Re: Custom ReportItem inside a grid [message #247054 is a reply to message #247044] |
Tue, 10 July 2007 00:06 |
S. Forbes Messages: 35 Registered: July 2009 |
Member |
Hey Scott,
I didn't think about the charts embedded with a data set, just always
figured that chart would be generated using all the data in the
underlying data set, but with a little playing around I managed to sort
things out.
The problem with not being able to drop the item into the grid was just
a typo that happened to correspond with testing of this functionality.
Once I had that sorted it was a matter of playing with the IRowSet[]
passed to onRowSets in IReportItemPresentation to extract a columns
value from the underlying data set. Too easy.
Cheers, and thanks,
Shaun
Scott Rosenbaum wrote:
> Hello Shaun,
> The short answer is yes, you can do this. In fact, all of the charts
> are done as ReportItem extensions, so it is clear that you can create
> custom reportItems and drop them into a grid.
> What interfaces have you implemented so far for your RotatedText?
> Scott Rosenbaum
>> d like to know if it's possible to build a custom report item that can
>> be embedded in a grid along with a data set and have the item drawn
>> for each row (with it being able to be modified depending upon some
>> info in the current row).
>> At the moment I can't even get the report item (based on the rotated
>> label example) to be dropped into the grid, let alone figure out how
>> it can be linked with the current row.
Re: Custom ReportItem inside a grid [message #247059 is a reply to message #247044] |
Tue, 10 July 2007 00:28 |
Member |
Hey again,
Looks like I'm not entirely out of the woods yet.
I may have sorted out playing with the data set when the report item is
embedded within a grid linked to the data set, but now I can't seem to
get something similar going when the report item isn't embedded in a
grid but is instead linked to a data set by setting the items "Data set"
property.
The onRowSets method is being called with a valid IRowSet[], and the
first IRowSet appears to have the correct total number of rows, but the
same expression I used when embedding in a grid is returning null in
this situation.
And the code I'm currently testing in
IReportItemPresentation.onRowSets(IRowSet[] rowSets) is:
if (rowSets != null && rowSets.length > 0)
IRowSet rs = rowSets[0];
IRowMetaData md = rs.getMetaData();
if (md.getColumnCount() > 0)
String name = md.getColumnName(1);
while (rs.next())
System.out.println(rs.evaluate("row[\"" + name + "\"]"));
Embed report item in grid with data set and I get n lines of values
printed, embed report item in report and link to same data set and I get
n lines of "null" printed.
Shaun
> Hello Shaun,
> Scott Rosenbaum
Re: Custom ReportItem inside a grid [message #247279 is a reply to message #247059] |
Tue, 10 July 2007 21:37 |
Scott Rosenbaum Messages: 425 Registered: July 2009 |
Shaun,
Any chance you can bundle up your ReportItem project and send it to me?
I will take a look and let you know what I see.
Scott
> Hey again,
> is embedded within a grid linked to the data set, but now I can't seem
> to get something similar going when the report item isn't embedded in
> a grid but is instead linked to a data set by setting the items "Data
> set" property.
> the same expression I used when embedding in a grid is returning null
> in this situation.
> while (rs.next())
> get n lines of "null" printed.
> Cheers,
> Shaun
>> Hello Shaun,
>> custom reportItems and drop them into a grid. What interfaces have
>> Scott Rosenbaum
>>> can be embedded in a grid along with a data set and have the item
>>> drawn for each row (with it being able to be modified depending upon
>>> some info in the current row).
Re: Custom ReportItem inside a grid [message #247292 is a reply to message #247279] |
Wed, 11 July 2007 00:50 |
Member |
--------------080106000805060500020706
Hey,
Not a problem, here are the two projects.
There's a dependency on a third custom mapping bundle but that should be
removable without changing the problem if you needed to get the item
running inside BIRT.
Shaun
> Shaun,
> Scott
>> Hey again,
>> set" property.
>> in this situation.
>> while (rs.next())
>> Cheers,
>> Shaun
>>> Hello Shaun,
>>> Scott Rosenbaum
Content-Type: application/x-zip-compressed;
name="map_report_item.zip"
Content-Disposition: inline;
filename="map_report_item.zip"
UEsDBBQAAAAIAHtQ6jabwDsgrAAAAGMBAAAqAAAAY29tLmdiaXouc2VydmVy LnJlcG9ydC5i
aXJ0Lm1hcC8uY2xhc3NwYXRonZAxC8IwFIRnBf9DyW6qm0OriFTQoUqps9Tk 0UbjS31JRP+9
VSk6FXG7Oz6O46LZ7ayDK5BVBmM25iMWAAojFZYx2+XL4YTNpoN+JHRhbV24 qjG9jwN0dA9O
CmXMLAkWPMO3DH8iCazxJMB28cJgyxsqOQitagv8KB3XhUdRNWv5Okv2i02a z1dpkv3RVkvg
whBwgotXBHKrfamwc5jxrvaubTsofMFR+P3WA1BLAwQUAAAACAAyUkE2E74H CPUAAAC0AgAA
KAAAAGNvbS5nYml6LnNlcnZlci5yZXBvcnQuYmlydC5tYXAvLnByb2plY3S9 ks1KxDAUhdcK
vsPQvTe6c5HpgIo7RRh9gDS5xgzNDzfpID69SUyVUgQX4ibcc3pOvtCE797s uDkiRePdtruE
i26DTnplnN52z09351fdrj875YH8AWW6xSjJhJTT2T3hTljspbegB/MOESlv BYTBU4LB5MWK
wFlNlXhOWnSp52yeitv2jlWwhRomM6p9QFlUkze5KpyqTjuBJw0oRxMiwkEl kJ7yII6iFpC+
j5AbgvRU2LFptjQ4W1F+xQ0K4V4484IxXf8vdi9f0Yo/gTZn/uWZlybClv4U K/zjOGnjHurH
Qq+hnwqL63GrzjwX4tdbWL66D1BLAwQUAAAACACEUOo2AOqOAlYAAACjAAAA MAAAAGNvbS5n
Yml6LnNlcnZlci5yZXBvcnQuYmlydC5tYXAvYnVpbGQucHJvcGVydGllcyvO Ly1KTtXTU7BV
KC5K1teJ4eVSQICi1GKwfLE+L1d+aUlBaQlYZVJmHlAASOpl5iXnlKakFgMF fV1DHHU9/dzQ
zQABPSxiBTml6UATKnJzsEgiWwwAUEsDBAoAAAAAAIBR6zYAAAAAAAAAAAAA AAApAAAAY29t
LmdiaXouc2VydmVyLnJlcG9ydC5iaXJ0Lm1hcC9NRVRBLUlORi9QSwMEFAAA AAgAJlHrNt5j
am8iAQAAwgIAADQAAABjb20uZ2Jpei5zZXJ2ZXIucmVwb3J0LmJpcnQubWFw L01FVEEtSU5G
L01BTklGRVNULk1GnVLPa4MwFL77V4TeBho6u5Olh230UKhDWuhlpxhfszCT uGeU2b9+idau
g1HZLiHwvl+P96VMyyPUNjoA1tLohNzTefDU6KKEKD0PL7N4nLwwBQlJWUV2 UBm0GwuKZGUj
IqlHzL5TuSklH7DcKCpyeaI1YAtIsefRXLpHsWpZSy1KsM5lZbGBUeQ61new A+jCYEKezZtg
JLMd2doi2MFHIxGiAZQQg4ICL2VVA+UGgWKjrVSwzAeVdtBezV4XNKbz8MFb 3M3C4AezT3hO
C1pI/Qs/pi5euJjkK1NA+Q+6T/83Gqij+ztasP701lHG+DsT04dwOhOIYYtg PThFW3bq9pah
Tcj14R65lS2z/kpTeq5GvjquORt1O6svymX/vhGz4AtQSwMEFAAAAAgAp4zp NoQtHfcXAQAA
3QMAACoAAABjb20uZ2Jpei5zZXJ2ZXIucmVwb3J0LmJpcnQubWFwL3BsdWdp bi54bWzNU01P
AyEQvZv4H8jcZa1eTLrbPblNDzUe9AfQ3SnBwECAmuqvl93ul8YYD41xLjAf vDfzgLw8Gs1e
0QdlqYAFvwaGVNtGkSzg+am6uoNydXmRl1hr5QJOtbf85pRy+iAVpR1jLMdj RGoLOvdkqilg
KxzMQiQMdkF2PxyYp51VFAuwXvKel++Uj9yjs2kxtkHdO5uIZtv6sBoA8ikz w0xWaxFCAbU1
XO7UOw/o0zgDasdghOOprfZsJepo/dvGOA2fccYhH4YxZuTZxN5rko31fykS UroV7D2Vunn0
GJCiiC3OOcWaA3+j1jjGl3g4uBYKm8p6I2LiciSXL04updpD9r/EWyOhP790 E+yPwv36daXv
