated in 0.02514 seconds