mI3/8QNQSwMECgAAAAAAgFHrNgAAAAAAAAAAAAAAACoAAABjb20uZ2Jpei5z ZXJ2ZXIucmVw
b3J0LmJpcnQubWFwL3Jlc291cmNlcy9QSwMECgAAAAAAgFHrNgAAAAAAAAAA AAAAAC4AAABj
b20uZ2Jpei5zZXJ2ZXIucmVwb3J0LmJpcnQubWFwL3Jlc291cmNlcy9jb20v UEsDBAoAAAAA
AIBR6zYAAAAAAAAAAAAAAAAzAAAAY29tLmdiaXouc2VydmVyLnJlcG9ydC5i aXJ0Lm1hcC9y
ZXNvdXJjZXMvY29tL2diaXovUEsDBAoAAAAAAIBR6zYAAAAAAAAAAAAAAAA6 AAAAY29tLmdi
aXouc2VydmVyLnJlcG9ydC5iaXJ0Lm1hcC9yZXNvdXJjZXMvY29tL2diaXov c2VydmVyL1BL
AwQKAAAAAAB9Ues2AAAAAAAAAAAAAAAAQQAAAGNvbS5nYml6LnNlcnZlci5y ZXBvcnQuYmly
dC5tYXAvcmVzb3VyY2VzL2NvbS9nYml6L3NlcnZlci9yZXBvcnQvUEsDBAoA AAAAAH1R6zYA
AAAAAAAAAAAAAABGAAAAY29tLmdiaXouc2VydmVyLnJlcG9ydC5iaXJ0Lm1h cC9yZXNvdXJj
ZXMvY29tL2diaXovc2VydmVyL3JlcG9ydC9iaXJ0L1BLAwQKAAAAAAB9Ues2 AAAAAAAAAAAA
AAAASgAAAGNvbS5nYml6LnNlcnZlci5yZXBvcnQuYmlydC5tYXAvcmVzb3Vy Y2VzL2NvbS9n
Yml6L3NlcnZlci9yZXBvcnQvYmlydC9tYXAvUEsDBBQAAAAIAKVQ6ja0nxFr YyoAAIYqAABR
AAAAY29tLmdiaXouc2VydmVyLnJlcG9ydC5iaXJ0Lm1hcC9yZXNvdXJjZXMv Y29tL2diaXov
c2VydmVyL3JlcG9ydC9iaXJ0L21hcC9tYXAuanBnVZYFUBTQu/aX7pYOqaW7 WwFBWHrpllhg
6RRWSpGQrqVLYulm6VK6Y+mWlpJSREC4/u935853fzPnnJnzPPO878yZc+Y8 LT99A5CCVNVV
AWj/4EPjAwCe1gDKABxMTEwsTBwsLBx8nH+DEA8HB4+QiICAkICAiIzovyEj IiElIyUhevaM
iurZMyZGRkYm1v/lPyFouDg4RIRENKSkNHSUZJR0zP8/LP+zsLD8v/m/Yf2/ PH0BkOECRgAj
GGhkAHQyNAwytKcBAD0AgI7xr1nA/4KJhY6BjQbA+SeCSAFo6JgY/2kdEwcH 658JDR3jn4GM
nEUYm4JVUe+ZiI0XJZsS+EPyV1HvwoZZdtuwbRwqceWixgsxfTuflL5L4KuP qaidf1m0aID/
W+e/wzCx/0kcZP/20f+1AUBHw0L7H+lfDQwKYUU9Gy/MZ6wiHwqfVgGE/3GQ YZABXgDuS9ZQ
V+QHto4cYe9HrEVcRRIFE2N5jtpxVEJSegjK+b6nsZc8xFk8ATQ0nCPndTX+ ZvHKF8offJmU
PCH523BVFf8WHvFsZVoOH2l8772vS6+hKoND8gSga+//iZfyFYl0D3iQNys6 jJb0CDV3ente
wMdBAgKrolBUUvgjz9vqUCQmqy6roHf6n87Rg3TL38njeLh8j7WiMiqjkoez vD7CQfcL1GxU
c9ByHOyDhzhcOP0sP6N8ddgO5T624Lwi9YqqTCzj5TFMmqPxOxd8Akw8vzTG zyg77hfXEKvr
2O+dwORX2jaSbMagoo02JoXBV74+0n8V0qhc0yrQ6ER0gM87wJ9DuSp2gbtQ 7tdyGk+AE+Mj
gghxihxV1FwkaH+3VKycZGym21bVPdCtijuTSKwv15yn7wAN7nJslQDN8eCV tk+GxOUzUk6Y
93EK0rmzYS+gQPVsZFYfpDQdT0qSV6XF2gf4sN2tV5h03/UXLMYwPq5dCL2r AP51KIy3av3S
98uQKC3LFvL+mqATNKsnrUUWssRJyUnc09x7jbs2xA4J5qPuMVRnEZD0jtJW 4Z4jao5ndymi
6zZz0C4TFOY79vzJBujzZb+OGcYa5dXgNoca7Gt+TET3CLpWeDdgYXp52pdn Xub+MaEryUoH
n08keoqYvmJ6Cnmr2ZaNJ8BQm9/L95kav/COB6jotVKKkgn4iZFrvOinQZ6G c9GyvCE5UdcF
hoUnVtOnHiNFZ/k/v4EFf/7Qtzr5BCD+/kcV5vjAY9vdxTeW1hOHJtclF656 U0PtRgkjh5c6
AlPSiiBQF8rbl5wWzbH9jPExb8EgSE7RkVmNd27E8CHF+oslcwEBDwz7XC5q HukQUmRNLaw9
as6+Az11nOQEkzvpTQQSxEiTSzVzQoiygK+1M1Dd5PjEbElJOzVT/rBONz7d V2TrocgW/K0z
MzhxE1dvsqHPWlHa0FJwTjd3iwoIN0pSMa0DIxx/T14iX9M7HQRv71MPLSbn FGTj+/mBQpiL
qioIZtUPdFBiQ8dOCaE1/JU53dA33MgtfNktmnysMm5Bg0Mjo9MxIOj2vcRA iJe0pWA4vTbC
KKfy3W99WZ7iB0V51uBuNj6W92k2+jGQiZnUlNAlNYvk0liHvmDSZe0Mw97j uIfwgzmLETZi
kKD4oxd1VB/rqjNrrAMkvb/KrBYZ6+Ut2WXQLXG5v0ZvmZIiMC6sEFH/g+C8 SZfpmGJk0CYV
1vlplW3ETSHaC1FY5tFpZH9U8QLXL+MmG7IPdEgZcy/LYeEyw5s5jFwvMhtz zWKXOVv+lamz
Kn0Dvfqdto8XcWX9cY4VmM6BQzvTVb10QccOe2Ut+G3H/uwFjLNn0PHlgBvt KY/3W10NjxRd
fBzGmgzzL7qF3UXeZWtAGlfM7X6+pr/7Q8k1/ZYZEnpZsNIDICQXOpoOXDQA Sn+ceqgmdFMQ
yWnu2ORf1cs0fwsCqHvkw0LIpkvv35nFVZimRrz23UFPrSm0CKcX2c2pYv7c OfH9ZTQ42j+G
fpOLnGHWmI5kCJAZ+i5XHaw2Eyb6vBqDpoH8GsaSY25ohebkn2l5+YYZY6v7 80qGgURIwYto
KI2DR/6/hyhYbjjORaShoO8urjM4ddaHGxfcqM64YG7Bc6cSfBZquvo4rS7O FYXAk75EKJCV
JQpfELEaaGlxj5ZJzaWq8Uh92N+mzkKmTLmJy+Pn6Pb11aaRlXf5wKRS7pTP s5bAj8CSErJ8
2zsKml3tkVXXuhsK0y1xx8t40dvD2jNtQdU4iQEm18OyABcSXP0j+5L+a365 vZ4fNvILP+a9
X3DV8nZGxM+se5Bmvun2ief2TSHb70cvtRvoWjvb0dBkIzqtVuEkFDsVl0mK btRdQ8sK/H3u
J70HY7u+inBqyWnlkJV+g5QTuv989VxtmG9aw0Ls3hb7sOMwfsev6VQ0ryIN DiqH+xrBAlSq
HlIMJNxTjjdhB+tK61iDzypMSAxVdvNULodzM1JsLT9o05j4dA+67G8eE1o8 zoaWQIkpDSUz
QHBQDDz2ikmii3YqFsO0MrdnD/R5Y+FD7Ff2w4Ap27njOQlOEeJnNiPMEE+R 62gD9cYRsxSU
0uvm+y2a13AlbSt7CQ9POiDr+oeoWTv9L6v0uFxGQb+mKyKMG+JbI1gUTav0 CKAoHXcLM+XI
FR9p5WgikdNKtVf5wA7x/rJLmtC9lwt46A9J7jafOxN4HeQe+EkYkK7388Pc h5S/Gx+nBPge
goLsTLxTx+7QBruiUC1lRo3dl91zqGG1uQbDJr1a0MKswPqYVVlnn4VRQI+w tHoxtZmzW3v8
Xl99hVW1eWfUdrWPr7i14vI9Uf4bItGHnUafhRx19y85B5KfehM8QxjuTBtT q7uBIu0SKSvE
ZBHSD9fRfVtLr++yngClAvLSSXrUV/t0Qjw5uZpfuXpPyyV8iiPvgr/eZhZH vtdAbnIsqoPE
aR92GaOq4WPRabVflUXEJSM4ne9nyWrV9dMiBuxwe7BcPN/9Uc1mP3BBW8So NuEzfZmztovZ
lz8vbfSulz0LxtafmeVpDWjl/VorVk0ID0e5G56YjISvLqe4XQkH/J4lTKlG Ladpdu0eQXeK
SL27o0ziGjq/a8ZytQ0tC7hVezQJjXYgtaLCoQV/VYnYvCd6QHB5R0GUUOxb aN4XYosq4WhO
2Ze2EOs3JbGVJ5K9XGKkXgf+mYGjPfXx1GZ9N/dZow0Apc/plsHkU1JkiVZM wZhWfIvItPHG
g+MBwrCudtzsdyDDQ4adPvyafJgiwg1rpLHqnF6haSfuCcCCw/436Alwp1Sm pTYh1kJP3zXs
xHgS2mnyUFzX/zbgL2MjPFp9Mk9xpALlZZ19N/CHeHNmU4zi+37r6sGq2Ue8 7zJDFm+rLrtX
hHoVRbvOHUNl+2r93yazeDupZvihPwFomPlWViSP+LvWYjd3rFjst5HyatXX e3kg6LBhG6ja
ECJXOMrw/tLAaI5c0QYNqwSh1jCdTjYTQBNTFKoDUhMVWh+zFLQDsiDXSWuI dm7d9J+xH9dp
aWxoDKyKeVy1CVVz2UYbnNMrn9UsWuyYndsQqOMgnVNT7ZqEALxtysZLFcZX YebOB3SM6knu
2vkTna+jiMZcNalcW+gK2Ut1K7LEiI5Gv2ChGmYSqwXDTQWbEqckBubOGE8g xrQ2X3yf4y6t
5uPDJ43Sr2NtbAjXommrvhWx8qfp3zmxLz5Xsk6zYjbHXjqcEp2zrHZvcAT3 l+uawRUl2oSg
YpUh1T8RkHY5o6QALwKz4SkB7dTxpldyjJnrGnCqTDVQxHDQr0/ghQ74Z8RE mFRKYSkXJZKu
omZ0cJdbz+2z4I6m8Y7YSTP6ajqCc76YnYRikQ2E+uMoXMxrCktepKQEyu26 u/fFfhIKy45L
1W/8odGzyJFLpSsvDaFMMOJ8CQVfocB5cPsTuoLgprOQhkJXLDPzAPwSPPPh 8BLI14l+i9Hy
FUz3m+Bw37YHW2+bu1YnnNOz0KnXh8R4GhvBXE41PHpffA8QFElMnjtw9W1T k2ALZ0nzYiEj
7QIdLoPXnPfyMcn9Lgi3QI7112osRzKeNt7EPegGaUeLbMJ4iOf4eZmp3CAl Swl/5W9ssETl
rOJEY1M04JDajSqlf6jJtMsTIFre2aryfkIKydL+Pths8gw1doQt1N+EbM4O ukVMSRCo64LI
8y9fdHSFRUU2qI3TzYHc2ItjOlI7canAz/iCmj6qWQrqlszn4GZY7l/6K950 qFp19Cbq6CaR
nzipbXBZGo/vO1VImDs4sh+DEyqdEw7p9AcoU3QiCrdOtfvBzoZRVSx+FJ1e hNwquD2UT4Ad
Xm5xsXKB+iyebjSNTY6zuIC64RClGbsFbR93vZZAf02SmqZoiW/sG6+uw+a/ PztJG+XMXUdP
J8H3ejfwWDwmWNnugkx3wU8z/1G3FGGrbyPBVviRm8DfEbUgDXkf/4NfeD9v wM6rpkPEt0KL
NhxOYE+J2KFoBepKjgJM/BswAriKS/+dmYGICYNENJYhNtWKMwRvaEcqRkf4 jPOiy0oc/1kR
2MJD5ZI5IUqqHtb0fHkSVvUwUyVW1boh/ASQf57LhbZAFeXMAl/hb6h4Anyq eXGk7VXTzYDb
Am1Ud+OXPfZvy+3zIle7iDt0pmo3BaejYksPSdt7HOtyBT9CUg0WhP3GMTyf ufY2MWGUGIy7
2EP1Y7yhw+vWtX6o4osxmY6dvemgnNJSExv+Cvvq1BQw0Y9QqR2/EN4qVmdb i+pG8IzhKCeV
pSubelL4HBjlQcarC4orlErqGkzUrfU8bn3gNRoWRBZOrV+UWsdj+QO8p0v4 Exy8kWZ+dLan
OAwaXfZXz6WMhYeDCzA5fIjGP/BQY99QRQ4js0vmZor4uztgh1fRZY08m5My LQO7AulG8rpf
R/HnaVhOxSJH5OObned4MORGMXLlalEB9gdUiLYMrZ8YzPzPMikXLTUGaaku fiMbjkK8ZAze
ZbzgmhS3ecmiBg6bIntERjg3xp3IR5srC7+I5yvdxpta6kW+sxJ4kCbRPQG5 +Bdhv0pN+2Ml
4lIGyQcZ5JRzUrfWfENpmXXUbvKGSUMC4POyopVaqTZuHhWkcWkzJ4I8Fs6p 8bntTL9Hhi75
iSetZ86s/31xpHJXliSibcjPpGqPGdWF3uAu8Twce73hhTkLrN4wmFnXROoF GmV08kplWfbR
AwgbiNUvIn6SpCenuaEfBm3U2fp+ktKxCHm1a/6DjzwsF7D/BMj0CTS0+Q7e eVe7Q+to6B/F
cjdseSy05HYt4pSu3hc1c959E3N5wnB2kzfTSCbUSjmNn1ISh5wJOidwHEbU aY7LxE+xP/tt
gKOd9GrZGAjWLNlFHn20543OfeWQn3XiVEMtf8MUZV022aEnLOK+hkADWgAl H2w8oXsnl03E
4zLwH4u4vzE1+EuA2Wd0gdIwpRW2lSSaRpg1iWKAIjuWBMrUqIPSO5Kg9ICw acxtNgKnw+8J
oMo0UVkhEh0p6TQQQeopqLlT6E/bztyrJSkoU2bYo6gcM5jOUhjfi1ajYVdi zPIBEEVHjdfL
eyU9FNRncFBGZ9esU9gMCs4Eab/5jkdGW2vvsEPDg09Tm3sRj+nQIWFCm2j1 6MjLq0GghKAQ
8CznjE27y0wVhJ2tjWRjPhPxrLu9NbySiPcsH2OYedFofvvoaf/+3mzqLjtS 0LY1SYF6+iIq
gkwz9siGmHs/HKixDfaRcku7M2Nd+C42qFog8OM6pNhWR/YZoyKTl24biid/ pT4DlcVq6r63
J2zBZBTbP9h0yM6rifCAOmREN7XreBnXt57Qhc6mjaeaNsGhdHbqSoCtRPsE rtyuHIP+1xFa
LkF/y6dBiqPRgWa7mYPbc1Mc7KJXV03ee2zE7PF2ih2jxi1MZUgKwsa1wHDW 2wLUlj6dXX62
XfpnOo+fMGmtPC8dhQwaNxMDKoHXQiV906PNrXCogcjmz7ZnKbkJydO0ezyF CllBICrwfFyU
KAk0Zu1MFIuAV19KZezl+C7+WDDvW+2GnqGoK+vGWl2nfSXbLDGyk9zNAHYo ibKLZRFn447n
uTQCpy7Xaka3JsPZb5hMTFaGP0XYZc/2jy+feJl6kbYhoUj3Dph/sFYPk6md RaBCkuE1sfAJ
6sULKdVJTYOqGjEqFFi9KWRhOlrYbDBQKllUXV9z8lJglbMzJDlNdzQiF5Fj 9ONowPDMWi3i
dSkF/3Jc0rauosrdFvObvpvcMuUbEz5dRMr5KhoEtiXVy8a8Bj5rNduGCsin O0ZI3A1+GXnb
UXU8IMxqqTr561GvR0GqgDPLs7SkzT+zs/0woPu1/JUZUYdrBxM+2KvM4Fal aM+OU6w0Pmtg
5eKQgCtggxY02XV67FV0mNrPC/s0LMeRc/uQ8YsTB6KfoMWXFlsh5TMmEn/C Al51nLgn1t8Q
EA/hVnC4W70sQXUH04EMTTMzIVkqtl7DuH60O/XzdbL2djJWLTv5ORqXzzu6 bSksypvZKeMX
3DdbV73ZTnDt1Ah3LDO1pIfmS6N/CXCyFPCd4U/lhNptpFuk0CtF+tMY1k0x DOaNO2gpfJPw
UmC/koxFSbDJBuRpkmP6V7RQoQxDXeB0zAeWxvzcAR6ZMpmO3JbgD0KKRPzO kImNnnYVzbQm
kEEx4wdkBGUhW9QJmbPLlMSfTuB7kyXKb6TFTrPsk/LD5Dlt8A0Wtlz+UJz6 Rsoj9QPaDJ+w
UCA72QDuudI4frW3aEaG2abF7E3qYAbXx3Irq2Mi8+dS1lUPtE32N47ZRjUy dZdequn1y/LF
RldBLfLpL18MNNypZnIKRpSF2+yx+fPrlqHDte3S2geP6MGNP04xPwauvaim lwoFlbXMV2rE
hx1RD9LARNeqhndnw8zc+Lby6pwma7CEWVezmTcsWRAJ1U+A1w62fqIiJube D4rjlxR7r6TN
7fZQf7NXOCqq8xdRgcFTl3ZHAaLIvznQrCyvkgp+avJVt3HBn3b0GgJDjcuw +ZtxezEZRVaR
otJgppMAyijAg1yxeoxtS3ixOmP+j6CehldIxKF7Bl/y2IbcN1yR91UIpVsS NHkWXOa6j1Gi
MxDsyIUaNnKGjThruFCDe4UEwL+RiYwZ48qQO7AyfwcbaAm1Sj90SvBy2TsI 74c4m7AzsBMX
UZlSxbRk5wmUMkiCrfww0Z8F7XiNlXc6VohUzyULLe+YYQMpfEK83i6o+WhZ 7qsPbnR47JJm
G/PKqmUX6EM9uW/mzQEQCG4Q9HTJcfrMR03mrvkJELmlBhP9fBPNiSIhdXPI eQIIxwepXwUB
A5Hc7FwX+dnDBt5mRMkS/W1SufbfOy3KvloxCbX0MExXIB1nTzZN1I2iF0Wu YBJLJFQJy6BV
22OTizkWGolkjVQdSpvXCm/vVNTEdiRjTNz2Td/+WCVjH3fC/xVDzTDShcZO 67Yt1bB+364k
zKM8xckJTp4h/EavEi3RwEtd3SpKSd7eLJYmlWYqZdtiTtQDDUERwy5oVLvG WxCc3iCPfLOX
lIj28N4ocgO1328IxubJIkCARyEiXjMGLrVR080Bl0PCRd7nJDQ6mkUiJbWQ isGwXPUvfiND
lF6JFXfaEeYG8y3e4yrz6OrtCbn2YzwLqk3G+fnaN5sJ5v4gOH+E52GC7YR9 dm7pBNHx7HIp
MYPCSdTqlXB+cG7FPC8lD3ja8Y3cx4FW+S0HTkKJ6jRxVSNAq/YP16rgrtc9 oWoLWUOTiK+S
QgySJm6dVYe0B4hAEDgahchhb/IO2Rk+oQvYEYnZZ7e3AnGI92Qir5FWphCK BKlMppEv1sRh
W7jjHYuUpd6W4VT4SVU5ZbGy3n+UFXheu5iX2BFLFEfTGKj0kPIk5GaTgzsv eld/gjxuHSmw
RV3MCjI1UzhjBuNjhkVewOU5Jo2zqscFgtifGx34v4ijk2GhOKN+Fpk9GHiZ mjF0kWSIlDWU
13zzI2s4HL25GfIskd/2cshQ85VuleIvPDgpUj7v68n4NrZueIS2vN4vkrDl 3ibsaUuakEWV
ML3fvXCJwICO9UaBq9szwsdugW3DTTa2DeNwHnW5z3oLnMz6FAg3wMgom2Kl JubZvBE2M/8p
Wa5ddn625pFOJVjx6tMTgEMPnJrlVS1YR3rMTx8wl4YezSMC+ejUrrs0JbHi ZqhtmjeEKWlf
Tepxy1DkG5ACmtQWMBx2tj6tqfJOyf/1B0LxSO9YQ6PPu1HIq9CwIGEQfxzx AUOZJJYj1oFc
I1Xj8HgudPvRi5ZT280HCwpRP+eSWoqE9h6wPhg3jm9jCaK85w8WrVjNFXYU +6/jRc6YhG3A
5wdlS10tMQdB4cp6KBS5emPSyFDgWOsJfs5cXvJB6xtbnyTFSc4JxeKhJnNF mfXsUGjmJgID
TWbbuDukq7BD7tX8WP78gnEHHP9V9uCHel0MjQebzbR8mqGriCZyVMrvrM7a +/GHAUhG8qTr
8vDR2ryl/F6sHW0IGb2BnSNU1iS7sV4qg15t282SJL1hbozhw4104Bh8UjSo JRMa8N7jQfkz
uqBg9Jg4hSjXGVu9DJ4amoRxozg2K/sQyNurP4q0YaLciQWKoc8WHTjsJ5P4 q5rlVfh+1Etp
xSKjHHLDbLcxpkmhWia+rl36FOQO/aBPUHcqmZbB1N9SbXKFP1NULRKGQg9f fS3na0c5N/4M
3R7lW6awQa3M4O9XhZgPDHzGxGdrxKXb++hgDQJjdZ2e90ZH5NVZwyb9Jj1A 7u5v9Gt39YeN
bou0o74zE+DSgfWSA+Yycs824pcRkKAi3dnTsVA7v/5kr4WHD/VxTeL0DmVz rH3Z8woRz9kP
XkF3w3XAwUP7ORkQLgnvW/UG7iXBXHCXjyG40u3cfmPDPWfYNgg2oFbdk2vH A/rNwG0Ms0Jn
0IQ4L9DuyXeWJQtYnSvIbyHO4PquQnF/VZUa9JI3xuuaC85Jt9hGkn9F34QI WEoWzFZXIiRg
jAj2yeqVl/FyOz42eS3NmdKVIhUG12fFXUrg4FpdNXt6JbO+DES6VOCyX6ve olgfMg57VZRf
3SurQz/WbRjrYDEhauV22DGxKcH1h3h5N+8qXZbeL5DvLsRSeEstd1oPWeZG l94sKZajXfLG
Lx73kuGMdutReJyRCUzb9yVLgH88J9xaBxduZqv9GlbWhMUP3NqRiWdeKTLQ qRqpOyLzEqt3
H8a27qRdxtBpnF/Dtjy59KZVsfF1fYual+W2zeFD/Y5QzAX9caEfveOcXZNv BPO9Wyntb8KR
c19e+zEk/YcfWtLSi7yhFND7bCyg9J52nTCOiSu3h5Q20rzIhA1jrnbHrTmW d5fuu828REaF
6AoVeZc+H1vihP0LeqU5iVQHXeQMJOUwFIe6QGpa6MwXveJVVc7WTWY1l6PD EXcoBYH25SIV
OPfUNXf2Wp3MOaNeP27ewvHtXi20u8MrN7GP+MXKflYsuIlLWURbTt1Iw0hZ 0H8XPyOubfbV
JMj9NewEH/u5rFWf6GjtlMRz+24yHqusJ4Cr32vKyasj8rhrKAFX/9evqFnD zNd7h8apHp7X
XcBTkYprvGDZud6XtBx/lFbOFsbRE29eUXgEVsvH9/gj49gNmErm8aBsMZYv PdO8B+zKSPZh
uo368KMKX0nmZkkLuBFOUurxyIHPw4BOyuX5H2HfSA6L6lK3HS9uE78b1VLh YR7T5is/GLf6
5lhEmtyhX89lK0rQFfl2/h5LduLqd0c/i+ak0J2XyGc3/PR0E17RasexnKUW UAzQ54VjSG77
1+I1eiODic0FNRCw50iwXLCI9dEWRSMvlOVtmLlbT304JWzhJ+pu0yZdpbiN x5NXeqffVbq4
LPGSrUAqcGatGpXjbkPO9YWe890B2Wjvgl6Jo0551px59ERSLXkaKEmYNzjp lqZcZU5f6vDV
F+0T2o26CX8dFNdPgSOuIbcQW3YTfM96ILFouMDdSXr9NPpZCnLSVHCM3AwU 7DwV/mcAOV2b
/YsFWUXedIQBFCWfNqfAxCI+huGmfpdZqQwg7JLuV3g/3xJZoJSGX5Hrg/8N igRoB33OPNVU
W2hNFZg412OL1GvIt2PsSMTtBZfqReWE+Du1IC6YTEulAhZmfMnm4nYJ+H7a gUo1NMRl+dIv
kWFSXyaVN+LktsY1RdYpWY4RFjvSllAPAWLTSumSvQbfUV9957ipCcYLT/SI QmM2qtbYYQKy
DJe3PUUT48RjjY1ZLQwANuHAR7KFKPVfN8W2lYZR1pvcOwPwduRwh+Es86MQ hCK/R+Ej0BSe
qfflm09l6kYcj688D2g2wFz708m9Ire26tmEhp8/N26vIE2Xw7x+ozbLYX7N JO/NSlVLn/zi
HKL4Bb+TnbwmuM+hwAj6AuJaRGJTip5ldIZcEYAQugaVnEnDb3z/FqH9Cv0N oZBV+fwMta5e
8OLfBVANGRYcllpO5LrtJl9ic2N7zs21mmbjYPIEGH6eHL9t97NmvjAAhfAs YHmM44D7JrFE
LgaMngv+DCuaaR7OWa/8GvBJGo3k4nDGevbPeq9IRBmatlEvSsRl76zGYlzm dx1RwkcdY/Y9
oNHDLH9L3PVDlMk76chlmbqfNeCsgDvuvPkOD7868QDI2GWPAtXc8AuNox3v KgXOKoE0mRo5
nI58a5q61FJpx55eOuLBphP6Zsn1kW9Y1r+4hgJH2mL9HZzGytpOgHxtq+5h BbWePuVt9TWj
LafzUzcenl3KbwsCBw5tKC1p7J4AzxyBCCADBvKcY/3+JZ7Uy2OfmGGNIcgT oHauwjCrDKNa
fIBYLDXFIHmjefv0alqp9K0j9MCwy61oNSrYKoSDqO9Gpa6bW8cm5tXJB1xX rIkciniLWhvI
Xx6dOWnuJ8CryVZRHuGRiXyOJwDMYpb2r+NeQQ1vJ0QjnXlCimLhxROAle0j 9xpL8xrYeY7V
SquZqrfTM0x8pAB3iSlDzvdHyvxpzBoEl4KCyxWTSZ3qiGauQ/pVyfHUjQOU CH6PN0Wtucij
7Q4xoc/HN6qgCdVQamT6oonaygCbB9evaSh0QBnmdmTyWItgAiGWeK7MvJFL GFKUTe9ongCz
K/cN0oWq8wDT9N7788LYB4ojcGLGwBNASq+GjEUU4g4P0Lab7mNQ4VldTccE cplMmoReYxUT
akkoFXxonpjgXOodDDQTyWiGca/dwyX9E0ixO3BLXk+1oOznHejSpP4+9/nI S2gRZx15swj5
HCjYROxBKSxqwz8rKeOTENeocjX0I5XtlbLsQUpa27sTp2FepKzp2/yB9h2Q l39nS0NEwhJN
TNOEjCxfj/iHrA3P0s2gXVPfuW9UUAEt5rYD9jGEDa9680Ue8/L+KhQBjM7o L3gzwgVOEfC8
Z1+l+k2nO1+op89RxAQO7/jthl5LLmNuUqs2jrt0pwhSdtXEQhzqe3V214aq jafKcX6XPCIo
GZHb7czKYJL2qBYMAK6V/czLdrHNX4sdYhzyVxtMu/uAErdJN9ogLp5hCil3 5MXjynZ6j9I2
bslSDdFMW0QuTtfPHeERsbedE3bwT62U/1HVw89x8HHc8+KW3U3yvM0jpCr7 DoIPzfBMjUmN
9AUsc+xbdxj4RrxontAAtqS8yzEBO0MJQbkzx1JhxC3CJanKHw2BSPCcyA7E RQcCdifRoz1p
CVK0bF03+r6dxhme+tgYOyNTGGqvkYg7LZV0rxPlI2BYegvds90e01/JMgJu L5U/esktVhzE
vs182QH2hIwMNXJEJadpOXsBbbig+AOh/EF2z5vL/toZisE1ypA4gI1YzC1W mZdTooZntfAc
bEXqPYR5l47idkBbxaxy9fS8NRRhC9iDe7vJTUfHDD9H7bd8zR/USoeEvXTo O1FY+HyXZJi9
OcUicOOYc8atQye83SXnVfGXpUQ3q6qRhyKBm2hLJTcKrm2l0a06XDfP5e09 SryGq9UG6LHU
VBlCbdlQNNMzl2rwVXswjfWfkDxn0hJD9xrzk8i+Dr0fyw7DUxBukb2bskSB RMVW8PtRCXw1
kcRiiY6kdDTdz1NDbyFqqyDNXyrDpRntGS7s62uCNONyfHJeFJZZK0tWmruC OPMUDmsEEref
TM5qe5NymNk5DuPmrz+5aeW6jh1+opiWCnnlKIaSa26RPO0In5DxbFOf5D7O nFI16EsvWE0/
vtbstOHimd85fx73YuDMEcF9zeJd55+WjjF9SIFQKgZVFApQFsoiLSQMOj2v sPuTwtzKJIB3
PH3raIpuhajWtthoEEX5dbxEhX5y0Zj2rEWFpi351W1fjuXcF9n0268jJ4YN 8J+9TTSXpDWz
jR6BPmp/Xh0G2u053fiBDPFN6ro7qSNMK1d9a7RA4f7jW8rEQWiMthD4Zc7W EIeY0Xp7Lvyt
6RSlox+x/0UsfxPxTKVrGQEFAUuE7cZRtCTqohY/X1HgzsoGXjjoTuYmOOwh pf9s/QkQQYjK
UmzXe+ewSCBJ69vlJja0h3L9S2XT0v/DuUZOgRTGZwBcE+NsRWZl+E/EpiSO wL4q8HAla0+n
FSLGMGvkIMNRvr4nZBDoaUE8heh8q/26xmu69y25EgrfI77mw84gqjms2WYp 5Kt0XB0Wh6Fc
Xd6djoPZ7ulZtNx4kzMvlUb91HUCqjqKinPp/SDrON9X7nJPaqcc+nS7Z8d7 t0kyhzVHSwz6
1u18YB8g3K+7kqQ/oSB0IYxqrnWuXnzFpC7kBo+X7BS/FQ8p0r3SJblON0e7 uZsn1RG8pyRE
x++lV+RlYEo3vqGBUAiifCTL1kpPNgP/vW+bPORROG9Z2z1afHU8ruzdxlhr P0tGVDjDnV1x
JdFF1/rkOi+e5Rk5b+IskMFL4JckWy42NbSyVCmlBRGxaY3P7+Ne2v/5g5XU lL6DVSoC6Kzh
LimU9tbv2WXNW5k/eSyLSyoGrc54ne58ncJC/hpp/vwrJ05viVrohZUyi/Rz 9acvyiucVdrN
+i/I+HxGP6/8inJKmYJG40lcR0/mGlr3GbIT51w+6lMrYInGYUqBKLsPN9Va pzgdmy3L1YHa
7l525wxvHnWxsIP3MWsIMRKTTTCDbX/mkIPIj+vsG1/7rjPoxhralqS+5xSo lFEeSuDNLGfJ
p9hovtiSMhOBrcxPT9U0A/nfC9vqMcJUgqKEt1zWNesK3djhHc05/AE+rUOs htAV4KyFnSd4
1ZprW1tABHZC4m9ri59wKyKg0WWksqjKqgP4bgcy9VXrRuR726MWdyySFGpo A+VGr2K26UYX
p/bK7HM8gVy8bgD0kjLyl3GNw1CkXQp53FS7RUZDphcaFk6nu5Ue/JGn3bdS ZXU236xM2QaX
ga91+rZw80XEctZxlk2/UH3k/nz8svrkTLOi8PP3+/Q+KC1NeX+OzG86OAD1 Y5nBrWgnwhMn
RR7LwSbGGZw4iDDW5PTE20KxOZDImzdmwx2+zb/ixQx2oBlW6fQIbzoIfiqt hXMdUAEsmYob
yE743vW64W7QWWJoEs8gy5AR+QPf2g59dvFIOtNQqAWUJjc039ii9s5wGD2r vaOJmv2P4m1X
nVawzRfdaJE6s/NQ4kzYw7fkyMGZITq5ejpM3NyhfjcWVzw5h8nzL5aPR1GJ fVhyk1hcf/NK
je0mg4MKxz77BOcWcmu4YZZ1Fgg+zxVmZR575oVErdOmhMLp63/asXwXx97w I8LRX2dRZlYQ
MssTzPJWVAxy20oexKe1zYO/WvzzK2zuzfpOu7Bu4/usNOjxx8qhMci8sGRm l9GYtNT9xF1r
GXi9kEpDad2ai0PIXCNeNemhI1MJtd4n0pT8jn+55/OygyVSrArazT3h+AfX oGHMw2+wXeCO
XkOLXbMlIDUtDJb689OC76Fxq7xemTZzHUZ1zyZpqr05iX7et7ayU6Y1iqmw 6+mWOYEkg5Gj
Q9r9jAswj35g1v14i1Ffo5H92hBPkIKZd/AKpWyH1/yOm6KmyY7JC1/bjwyq 34aCgUKPPyu4
qSaH1XRusUOlxNnk606Re+W00R9Evs/Y4oGCUkvoCSbG3D6+k3xnTuf7nsfs OE70XvTzeNzQ
m3LYLUypSOavVf69IvH73XSa5NKgqwgEx97eR++xSb73fFJN1B+VXR8nNWTW 59dRqpeD71oM
tJLotfMduMxQahrAyI3MbD8BrTaiBxZmLdIC5fG/s2QF/c92+briiNn55Slz HeXCIn4C2ddu
fCGleiF9ipMFiOoCIz4/KtqvcqUnBvjOeEA063czh0lzWuQpqZ59HqgZH5BG CdiCtj7xfdQp
naIBvuLjNis1ciHUCOrfptab9HGV6g49OUIyQ7FVj2Q1Q4s4TlcxzeljDYr5 hkbyrUTY/kWL
eW9bEcu9apKL3b4Jjvd99KWE8QHzTZRhY7TZZaV9ebwU/V/mm+yvTYT3+oJB QolXHwjW0Odd
FxhIEYXavFUxPA/fbsgvVYtL9nkWHshZApWI9bhdjFeAnH3P69m+41s+TgSF C9pUyoqzxZL+
sSEN1HL8DA33F4k65ZeJoWSkMtrmlTdgDS4qreSnXV/gmn0kI1k20wRXKEqc nq39+GT1tSSY
BCT5N+85l3xUIX9hyxrRZ5uXtLixrxKfVv4LUEsDBAoAAAAAAIBR6zYAAAAA AAAAAAAAAAAk
AAAAY29tLmdiaXouc2VydmVyLnJlcG9ydC5iaXJ0Lm1hcC9zcmMvUEsDBAoA AAAAAIBR6zYA
AAAAAAAAAAAAAAAoAAAAY29tLmdiaXouc2VydmVyLnJlcG9ydC5iaXJ0Lm1h cC9zcmMvY29t
L1BLAwQKAAAAAACAUes2AAAAAAAAAAAAAAAALQAAAGNvbS5nYml6LnNlcnZl ci5yZXBvcnQu
YmlydC5tYXAvc3JjL2NvbS9nYml6L1BLAwQKAAAAAAB9Ues2AAAAAAAAAAAA AAAANAAAAGNv
bS5nYml6LnNlcnZlci5yZXBvcnQuYmlydC5tYXAvc3JjL2NvbS9nYml6L3Nl cnZlci9QSwME
CgAAAAAAfVHrNgAAAAAAAAAAAAAAADsAAABjb20uZ2Jpei5zZXJ2ZXIucmVw b3J0LmJpcnQu
bWFwL3NyYy9jb20vZ2Jpei9zZXJ2ZXIvcmVwb3J0L1BLAwQKAAAAAAB9Ues2 AAAAAAAAAAAA
AAAAQAAAAGNvbS5nYml6LnNlcnZlci5yZXBvcnQuYmlydC5tYXAvc3JjL2Nv bS9nYml6L3Nl
cnZlci9yZXBvcnQvYmlydC9QSwMECgAAAAAAU1LrNgAAAAAAAAAAAAAAAEQA AABjb20uZ2Jp
ei5zZXJ2ZXIucmVwb3J0LmJpcnQubWFwL3NyYy9jb20vZ2Jpei9zZXJ2ZXIv cmVwb3J0L2Jp
cnQvbWFwL1BLAwQUAAAACADKUOs2tP/40ugBAADJAwAAWgAAAGNvbS5nYml6 LnNlcnZlci5y
ZXBvcnQuYmlydC5tYXAvc3JjL2NvbS9nYml6L3NlcnZlci9yZXBvcnQvYmly dC9tYXAvTWFw
R2VuZXJhdGlvbkltcGwuamF2YZ1STW/bMAw920D+A+dDa7eD0p2DDEO7Ycih G9Ac0xwUm7W1
yZIh0smyYf99lD/Q7tBLDX+J4nuPfFSny5+6Rih9q+qD+a0IwxGDCtj5wOpg 5NXqbrVIF6lp
Ywx8qBWW1nSE437pAyr8VWLHxjt1K7Ev82r1OmySQFcbF/GMjiJ+8+BP98j6 s2b9RvgW+Q3I
hyG+YWy/osOgY/23mnBofrkE5xmoDwjmCbjBgJcE2p25Ma6GnvCpt3ASK7WD yoNxEHPgjLxI
u/5gTQml1URwr7tngU3bWRhqqAheq2CR/lmkINen7zKcYCoclxPt0ZsKvBsb p3xyYLeHMEYK
KVd+Cf4bzUghxMurRZpIf4zEchAqfA+NJiDdInTBHyy2IGs5BrJEQsd6xCdi RD5pwLs1uN5a
uLiYZZUVi7mBj3BTSLIoJVFRlAQnRjX6iKBjNhCyRC4FftKOgT3o6kcv5YjP g3CFVAYz1T3Q
TF1CIFjPirub/erF9nyKoK1iDqkaeY7lxZwZm2iruHfnbd+6O987zou57Mmk JNlyiIN20ZY1
vER8k1D+YSBMTo2xKK6QcjLVvIgUQ+sD0fZMMlzle1adsLF1MROP2vaaMc+k j91jlsH1KHMN
2WO2z4qR+u9UTfzKc7UcJyi/cv8DUEsDBBQAAAAIAKFL6zZAzZrSWwEAAEsD AABbAAAAY29t
LmdiaXouc2VydmVyLnJlcG9ydC5iaXJ0Lm1hcC9zcmMvY29tL2diaXovc2Vy dmVyL3JlcG9y
dC9iaXJ0L21hcC9NYXBJdGVtRmFjdG9yeUltcGwuamF2Ya2SyWrDMBCGzzX4 HeaYhFZ+gJwK
aWkOIaWE3hVpaotqQyMnXei7V5YcYmgvDTXCSJqZ759FnotX3iIIZ1i7Vx+M MBwwsIDehcj2
Kv0M98u6qitlhjtwoWUotPKExT76GidRM+4VWyGp1t5pNGjjA7dS4/IP4fgW 0ZJylq03SJTS
owvDn7JtHdFcBvi/+HsuogvvuY/NYlFXsADYdYpAaE4EPriDkkhgMHZOEhw7 JTrgIY2Ga40S
ogMRkEcEDhaPUGQLaFCA6xSDFmKH0Kcpggy8JUjdTzvnKRuy40twJp8eucaY gM8KjwWURAZD
YYPMc2SDqakr3++1EmO+G+4nZa2N15DLTpn/KLquPhMifSNhMpahkvNp9svD GbEoB4dyNS+0
BL0KGPtgcz8mmPmyeHwN3Z4Kn54TtBhP+9kE1zSw2662cNtHd9OixZD6LceZ AMV+P9HstT7r
pPUNUEsDBBQAAAAIANxL6zb0jyEBqwMAADULAABSAAAAY29tLmdiaXouc2Vy dmVyLnJlcG9y
dC5iaXJ0Lm1hcC9zcmMvY29tL2diaXovc2VydmVyL3JlcG9ydC9iaXJ0L21h cC9NYXBQbHVn
aW4uamF2YZ1W227bOBB9rgH/A5uXSEZKvTcICvSGFtgsFmn7ATQ1tthQIsGL nbbov+9QJGVJ
VtO0BmxL5FzOnLmQmvF7tgfCVUv3W/GdWjAHMNSAVsbRrcCflunr9Wq9Em1Y I8rsKXAptAXK
lQFqfOdEC/Q/6feiQ9GqWhD9umMcZcEqb/DhY4tu34LlRminzK+07NHRvWG6 EdxGnesJEGX3
gu4Ma+GozD197btawhvVOXhwPejB6ld2YLQDR2+Z3CnTQv3l7p93Dxy0E2qC epBEgZO3ftU7
IekmGt5s1iuyIZ8bIC0THdF9+IRLZi1ximyBeAs1wTWHMjXYe6c0DUrVeqX9 VgqepG+ZjuQR
hA1dbUl8Xa9+oDh+qiq4sQ0zvUHrWIccxj1txIE53HXMocWTLZ3zkW3cJfLJ tqdppp93I4fE
TF4Tl8v+iAiJecM4YrwhHRzJB2Yb3CjKk/eervCJlHGFURjPMfc0b1QJUKRm CKQo4zpy8cx6
DaY3+yzxfYPsChsWnPmGv0EqSE/xo9g0ProHF5+Ki98UPx2QZBP2okfwE7+c Od6Q4lZYK7p9
FhjqijyUj2HqvJTJUtj/ucyWsKQF1yhMvSWcSYlF4LWKGX6BHDDuQk7Q3zKV ByXqkC/jikmH
hCyE/xI5NOpoyYB7xjiNyln8+o/hHhuIbZAh45bFdtBQPwpZ6b9HjLpPAXwH zpvO9uiWO2yO
7azTsJbewo556ca1anrDpzZ8GgJnsI7Izqh24Et0l3aondS8V4O2MuTyHr5d ErEjnXJkp1Dg
ceSfohOEnQs2rhRpA82N4pgNhm0u3iF+Oo6fjqymBiuXurPnpkjGnsdWKMmr PJvQSsIUwJCX
AdNTew7Kc08n9Sel4be0T3mdUbRAwVlZnM3XhKvaLGVsdlwGD7OlnLsOz8KR tynteKLF4pYy
PN6QeeYy3PD8rkPl4qKKwy6reyPTkMe34mTsKnq+ntI+A0m5ATw73mN1B220 dTZIl07naUbx
GLKN8rLuy71hOES6x71iMKlY5qRl95OiWKB+IPwXNM/zU58eZ40yRzCwVlVq 61i6LfBwmNbx
YMWZZ7BacODXwTNeLdJ9IpnI7pP0DSn613J0LAfHxUmj94fjokgaqftGHGdT 9Tx1kYQhzSMX
2o9dXMWtIb0pMyJd4Zb47kd+LTBQO2kYrAcMyYFhgU6BqEZeD0x6sFiwIgkg NiJow+y/OPjx
ZRxVMTCD97uwW9LBXwY6ss0lsFgiCW7oevz7H1BLAwQUAAAACABSUus2YQxI wQcJAABQHAAA
XAAAAGNvbS5nYml6LnNlcnZlci5yZXBvcnQuYmlydC5tYXAvc3JjL2NvbS9n Yml6L3NlcnZl
ci9yZXBvcnQvYmlydC9tYXAvTWFwUHJlc2VudGF0aW9uSW1wbC5qYXZhvRlr T9vI9nOQ+A9z
82Gv06YOZfcby5V4FSKVgiBsddWtqok9xNPaHu/MOCG74r/fc+bhVwyElfYi SOzj836PKWj0
gy4YiUQWLub8z1AxuWQylKwQUodzDh8ZLQ52d3Z3eIYw8p0uaUhXOjwRqZAH m/BzSYuER6rn
Ec9AWHhc3t8zyeIp3nWwuAiP15odSUnXV6UuSn2rJaPZJtr06uwhYoXmIu88 zJkO724+dqCl
5mkIzHi+mIkfLOd/Mtm168FqiNzxe3rVRBByEbIo5YVi1jGRkCxkXonwGGA9 Km2QOd+yfMFz
pNcsV0g/vRGrS6bpKdX0b5LfMv03KG8MfKpZdi2ZYrmmaMExVexlZpmIWRrS gocsZRnQqvCU
Kb7ITxLBI3YicqUpQF/DKQMnxOCE8JRnVsXfaFq+ShkT7Ir8Du6akexmO2R4 ODURB90jyTsR
fAadqyKl621Qb5gqU70N5mxdsBfwLmmxvaaAfGZC/gJex/4PNNJCro9LnsZM bkNrnfFqOrT3
NURgzznLmTRZ2iy43Z3Jmze7O+QNIbOEKxKlVClSSLHkMVNEJ4xIlgN/aAEk ogWd85RrDo/u
hTSPgT2xuUQ4lIPlRT4nLDePQTKxxUKwWgjIKBWLCc8J9XSxyX4yJjSPnUjL TzluS85WLB5b
eUwnIlbIQNcaU8kAsoQmBRwEKZgE/TJDAG4qaeo41cYQcW8egzYSNLiHYMdN Q0KkmOzuFOU8
5ZETA9Y0632aFSkxTQEUerol7O78Bczgp5B8STUjIIymRCFGBGprcnr24eju 4+zb5+np7IIc
kv29PROcrYguzqbnF7MnqGz3xmhlVAPO0HTrSZEvhjWuNdGhLpg2OXY5vTzD PAtGFgtsGEim
S5k7bgcW/thhsxQ8JoppO4o+GNTA8RYNWIOtKiFgYZemhQzCBnVZYta5q0MS 1PCRyQmYMrmG
sIRgylFRnNi7YIT3wRDrwfbzoeHK70lQs/vXIcnLNAXlBqgZaqjl2l0hZFC5 MmaayQyInL5g
BWaAG9IWqMa1qii+0rTRNaxit57aEQYjo53zsPmOqI4SEvQXM8kW7GHUVPR2 rTCPmZQhZEOu
0zwY3uV0njIskUp7UulNTG646ILmUBUUGjAGDgjqxDGK1X5op1Sl8WN/emDm Lnykn8ivq7vZ
9d3s29Htt+nl0flZlahdXlfz7yyC2ZbbOa4CN9C/fCXSQjAh4FKR1qZRCzTB xxF4Ab0HHHO4
GX6nE4IPrFnwOZkQzRQ225g5Nk6izyDy009eiTCFfNMJ+Q/ZazIGHkC3YiSh S4bdUKywbgDy
byBfwQqAbqfx9xIE+VYb13nj2DibiVQQCyfxy97Xg8ZjvyKRLEYcZTLRwYIq zYwvYnwGa2qZ
5SeizKFqvNp1XtlazmmG1dek+ASg4L1Nj1XCwZ8BCMtN8SELY7ph5HITSrzK TcBkS1haoGsF
Q7Djy+/DIXlrxbwlw9+HX4e2JAa+Hh6rcMSixLRe8RjcfNhup1WN12FGja+l gKaj18HQUA1H
faXf3qbIErtNGzYiL/E9eILXPiraXLewbcHA1jMRLMdGlTHpXQzDu0/TGdTG p4q3N3y5b0NL
VSmhsGDkxQV3WeudlDC+SHTDS3Z+vOgmS/cP+Mkz/n84qjL+OU/t/lOjprOE IuvmrePfAG0r
pNEVnhlq2JI6IntiWW/UtuWbq0PyxN6JOpzaOQEKRXDuhPK1o2HcYAUHJuyi 5hIXi9Oj2VEV
lNbBwAr1N05u757cK9pUwtjFeYxB7YppWM+7AC/uqZW+V2RT4XHts5EZW30b RPN0A+PFfB22
9gQz3VnQDtZ4Q1/bDt2AsoxMVkOxtFt7Z4OolwbW6uyOk7XrLCv0GtKx69Jh tQI0evCApbjn
dofmtpw2doX29trdtBy4AG+MHQ6MfPBWY5XovLaAxRl8nLMV6TwILJfhwdAF DMbyPUw+PInA
esOW5iAjykWCM3hNFGSlvbBrE9n/Zc7BGKp+uEUbjg+gy5rkAma5kD+Q55vd eiQqHSZUXQrJ
jBJqYza6lR0VA50BHSeowbUR3cDar7cwHJkGViGiRgFuXRyw9g7g61d0lVtK 4P7t25HHNTr4
5vGFfw21+ChWTJ7AKQYSHrqq1Ooz10lg5VrNrerVDsGVcYlj4VBq7j7L7OOD 6umjuXr0qpgL
87Fd5AZ4WIOvZ53s0/NFF2/r4Vc4uPJAw73sDziaqukiBz2Nj5turRJi02Gb G1ADx+x+7qm9
wPQj7seX1lyIlFHogS5arYPiqMb/y15uX0+++bu4GGI0uTci5qkXgR/Pha9C 8gR+FUUv8nsO
WnVjGQJCFlR6GEWGuIkcGquHmxGoeFUSK/2awdDSvF2z8MeGbv7af/sjM0jx BA00m7R4VcVl
rRk0s07nbC64MNWam9yY9IUOkwdzcoVbBVyMyCXVSSixs9k+bPcEQEn6UCxv g9N69+zOiDb0
rSfBCjr7+NkX1+Hsv9dnsI7Nvt2cHxve/sU3WQBLSwEDzENtLdrp6Uv37uYj KWUK6OCX67SE
idmeynBzXOKWaa9hzIpSRnCmmEQim+CbsYl9Mzaxb3sm+Dp0AoWDf+H3ojHc MFtQVmNL8r51
WtVF2vbSnPtdYnoVQihj5FM3b9MtMDSrNghDkbRA8YNpKi3QugWCeeXOiDY0 CqrQvEkT9/d4
nFQCTpQNZPAJHDYjlmvJCDoA94AV9HSiIPcRxh9gmlcSwQf2eDHx2/Ov5H24 V88MZKppmu6a
2bGqTBgY3d8FAcDekdUIGOzXLqgavdscal4gjVleSeWhgTEaeSXAK3mK1yKM JV3ZdJxzKJQH
+MOlDHKTJ/as4Ma8nS1uIWr8Y4Rw0wvaHXgy8RRenJWmzMlXyMB8hlc3R5/O z8KYyh/QCOsX
OFatGxbpYG9M9sZ1pn9Gz8Lx4x1534BeGD9bcB8TwH3fy+TnfiY/+yVrsLkA PrRfSTg887Ix
bdYdiIcVV+Ae4JjBZ+//ncicCuU7RB9CX1n7WllJ7lfqMfGjBBl2TWiFTLTN 2Hxl02NQZylH
GWGUVgY2A/1sllQcjPM8Gf45NQxnLSpXVOMIcOD3f1BLAwQKAAAAAAB9Ues2 AAAAAAAAAAAA
AAAASgAAAGNvbS5nYml6LnNlcnZlci5yZXBvcnQuYmlydC5tYXAvc3JjL2Nv bS9nYml6L3Nl
cnZlci9yZXBvcnQvYmlydC9tYXAvbW9kZWwvUEsDBBQAAAAIADJSQTbboorx cAAAAIgAAABS
AAAAY29tLmdiaXouc2VydmVyLnJlcG9ydC5iaXJ0Lm1hcC9zcmMvY29tL2di aXovc2VydmVy
L3JlcG9ydC9iaXJ0L21hcC9tb2RlbC9NYXAuamF2YS3KQQrCMBCF4X0hd5gT zAVcuxTPkExf
w2jSDJMoovTutuLm8cP7LMo9ZpC0yjnpmzv8CWeHNR+cdJ8ajWubUU5hCpPW 46HmmSFFrYNR
l72bg8/XdIOMH7RHKiqk64AvUUCXaITXwDp3+kP6HHIL0xdQSwMECgAAAAAA hFHrNgAAAAAA
AAAAAAAAACAAAABjb20uZ2Jpei5zZXJ2ZXIucmVwb3J0LmJpcnQubWFwL1BL AwQUAAAACABX
UkE21Ryc0qUAAAAzAQAALQAAAGNvbS5nYml6LnNlcnZlci5yZXBvcnQuYmly dC5tYXAudWkv
LmNsYXNzcGF0aJ2PPQvCMBRFZwX/Q8huqptDaxGpoEOVUmepyaONxpeYD9F/ b1WKLjq4vXs5
nMuL0+tJkQtYJzUmdMxGlAByLSTWCd2Wi+GEptNBP+aqcs5UvmlD750Avb2R o0SRUGc5JY/y
dUbfSa6xI7WtGXAljQN2EJ6pKiBv2nW2KrLdfJ2Xs2WeFX/YjADGtQVm4Ryk BbFRoZbofql0
8Cb4zraX+ITj6PP7O1BLAwQUAAAACABXUkE2C/B09vcAAAC3AgAAKwAAAGNv bS5nYml6LnNl
cnZlci5yZXBvcnQuYmlydC5tYXAudWkvLnByb2plY3S9ks1KxDAUhdcKvsPQ vYnuXGQ6oOJO
EUYfIE2u8Q7NDzfpID69SUyVUgQX4ibcc3pOvtBE7N7suDkCRfRu212yi24D TnmNzmy756e7
86tu15+dikD+ACrdQlSEIeV0dk+EkxZ65S0zA76zCJS3YgTBU2ID5sXKwCYU vAZLI4ctuNQL
Pk/FbdvHKvhCDROOeh9AFdXkTa5Kp6vTDuHJMFAjhgjsoBNTnvIgj7IWgL6P kBuSzFTYsWm+
NARfUX7FDRrYvXT4AjFd/y92r17Byj+BNmf+5ZmXJoKW/hQr/OM4GXQP9WOh 19BPhcX1uFVn
ngvx6y0sH94HUEsDBBQAAAAIAFdSQTb21xoqUQAAAIYAAAAzAAAAY29tLmdi aXouc2VydmVy
LnJlcG9ydC5iaXJ0Lm1hcC51aS9idWlsZC5wcm9wZXJ0aWVzK84vLUpO1dNT sFUoLkrW5+XK
Ly0pKC0BCyRl5gEFgKReZl5yTmlKajFQ0Nc1xFHX089NXyeGl0sBFehhESvI KU0HmlCRm4NF
MjM5P68YaAcAUEsDBAoAAAAAAHJR6zYAAAAAAAAAAAAAAAApAAAAY29tLmdi aXouc2VydmVy
LnJlcG9ydC5iaXJ0Lm1hcC51aS9pY29ucy9QSwMEFAAAAAgAV1JBNmGsRPSy ZgAAYWoAADAA
AABjb20uZ2Jpei5zZXJ2ZXIucmVwb3J0LmJpcnQubWFwLnVpL2ljb25zL21h cC5wbmfNunVQ
XE23NwohAYJLkAQLIUECBHcZXIJDcAvu7u6W4BocAgQS3N1dBx/cYfDBBxm5 ec457zn3++pW
vV/VvX/cX/Xutffu7tW9VnevXqv2jlFVlsXFeoOFgoKCKy8npf6XEvxzYaL/ zWmukSZ/yXM3
CfkvmH/hj2ke/ff5pbOcrhsKCjbRPxfq7Hog7O9LUndpHXdJVwsTdxsnx7df bBwsUDjY2bjY
2dh5/Rv4Kf7h9k8NDSdLdy8TVwsUJRMzVycHC3Mbk7cyNq4WXk6udm5v+Rut Z73/Vi12dtXS
9s45W+jFDWMneC5mRgP/RZUlj0rYWRxGsPq2+ItzwgTmgBu0BrcaeG1Ive9C OdwFWW1Kq0x1
TX1A+Q8EB6lHTdyQVlrwlBFWGht+DqEGYDVUPPPQnbrIgRECNoK6QXKM7MMJ TAyAdA7YGoqd
+QQN6CqB6PUDa3q52Pu9DF+wVW53C/b7wGC9seP8F8csiU8YnxUx/pM7yv3l i9ly/A6MBWKl
v09yDnYSMo8bY4h/tIXy/xJMxVyFKCiUlA52XzT+6sBQ12t1KHlob6j2A2RU JDPKZ0bA7WBC
w7XW1eeVtJq6ojyO+KCrkb9YYo033XjriquIMAyiobm+9AaXILjlQ2RamTx3 +nn1n+6qP1WR
8ZsN56W5iA3zP5OPgHwxtWuZc1WoJXhdxOnP1Ebtzpnaaljb8vZM8Bii60zp 5LHCKV+poM0D
xevicLMCdLahoi9y39gs1JL5USW1cOcjJC19h5FvTMrFSpZh2Bn2mrI7dDfK Gab3mknoM5lt
deplxaYo1Y6Sl8rhRvuduW0sRb3WkzUnj1Xl7u6oO84LSk9LVr985TqhpYj0 ALlNPUOtjkJT
SPjm127JzSc0wea5n065oiQMpwXrYW7runY9HzFOz9GyRfZ+rCeQyLYvjRHb pwna5dsu5dz9
jm+2yX/zxX2rAC9iCgvtuy6evRF9zRFzfqoQP6/60NhhIaZNUGC4/1ktKplK a0D0nXWerl5Q
A8bPIlbtIAl36jLAOxlpbutJcpFd8rNnoqBgKezATVQ9MspyBspygn4W95p1 Qm9b+v6oY/DO
HLvZfRmHP45I/PRhiJmiFeYRDm0KrTln+ETm+lOa/ELTdphQOFppBUVTwGeM b1/vU834Uc4e
+Q5XqeaBc1ySGUx6vIl6KZK/8defqbbhon+gMn7zw5eL5gcb/w+/AueMCy41 URSD+Kt210L/
g2BH6dQrOn9Esf/Yc43dIi0u17muX1lXJuWWOPoKFnJENG+T81L89o7j1nTe 4Oaa2FgX9S1Z
4B8+RouDnF+77r54/cp20f13xvt2/8S0F4dW5KXEwszoiTYcwQ2FBfrUUXIW 5K26aCQLpl2O
hLQyzhK80jlyv9NRvqg3h4boeQbfFXrKod181JhsODC9ta9NOXa9OaWIn9H/ ge1Ycjj/goQ4
Np6lHYctbruomoqmHWR66tRMVIzk7jkJtfcl40ZPJG6wSThQKoYBWw/zdkuO ql5xhFycOLqk
cdrhcEaZWcZOrLlZPYi/xJ9njUKN0VByee8nhWgOPrCgfS/CNTxx9MDFsEIs EILTEocmzzu6
4yJ1b7/5RtzVzDIGiZpk4RmDLDQm3xl2Af/E7OC2mvBgkMvF3hU6SH9pFIvC Z/cdvQW/5XiX
o18xh7uOg9ns7bi8WjMnrrk2m+gQ2vXS7Gt3nH7/JZvdtXlyxrzzwYJVrIL+ 13tckyUW/vUt
djKfJEaXZPNCKvha0iSU5ZUbcAwjteIKNc2sF5ZULZ9H00Tmsae6xB/RkPZc unyt5B9zcjN9
jxtpmlIoR6/3XPq2kDELR/qXqTo5a9R2mdWW9W9hnOk9l2B62WRmozg7o0lF tBSqmOCXMlYc
JZQ9chhpXwKZOb+52ViInuhWpXP/cPlJ/SkHaR1ayHGKtpwwxW1/nlmd5/Bm gmwg6NJZs5ge
WpAhQ8j71qAkDUe7pOjm8zf17Gd+kuy99VG3v3aKqzFLUWN3X7YwBGnlxEbs NpBs3bxkSV4l
QY+s9644yvqQyy36oQznTZp4Eaf1F/S4LOIsMnWSnXKOwQWGqdvjY23jupER U0xdHNoT8dQA
uY0TOCXEQ0ObnP8zuxmxImnYqCm7AA59VO+enAMSry27YY1TrCqJcY7nh7HQ GAeSW6vq+oep
tCLG5Buwrr1qiXLgNi0DH2WLwOpXVZ4fl8DFN7NodMtLVOrBR6EYWZ+iK3eW ChfkTBRuguWy
bCcSLQI1+hLT8GRmBzsIXax+L+1HjdEkraP8dJcm3nWqspcynRdMa5Kg6ZRi t7HxJW086Zcj
0vvzSt42Fnvrgd/ywJjVc1IELJHOzlP19Qf6V9p4tZqu7a+5O8moUdZCzsCZ pj7nVeGTMabs
nOCNCeEfOL2NN4a0gHkZrFxnlkbKbRzhz6SkGApO7JtRwrmGrktyD7Y8Bw8/ dNT5XT5FVtOR
mw5gpojY12lQOaZZAAnjuXvS0dRjzS1YJlvw0DTBBW1tBMYUl+SE2S1g7x8F bTiL6MONvcEe
FDg6GWgnvFJBVIAbOH4t6tSfUPzA4N8gsKhNNySK/8y8RZkeCyDXTHQfp/bp PoLAMDjwoM3u
c8XAnmf+aA0GWkxN6WxBcqIl4+ekX/KUqPTSEK5BIDbEEwXCOviF/fU+fQJ8 l832aZQ0i2sq
xIn6aZiInG6qYqQZsyod1XGSBb0KP+fgBQfRM9V84KvNUbMRYSo6GuSiwpVT lc23qDth2RHC
LeesfnJ4Fufj7fYrn76dwJxBKgHGXXkyFqwFq+CVAOVJmNCzSh/1z3ciOdRi Pi/yk4//MAHE
zp6/zW9Pf2XMwEYVMHUFx1pCcZF2SMWlfJ/0oPKasyCy3fmGtAuJkj+tKgt0 Pn83bMqhX7He
IDYBswnEp39QuN+kaZvhsjjHaWX9Tf9LQ7hGtadnAjC49+zbENOVsauj+Dix nb3WQdh8fhV+
6EDYS+WlcXkaz+vso4i6yecnKXP5/cHu5Ilx4YVTSkDrJl2cacZgoECw0+jP 19cl8rPiJuJ0
xjcyI6vYsGN/VEoDU5ayuJBJSfq5sPQPJXLodgfbEhSDH2H48LmRhsq6ZSnV WRg5WJ97loJT
xAK14MW70+rXrxFt1Wk0X1tVbEYWY63NS+PgpuykLmMijiK+Liczbq7BP4bX /a1R5Kp+tuGI
H6TJdhZ8rVWaSLx5qAOynqqMyYawuWC1qQsrjvUd6UUWWmbi9OtRSpaihPP8 pv4c96bpRn/o
z2Uju/IPQW3Jj7gflw8rL7ezabiNt5feyTe1m46gVybSM+UbzsMWeS4diMoL BYJmhC80w6Xd
3uv0fQ9gX8KwNOYbWusawhehkVz1gj+KytYVyIoqwjt68NrYOaWiLCda7xqr o71yBYyJI+vM
n7cihzl4zH+04bb2z+7NNNKrHFsv6hRHrxEFxXWQtDEhsloJqFQwOG5+IV+w C5qrWpaXai7e
MbEXseezEfkxJ0a8QBR+Ebn0jqKB1OyipnLrgx7MDa3eHEt+xvIdMeg3DYNT bWeKtA9YHRr4
hEnby1dlSh6Zlm3JK1hlNPRI6UUqCqOllL/zmWDyE59C+cOcVQYZQYFOXslS SknaZMg5lYOX
ZVOGSzh26JUpxVRJ5BnfGS8pOsmZ9kbZx38KnfOMJr4PwTA/gCXF/XAPHW2+ HYlSzK52q3IP
nRni5JzXwlqu7wltLXhvgyMUS/wb+s6+sc4OTw+h2dOjzWE7mPIsQNI5D+R1 mD0VJT/nQ+1e
HSYATfYMeGVomVhNIGpwy5gvXDe1JVdpY/xwJWU6mKnzx79Leg6fFDsZXXED 1R9r2Ilpi8fp
6egdek0aAIX561IOwOb+6HeoQGfB9snJ24MDFUatFncqRXP1N+of7Hl3vhvm uS8mVtNgveyq
ynlmcVdAPvQyo7WFhDjOjMsjAm+RlZcV9M3m5LrHDSFVNfECBdgsZ35yukO0 U3dwFOn+nXJI
/F30ibTW19mG9GU+z9mXOVFb3zFDkb/eTuFJf8QykwvpfZZtiEY5+VDlfnSL epPmpijxKtz5
JDnc/fNVIRoCI+ihZDhO/vSdfmKcTsbO2LYwkz+w5AK70rs1Fe4r+R1/pIec buPly1/8uTWV
X3xI9MfoXQZJK5iwGj+0Fie+sL0gT+qVPFElynC+lAI3U5Mps/yQn/3Gksaz w2xhDQEKrt/B
G4gD5oJlTWuZ3vLFvE/yfR9PrDd3LxcqqFC5vXPILiYYSyGIEzUlauNSuvlL 4zFAy2vkmxuL
ZW4Z2fCbAeOnYOrs6WLrSV1bpVb6owp5VcrnrL64Zy5ht9GEoKHVkWSgUs/g J+BDz2+gZiAa
9aU2myBGN8oFg9/pgezFQ0GU09ejGu2Kshsn0t+zsI8IBEmFX5THcT+kKK0j wjgCKTgTzpwA
+f1D1R4a/8g2VgmcUfij3vArZw2Hnq8oWZ+wtXPL9QSN89MN6S49zfOjTkzz 90JglmGB/ffH
7DGCaVLf5dyFyGNaSIObFOerL9+dPA9c15UxFBjNVHS1/NDKaZYkv5V+mm9H w2bCMgYUGHeZ
ClvSnPuYREpoY60vkAogduS+8Y7eBASmu3bktLDQfypP1nptczsS7U4HSbry du//z5KGY0W9
2896FsULtFIyqNRdX/p2rZiGx+XLe4sXyoo1pfSArQ13D0IWgQyB398wAFv9 za1yJkWKcliy
FdMnP6dLmz/8GK+T/v6br5eonKxjZluQ3GNnxtXVNTNn7bOy9F4DCb8Xv9YS us0MLb6dVJRw
BRNDPWHKclmybqbuGeu+XTxxvZ43jGXfW8AmLrNhKK1hjH+10zmXueayGe2E Xc8rXU1b2ZU6
JYfMbqleLG5oTNUmhfGT9espYyfogkwFIFvDuCrpTcKN6fLiu2jPFd/TbMIn y6Eu3Iuq+mXU
FzXMPJNac+oond9Q3DGsbm3Y+oU+D3/VZaFVjGxwUNKkOp5p+g3QM8GofzxX 73+Bk3Gb6IEK
00Phf1YZxIK7Q9Mvg6O57jL7CLgqEDRaflU9Ee7Ti69HNs/GP6/DJUUTUkeU /Ba0d8b5hp+0
KHeOwqRyw/34Um8Oyy6K53JFb7HkNlaBp1b65yHCf9I4Q8LeJaLmaKEFyp09 qRb2a+Z5nXz/
zPwlA+5wIQ93pB5WPM9jRuSudSxAneDNR8Tel7A4R0TbAorddH9MeQjTYK3j IncIRlwwRlRR
pN0gM4W4w+TCsJ7SSlIt35u2omJG0Fy4RzblU+qt/MPb1D5vMR+I80IHx5/y yPJfH1t57Rcb
TbKS7czmuCq5P3gNVf0pYfK5Gspa+mlg5l6U3f2pZOngM6EPiG1+Uu25jIKN 3DtI9JxetHnl
kL0TU7K3ybqCZLII/+BWRX+QAInJ3waO0l/j5Wa9U5oY+l9cGGKovcNvAbYV +LwOoy8Y93GU
8gW/a+r8s4P8PZm+XDjuO9K2FfBG53v3dQ4prJ+RBpyiWjfs28DJEd2PfqIc uc5q+oLL3x2z
tK2DMsIfp+G3gzGUvD91XqXhw76WwH51ywN7fvTNr2OdSW7HtBXMf3oSuyqy FWdhja2etLJ1
2fjc9JFGA9wKfBfa/ZR7B3fvJtYFURIryqbOx6Lb/w2g5igsYB61LjWAYTVH qyeRp8CVjdVh
Yye54TuSBF4HulHKkM5+ogIG2EL3WafxVkW1AGqIPknrnc3pipnv5FLS7AEI lsCpefxFX4P7
Xo3E8AFVtN35OWC7lrDzpAR1+Fi1aDZB2mpxuxmd596B1O9Ya0nWosBfJnRP BYYvHZfbSiVw
zXqm1Kb56b7V2OS7qRUgIeeMgc2QC5u95VeVTh/Pk7M2+febHZSVj9gfKi9K G44EOicP0OIs
kdVlhjMefL0kMqffrG6aBin2m+evBxnCnWztr0F8Aqm0O7s3fMmR0ZremtN9 Iw+R09es1pMf
Hmp2BdS9Xwtc/0jmdHrATmHYgz9q2/Rp2j9pKJb2bwOrfStgfFsQl8kYAPTF WSUybPU9P5ZM
zEnzli/PlRljXvA+bdLnO6qOkQTvqFL3KAVlpbo72SrSqgYboZ1oX9p2zllX 1PYAxHCnmMLX
PSHug4Nbkd+EvEdXNG9jCq9UeMceGhMKGg8/br4nL5RWby+5NEs5WP9lO2QX 5PURcC2oaTbI
3BzKPOjCmvfQHTzgNI3AkzdRJB7kyRhiEt4lcs/ofDylO9xjeHMJcmYZs7dy RrxcJR/Lv+Lu
axEinPrw7VPPlH5OblBJLZRZeFdycJpEki23MO5bIXNkFbkghqQTw2u9Geb4 Kn7fI0oHLUpD
F/fBmRemlAErL9V0p0mE2PJzK7/lMntWLbWKxRbhl21fO09o4hhy3NS9btPi cP+HHfjroZOA
5KqzE/KD0an/Zw3NpXznCv72nVMLtyYjF8/BZRIrspo/dDmG/1RXsLJOsvun 60cFS+sY+qCk
TC+9wSmKninNA8PBqSAPT7zGa9pT2L7FhiZO50scw3/o34bUkQgiLsjH+I3n 8VWcf2kVf5tc
7O74SEf5kg/xUuvYX9pqCn7HEc/GcF1leqj09fDjP/Rb4TW7e5qPtsudpbPn P/TvaKQrjv/3
SpKRjv26ZUhCH3SIkjkOFaIwDlpbL9W0EX800NGxe9h66lC6bc0VUUskwqeE fosDV3SNRK2g
lRHLEADx90wpDYbnE65V1ya20vvhfKMbIbSfszjKq1YR4jBk+uOH+IaZr5le ZhfX1xZZX29k
o/+raSH8cEGw8ewFqOmwg06vSKWly2QC5SCu2z+vljY20V3/y40NsiO9bCnB Q/+nZvpl/gzR
Qnitoe7PIxiMZU/j6yHmCv7XQ1FhE4loRONrvWrytn9kKNfpVX/96DNSOsaY UmQ8VNwiCTcN
2jni3Gl2GPaEP3iUW9jmItS/ovHjwbinzcwtqALng39fkueFdV56/BJfO08C hvuLME/85gnR
PbjO/UGbncE0yx0g4GtdJYa/76shg5Y/eP5lsHwsjvb7Kju1Lpv17vz2cPj1 eELhz8uPdi98
M6pYLdwhH+JuFN6I17YzAXZUJNDA4yZl3KjYZIFFt/z05XPvFXoz0GS8VLGo OSgl8YAyU5JH
cVuwZazEHBDUGhuB/bgSauU9/2zIG7KtCxrwtVaCo246hd0VaiGNL4pl56FU MKr2E7pBwqFJ
7WloC6mImoyAmW9CAe+qxLu7OJtRLvJWuhr288OXQoRUUCTlwicOGEPZCTpO kIYEm7N/piok
abhw5n5e7JdlH4WNc6ezNeUuJnUv0pqWV/snmU1APNcB7jxaUXIANA8oBdl+ wrD4YRs3XN26
pRUE+9Mtnl850CH80+eeF5ySJzsFRKaylslSivY5XSL0pjYSNDqrKzaitPch AY8ps7758Fe1
0JmnYT/kxxIozSukStSv5TUbzGjtsRWoRGhfB0NX6rsksI2KmfX7fDrfWFep SKyn7OCrxRj+
SNZYYwa7TbeXb5ZV/GgHTREpTWZy0cDpdB6FV6ZHkO3fIHGckNXTMYBUe/dN jiMKNt0T3qip
Kakmcc2saRPJIt3Qx8mnkXWlb56x1o5kdPLj2+emcgOyYFXXfb82IdsjzS2+ D7KZzGsiQM2T
2bSzkfzZ1e1D46qlTaok5R/mTq17+4KvPOyxmgSPfxB/V1RPjVrEHA4VFfkc dzECmxouMOvW
cEfnOXd7v0Kf10oSI1aoKPsbp54FoEFfbcq5GUo3Ug8tXvhuEuLS82xoqDa4 ottFmeEkcmiV
wULCDGrpOY0mhu8b9nTk44WPlNoV0proM2uzqC26N0lvYZApJvUBWm1PtE8/ id6CayM2PAxj
7/QEirtgaP78sT4bSelbbolpZEVnRWKrt3Fzd8LwBLvjFxlwmC6Ww+KeyLXB wzfhk536I66W
neQp3A5dcZW9S4iHzSbfjCFFCcw090Ai7mQK/1X3GyaeGONTWYXFXbJhv7aX S07S8OtZOhHq
zOmwkfBGl6SXukHlZVIkaWU/iTS/mN6qxcj2mLc4uVBeXDKfWz35kXt5v/Ig O4cJDYEUarim
vqHDZL6P0Xp6FnLbkNCOTZFW7u2Nm+riCQEhcN/iOiV4x075PovVL8Xnm0WK tGl724TH1JWr
4cz2H+WfBVzfTqVcUVc/g1eHpWlFBtx34my8mfcZkLSsMd3x28g2zwjvNMAY 0kd48T/9WMmZ
aGD+1tTVaz3+2I63ZsyEMV0ldHVK3yDYStxgz9HU8mZpZ2hI3iQQUuRwLzQJ mqmH6z5lnQpG
aflAQhWznQplAUSgX8j5xXe3ZO/5AEQXzjH6b2vRJ+d5xIpl6r8Nw41TZApk L03i6rBYxj71
VGg1wN64RxZF127tywm3gxWSpSfUkeQ+gV+CknWfK/VOwfyOG4+WX5hWiakT Pxo4cVDXR9cm
4NirHhCYfc0933yr1LNA/50bVbZFto39nf7Ae94L65t25tnwijw2Y+IuXHK0 fBrQc46uO5K3
r0AREPVqBFlqvOtrfeIHLB/PeHphjUBNZ1nY8Atr8RQIqiR62QsOrdwDkzUa 3veiYkNlM1iz
iS09RTwfcn/WWT9US2DP+nX643q/ANdYkaUh7I7SfD4gf4DlDTWUHzRroByB DS3zhlmTM9k9
BjoH+jUBL+U3f3Yt+hifnnw8+CpwDNyRpTGH26bGgdWKQ6QLs7mxTl62jwPz DMgQR51G+e+N
JISqrZEvy5dfXpWN131do+DgW6LIBEH33ba9BrxNsDc0vpxGeiLZ+uqm2rpj XVhDXLqBLQhe
O0gyAUigME3PAHo1jPw06StkomQTQJFy8PWOe6rmk/Tyl7rGwIIsWuAIe4HX G91T+6BnU41m
WbUz9PqT9yonHv6B7ocV0AtKZIX/7KOy7z4V2yDOqma1TGDR6cw1pCCCrxfL /EbnddXlSIpp
x7mrUPnr0QmL16sfR3w7X69e5n3K182TEIKBP1gkPEiLmpH3TfWyvtnM56q6 YvRdmaDdBDXQ
hW27KrlRT2EJ4ac+RtsfCy7rKCX7xvn/tlQ8lrxqyub4vYukzm1/0y2kgkR+ a7tgla4GXHfV
wSnyt+tHS0KWj54MZH+2d05TmDzhj/vt4H5rjrUJ57LrEL/MLOMxKuIhCzNl v88O4JPP1yqh
0IUbvaAhS5oh1ZUBsYS5OtS9nqldGPidAl/nzux4ZeqLdkwh6hJwVavVhGRq h5QnLng1CApu
5+XgduZcqLQorBdqzqvqqfQtdHwYL8VT/61BWad8KQczLGqdfXdiTXIlf+fJ Q/3Jr17aP78A
eT5ObCvyyFY+9dr4dpVlR8icDHmu4ALxyIPqWveRXG9YhRB2mAp1pLRjlXvp 3WcKLgixdg14
6VWYqkBBTBD8RLda5K9eyb5TjcF+/D2TyyylLRM1yEfSKp376uG+uDWWjm98 bQM63p72aLhA
3/awJxu7aqFMX9hmBXFgtocvqjagcCELui304dn4soLOlNVvHvjdkfOfKcGw xeff4Xgkd5fm
f/qbe83/TArCeXNnIfVtklo5ZhwUOc3npae9CQVCE4XtoVMdrfldZ70CuB6e I+MhcOY1lQh8
2envvWp+nJV+dHNFaVG9PlYcfFln+dDz0lwz2yej5gTpaoVN3/bnLtDn2RtF H1vknXq60YhW
7JtBFhFxuRvr60VO7Q4f7Vsmyafsd19geGt43GlAwKPz84UNyyANrZuLx7Ap QlLAsnP8vlgr
sAvvwhOwzPqsaZVOSqXGBcOTLMHjjItlpeJw5X2IyBM52+pmfS0XA8Qetth4 tLq9Re7kyk++
ds8WQJVSBxf/UIIJnBKaH7g2s0UWqDSHMdfyO0FmJ4XAzmgWnq72GyrbIHO9 bLXtWgmziI+v
VD0v/FVp7GReEFwiRqnTw9Y/iVRB06njcSPGdolbtu6LlVSyPTbFwe3tEDHo JuVXY+AjDkae
6pr60kkjx4t81rJY554tpmG/9zV3hL21oEHUugSvVb+whad1s2AP3qd9zDwo ttDLvIy7smH2
MIFX4732spUjkvHx+KFo4FKqlamRb/cHMrOWCUz1w+6thBr7tQfbRsN3XzP0 RJvP3jg9kdbM
kuvYMpyi2XUPrVSTPrfxnHbaVMFXBtYuYJRCymq2s9XCrqiYXwssHNIYzKDP XRQo4QtZd/d+
1BxEbq/S/vF6IvOf/q3k7mYLSb6CAaRiYoc/SxHZoKCgdDnYSWh45xgqj+OF shOcTm5eEKOE
bRGO9UdWvikj7AipfamtlPVjEtHO+hYDzJmSmTs58pFHZ95fKl9v643IsWVb jKIZwfkRY6oM
AKtsiiIuPvvEGn92tunmWSgejsTsa8Vy15rLRnRZ52Qncwr0CiuaO3O2JgvR UUssgSUioGGK
9tSI+JtXdQZxdwaK2ZaP+t42Z/bAoiJieNgXNxqOO7mXT2ox9gNyNKFLpdJR M9NId5rTu3K8
3URGjRhxvYsXpb+Mdd+ePddBQUEV/ivJl8epMQRKII3mv/1M+n8A75yzZXHS 0LevxNTuutHu
9vJGFOUI/lxC8M7lhSY3ZAVSPzPZqLpOFV3yDczxqPhdNQT5+Z9PiFtXHwA3 Gh9uH/twwuea
aaz+xibofQKPTqueOjwgQLHf00q3kRe0dT07hODADrnSVRTEfra+WYkUxKgX 6RFAe4yaXkTa
dgNy0eBF3lBAe9PJAk7ODX6REORhaRMB+LkqtLWKc0gz9Yhj7Y2wo1l8Og3i RJtCIiORyH8v
0v8z7hfQ3sTVXLp9ie5BQcFq/G89Bmm3/du2/wf4q8fcuKRVfhwZDbk38rRM 7+OKE18ly6jL
OSZme12fY8uN6lZTrXpz5S0cRxVjEv1ESXx8cCOPNPnv5C3fFYRErEKGE2iQ VO0MmvF+GdvL
Dxfb/U7d1cbdiD/QlS4ruLbAH5z+p5AO4M7dRTqitb0pfsGJIahKVhvXTzQQ trS48BlxjrQP
erw5Am06bXbBYVf740GPP+/IGquvmD6yTe2Tg5OU4QZVK8DaFaeHFM9cfRs9 44VaE+DnqVwE
m+BDEAL2AOK9VUGytqbiJApwmgLAXxAjrzJBCHuyG7upD4Bm4pVn+xR3p3vG nFf31Yd7QI49
iaBGnCS3RhKo7t4wz5Zol2CkKMqYmQjH6fIosgKh8uAFwTn02TMKKmd9C1pp YoFP6Ixu+qIc
PqXlefRPuyk90IGSNQ1PROWMoT96fO51k4c922hXY25j940dBmxwkOoeOwi3 BhrDSZ0cB5pS
Y6snJl3dDSb8R4cDQ5APS0ZdhcPKW99IjtHjrH8pUpp8eDNFtgZUirx2YoPo Xq0/Uhsc27Xx
3lZ5h48fntliAA+s5HIv0u+62tOh17kw4NJlgn+kTx7Uo2vgU2caDBmJuCY1 QNzUmwD7f8Ur
0cO9jlb7yfbsjuhygYmP7wFThg9oSmCn4liDBPhIF8sq29nmSknGVTPNjtqq 2NhmIC+NG4Ap
IGaKpfUthX3XKTjnBnvJSuct3annC7AauAE/5c6qmWoFByqRl0l6dX66nGk0 tulxU7YbUoVE
87Du3OpyAMQH+BnGTn8KHAmY9jSGIj8LnXiDnSasPt+d3OgaJm/UnwSJNR2h fTotZ8rcdnIJ
kkyHdacAAjZFxYafdPJ7pjZ/XDGwwlD25kaRjJ3aSQDg3WN2XW3H95vBVTLw 48YR+k3M6su2
wTZyT8RQajfwZE8lZyzzRh2RA3roR3ie6isA9MUDSgCscK+7s/3GeYeZhSR4 gLDsiNm+Qnha
N0dAdEepx/6l94Gi78YvampNRD87zj9J1Uz/NBsmLNptZSByF/zarJumKeCy XqnrO3YnSVA/
rN/KymruGLa1+PIQbzgcvNZzwyphdHJtZ2wFmLgqqJYB5BTVl79Fpq2DPNn9 /ZfipymWgkSG
S+W6VYfOV63AbqfNu2zD1jRLSZfyuMPu8LVAMpBf0hX40dGoNCCkCaJ3cI/f 5iOVd5JxDTxt
vuY5jD5CgnVGg0qQ2p4XNyWlKlQUTGfvnmrN2Kcoxz11t1KWBrFxkGC9K4h/ 4Far8Qc24AuW
qZsgZ4Pg8dFWn6mavyVs06NHQmzekWSL21NutzDjI/RmAQCSqlx1Yq2aZ73d 4Ey/c9fHf2P5
GXk/+HYgjj93Hrh+n2+FsvfUPT5Wq+i3B8D5T9WAyY237Li6esCRog3Ju/fP 8ilW14bI7n33
3pSP3j8zDsuFDZPdwww0ELvY/sJVTEhT/5CEwTEwX1fPvxa146fGNPeTSEqT ICKA/QDUSHI3
bZPQ066yYqmTrmrrrzIsnhLPmZANXMJcRiCMVYqm1j67iwpz+wezoF76ZlsF 5uycfaegdxZX
j8Kfdsfyvmb3HhsxcvlOXAHvDj2w8nt/2a8y87Y/bno2nGcLZ0aCCPqro3C7 7PgMkWz2c2YU
+l/hKit3D9OOAZ0g8FVWeDkEO0l2bPMkvhY9CzTg655I2GLkubnHyRQEENJ2 GHK95cmFUTnt
md3R1Ocj5H1PAY9dPxKSVM6hvt7QWL9W+qVh2qcIi1bfT4jfsHZ4LmyObH7w 3Uz1zFlx0A1u
6zoH7NXi9V7vpawVCHnmxzybgNacHASitn/yEkaFiwTIrneersgMlSUaPTLR 3OaGNJ36ylM5
78l2p8Gwq3cVTlEqFnOm/Cb9lkc3LUYg2E9ZsmlBSRycR8OrldVAl+rSTBsP B0uyjBTR7k/d
C4j1gIqqyZOrnKrAPJPTf81YTZa+R0N3NvMF372Gp0tFP+T0YLHyzmcqAoxF 1QnYCE0KSggg
byrcz3mj8wD2OhtsSlrxnABs7tds/r6ASl0gQxIe9FZTLlhd2NIBm/WXIt3H woTjE4FNsdlR
dPDN5YNK5PJBu2jT3LKMHTJ29Z0L4t63BtW1slvt0OmlwNCA6y+W++jzylLH SV19IcqzUqcD
QVSmIDH8FtavoFLWJb7vMEa/KYrazepsjdmz0vXHdrHqvsb9zdt8hT2IAM3h OWyxoHu0JSVI
FF8w37GX64gEjGWsjzT+GHTi4F5j5nDaLym651KM1EA0xCmm3BMMYwrXAcBE wo4/E2aqHWmR
faIiUPC68FUH73CQ0MPucPmNGwx6iFj77+PKb8t7PDbTYDBo49v607EzlTe4 CcAO+t5BRofk
ydvcuvc9GJ5JyAwz6zb8VV9X6I1n9HhsH3XVUZCGPz3MSAyyfKhFCgbS5P8a n1suMkK1L7DB
H3QE87wRqK7/TZanPQwMbDYQerUK8EQ4xmectd+Bk3ktJlxLNmfg3deaphqB ng+liCKjVqgm
jgqfCuORvxDzgwbwSPYGxu0PWLI8o2lATkObPgKGXeMzoNqBQE6g06AyIn05 f+yvNdBACCBB
gebxJuXgH+Cr88WotdFNh1dy33nvTh16dJD6yPXPiAh4YuCU26ddohU0n5wZ ZKJDGPdyk8ra
GYTEX4IaWWkOy7uC3rOB75cxfiB6TXkQq6PdIz6I9XuI5n9v+f81dXwaUCXN CMR/ToP4uDjF
ISZrsJPfvbemMHaxQbDpqqCD/NHoxhm0U8u4WXIFbov/fHLaTNrGnxofyyC6 k6wjtpPegTel
VvGkBn9jWrS14nITn3vl5R2DfWoKZUrpPjlvMR5T8E9LSPKcInu7scYBjl9Q 6uAlsMO0yLdg
5RzOhjzyPOQLZFxTARSM4qXbigNjBK6AtWqQ2irdKpBMK3/6SRAhvjJgP1BI UOSzcAZkdRNR
yHrqjnLZNpDsoyy+QTF8ZNWOkETEvzTYflKG7+iMKRxnuDExHBkpIK0MAnfA nAHZvGcB8/Xd
zdsQplbqNUdDlfYn1w0qI4oJaL1tVGDku+ZzPxrng9adB04Br2DeVMoFtulP lPm+rJ5ngk/M
8GFk0XWdkt+GdgY1POHps25rtR60cuy48efXD82xuGezxfYCCREdROC0s7ym TMqFaiCdClDT
l/mwVxMJEDqHEz+4xYPXzLMCqT0vt5Sbs6OkcsF8Hz/pgsspmD0F53wshG7u +ccDfgUeIdf9
I5rrmPuTNiKUEQJBRVvrPQFpfhJDeXTu6NVHP0De54m7C5VuCTqj3XbVsRoV NFpn2TC2BXC7
x2cRp2McWXj3hfD3hXZFBmRR3bVixZUg/p6UYR3vmm2FZW7mlZXij5Pnvrls 1cxLnfp+8Zmb
VG2uF+uSN0pVuiCXX4Hbh/rtlH4JPt87iqquJn3evDR7MeIr3l26cdN+k7Qh NHfuBQkvrw0e
FsioIPYddfPV7k59kqvKuT691ooy8eZCohSEPr7d6v5QhIKCB/ofBzY55N+7 p/8e/+nAUjLh
RFBFE7u8xRuI4SfA2JGiHDE6OhYFtVvJiwGBCJ1qW1urdhsCIszpsLyMjN6v 7OQ46GH/IlsA
2OPtyT4YmB/kvyMI/QPecSupQLG4h/Yi1Y4eviG4/JEI+P5cqcp/FHP6P1zt bwI/dQU83QlB
avgsnt88ycrMPzXkpeWp3HY/451BVN0Z36o9eqb9SgGdbT7kGn65qth7bvim 06hkvMrqrMNP
1NkWXO57ckqzb7fp0drg5Eedhe/z4g+i2sfiNv4pHxCEgPodss7C7y93oZ3e kW1lbNhSgp3U
R1xSiDz6q+iOVjKLciM5MtCtz3GBDR2biizVjS8sDvgHObz5j88deI4l+OSm ZDFzRaeUCuTS
zacTgXI+teOo5a1iZg9vTmf+ioHE6hu4iUi/yb3mbwiQFi2WJRv5ffTl/L4A e6VujAr0heaP
FWv+ZQAI8ThBUgEL0rJcRB4F5XaETCCOnco0tLxOKX21AmY+7YSxTYuWBYYI a7l6tomJjtEC
oCSaufCHROD45mskhIOsZRBxKPxId3u+V4JIgwdQ7fQ0LYkgZPTf/hUxMLLi Rm3lu8R1oXLm
p4vmT8xnSa1GFkHm8+BOmKITs77BIOtdKZVdO2QP1/xOOygKMvnIGLAOTzjm PXdZh7/voqsH
+E7zph9JzP2etCEbgdwNA64UYfuvJ/mqaHe5TlWM1QKm81E9biHHTq83KbOo M4/0H0XySvDd
7UpGvj/dK/Ugk4YgtAwBbGi3Q1HmbdOunA+jxsOSj1FISF0ZTDDj981RG9W/ lokgPzRjPWjy
yqlXpCWcmZ/1mjtgcDWvz2x/oEQHaO4S4meqiTheJslfdPmR0Pd7quqwZccB Qls+1FRu9XHq
zxWNpoFvM0z/oUFWfH9RhNiolNnV4xLm13iiqLW/AEO8BGuWAJiQWqKVsynX kVNMj9QvwN6J
Ef45aLpHFbMhQyTtVtQ2QTe7OQaDPjZrRmYHmo9zV07bcx9FCIuwe+r7rmmv xxADZ19I0+rn
dEvQGgGulldWCOQYdRbxk3ZOhtviWKcW5bLjw/ztx3ytZZpznQe6/VciyAmZ kTV40B80YHly
UAazfuGb8i2Zm8BBnxdy5QaKGYH/MeApldmoolhr/BuevPXG7vjXeXdfMErv ukmOnbbepHpV
+2tYklU9rfXO5acGMecvHjHVN08JvSZrOJ2QQd0nrW8QEvTGfTpZGh2G7jCx RatoTGH71J1o
Pqb8M3rOjSkLtDEmLQsuBq+qVHCSlaxVZrwI5DOiyui/9ybWQFf0Q06ox1u7 H5osfxSI3Vap
EGDqpSSeYEdq3YMqFig62FTHyw8n6MUOTUW31yL9+uNt5tNrrio1UGrIvXLF hZqFJ4jmZYIh
Rln1UHPbXbWVmVz143ge+PW5TWcu9JvfecbNhPgvrryjG/mga/7IYev6K6+r MfOJWQ+Q1/jI
TUuYJqU8dE8b7JIadsFfeb4AAssXiWLkMmcUXYrtn6biO2feUKoN5m9fj8ia IfQy/sByrwyG
/kwcP8Z3DFBoDhFXnG7mNj83nJh9YLsXPEMejgG5zMFCo+WCVhICI+q5cSM3 EH9Z7cC0jHOQ
1+tyzvIToStLX2Hx4YSkzW9Wp6fGR0Fge8KHx9JxMp9peDxwFpE3uFN/JVKd Wx+umblwS+XD
JZL3lgKZpn/Da3z21LqC5DLUhBuPn59CKG/+IO02DJHVB0GGSFDdf/LesEUG x7OKRm7nu/sf
3TNn2PAgytcckcF52+VT+VZtepO6/sK3HMo+gxX+0nwIu8f/lARaA7itWkT6 stllr4FE94Sz
gEiRuKmkAOX8yf128pCpiIc81Ncw0X2PfW2fSvOKsYqq6llzX8p/bZ6Ph2sG AG3+Htmi5HEQ
DQ0qcOeZbvsT9cSCYCh8FihFYlV+Z9ZlJfwde+KOk7muJfh8eQGOZDjRbiSp 5e3Mc3FcyvfL
w3A99AC/82oRnv1idzP1KZP6xqDAtTity3GfQmXrCbIgqnma8IM40CyK7gug 6JK56iTP5w7i
16H20MeSwGKU6yJDxaYz+OTJ3/Zp8bcV8TaIK+BspGXnmYrqQ9BpAk6g44dd a02MDVluvFLw
PaPxU4Sbo792wBcrem8js5ObFBaZM3hE0/ADSU3/TGUL3lX5TSPz7jds4d4x JB1zANuuphe/
xJS6tTFwDLI349/OxUWL75DuasCnKRDrcLzJ6Dc4k+ucm9nlabG2/8xr+kj/ qeLRu/oET7YM
0jjx2B2/aYjcrAVYCd2ygB03ZzvRVpy8+NsMq+pnQWmIauCmaRAUOXK+C3gc VtE66hB5aNFb
Nr6eGkJSPRXRdXtawADbh56tU8rG2kPI3Pp4kj+33a4buorBJytOQvEEDzX5 Uxz1VnUCzlpG
abKNgaKZ+sZ/67coqzRrQKle55Nw/ess7AjqAR+uQNRakpu79HepIV2gpZ6X nhZBKgav7Iz4
URZTE8rQPIVRT/RMfduq61YxDFDjt1+9UTl1LomvfmFK2uX4PpD0IqCiC2/Y 6dA3jYv8cuYH
roPCLvZh+a6n5tAUwtCo3aZBuQ1/Y79Fm0r8rp2uAeodf5JafvQs6cB2c8x9 4PaUEtsFO65e
EKOoGygtMo3r+2ExYtPlgUnS7HJBF7VRevBvoOWS2VA15qMuC2ctZPbAYcRX MMB/sq5QnSNk
KFn7aLRUWNdtVH1afemyIuJAJOLjr3B9de85WG4Bi1k1gP9wHfmWy43amD9M IxKffemnfdzy
uM4x+/T0PFdIZL15/8qbcuWE2PlJyElM9DE7deTHEfoXg/l4ODO1ZG0KushH SOZouf+PbtmL
z1QqLZJj+2jahg/pJN7xHJ/qMyGNBfgCxtL507W/d3A74Vpwl2EE6m3Q2C6T 5ywjuGy3YCwp
AHjarS+7//zygcqrLCf/fLjtGdXqza4f606Y000n5ZoGlTkozXg8DzIFChtD 3HPuz1MJ2Xyh
z/f6uDnl9RjVnJkiiD6P3lY6PGwFqmxK0UCoFO5iuE2cbtgmrB+3QT7oxekH Go9Xmx8tVjUX
X9Yx5+YsXt60TngZLiP5/muS79sLTsgNgWt21Mtn8rEeiV3MFqWKhuVEkKnF UAiqk7hRArjm
XEhEVr2wHpCDcuR5Wl1LuigkDCW98QltfutEmvBe+ZyDAtwQLSK4WaJ6rrVL gprnkV8k3DD8
Vpi+HNZ9zKVQ7kMs+buFnI3sgTu9iNJ1mMlGpBHxkc1/Kt4o0XBcrVV5OpfD JV62FTOuxEu0
v9VvP20bW1jmz+31ddxUrxYi37WOs9NxecPeCbkUt1Q67F/r0OSU3fSMYcfF 9LTy7Ofc9/Fz
19yvFkGnxxaWtUiShENeLHaMMnvf5Hw38Q3juo5y8ppz/FlvvtrF0+aij+ea AXHnlepVH65f
M3e2dEtWEVfAuleNwS+bV/ID5Q3ganegwFq7IBi6z28gnXEz0tYJI1DKR3Mf v6fK6M9j3lce
ZFGec2wbxj7pk13reZRTI0CwmHJhvAo+KjmM19h67rU8ihFUBcsfPxEFzCl4 AvcFxZsQ1wHS
gs0jU8bljpTMfjMID2S/yGn1dffxmmtBfTbUZTKla6LeUFQUOW4+E0DO3HkP A+6/8VfsiLjd
2bplv0O2c8AQ/9jN8wh7ePM3i+Dmm6qHeCvBiCpQ22XTt9y8r9ogKAvXuMou oLwzCdUwo+uF
gcCTasg96DxwUr+myE4Fifmk/WBzKmtGEjjEtItJNcAqnIfn9avjEzyBy2Ui IA1/Ny+IwfOP
x4XXe63a5ArHNykznttXjHWudW19yJYqnngI5+/OaA0h7ZbvY0i7WGOgwgww 9bqSX4INY703
1/rhUBq4UECTwfBd4NgLEKQgNOsteOVNcdH2Qjj91F+sCX/VrH4A2FlFElX6 oPW45bMzRILR
bvbXiImtpsdrUHtN8ktgUKZduVT1nyMNn4rIRBKOODFu7BMk5ix4tQIs7qCt 0XmV5VfqcMbm
paP+8e2Nl1qITYuxO70vlIUn4dzrTzQQkyDzn5UWnBgbyXBmx0vdO+BB0L3E bUZbwrP8Ly7h
VRqwIBASrR2Bt5l6JJzdD7kPqtSnB4rAgiyR8fr+kUgo/i3Urcb3XBXM9Fr2 cP9wufdPgJ8e
KGKKq7w+05Fv0BZB5vykfd095WW5734HaZHu9gI+bOoPd4KEwqARtciv9oD/ ewTxL3IB3Sb0
m1l+uknqDSRGVtx11g/PbtoQfnVSvPMJF/Vw+t2/aWPgEnOqcO0fgMSEoMzi P/HljWp4eghM
ykLPLn+fVneb9XXR3S0fiTazAG2dLiqvvPxuFyIfqQmiFinW66IUn54/iJQ7 aB8eX41wehgX
38VVIPmXqtP3j/JtnfIA7SsUdXZBG+NSj/ebm7WFd0EOHZFwuBfGvOhNP94p XVVBwO/VcVLQ
bbO0YMWpymqhipAwsgLplgvzycg+L5wPyEZdye6yiwkIfIw9r13wb1RKjoQw 8L+W/EKGqCqs
cGIu09fOewyduIvtvI/UzNz7DYGoZd7CXRnuoJ3nBuCgSgZwsnvOF90WoNfN twnfT1LXJSJl
a9r+c6OBLiLGhV0oPn+6lNrXLsHLy6iTw9D06r3hBDsEqnspxFRDhPPgyb9k thbo06C8Yhyg
Un1uAXpIPUjqXE2424JfuCtu5Wjw5rt8lUSeTdhSWsIbuNLpxo/Wav4GAQsc 2MijM7mzaoQh
NCsFHAO/NXh3pj0+sWG4f10xhoCpCHVxMoh1ne6KBbrLUkzBBNvKYX/Afvvr HiFjiGM+VAeO
7ySHmWqGm6rauTRaYArOJ42q+H1fQ2CJb/6sG00uPGl0FcQ1PWjoCSZNOv+z tu7tNZt3sy64
kiG64vPt76wXXuJHv7f9eeLVSYqC8tznf0Lcn7z/PoD99/gb4mbFOJywE7ww /F++0UQDeO/N
hO3llmvN77MwcNwTd2rHJd81bjKXpKp/Zvong4OgUCji5MTuc8RmWB11huIT 0ZGxhmb+uiPf
/vW1G/Lx8dEtcNyjlFpzkVWzK8jHR2Dpr7dTXXmDfHp6YvvsUeELKELaPAG3 kJmioqKBKyhu
qA5FVcyxnr0eEQtJ9yRTnbpZHhP89Q2P9R7Kr2cBxdqqomMcn92Kv2nbaCHB sCS4sYfChTQN
MgbYEs3mmjPxUNQXbbyTZaWQpm0Iqs3LnJTWpb4ysx+7ZtH/lf8lR5dCrv1L 19/u8JqyH5Bn
Z2cX8dEB3r+gw4p0AeLZbztmd3LuZGF5WlTjfB0ZSUbQANEUm9m8tjpWMOX9 ISLf5gB5KhSQ
p/j5vuZU54x++MuYKpQL/mWDrvpms4zKCll18ZmGZvHBHu8ttcUenAEi8m3x HhAx+cPpCPzg
GHxWa3J3cpp90+nPRx5H8iCaBQcMJ95opn8YFyqHECX8rIQlsF063DXmKQex He7KxzcuQy2v
1RbDYL5+I5fCc+YTR7xH5pmOD0KH1StjyJI6tS60dIcnPz8oz9l7eM/Tc5uZ X94Hr5BWwkPv
r95NGnV9EDmGVf/HTOVpZKyAJ90hFmwPi6knbzNqTAIoJrvsHqHzxo13Po2A CoH5rFH7Sd+4
WWSAA133tewmTMGOtiL75tqOcVzgWBa2y9Henbpx6JsOYqlU66Y/t5+00Tro /gavW3uiM14U
vsq56+NqncpzeA81ErDCzfAToK/xqqfvWBUczzyJ8Ui4tVzMemxTj4AKLnYq MjtoD9+8TtQ2
KqIuHfD9AJXP6Dwv4cwvOs+wdypCAPUomiwBXXbcd9oda8Osh3QV15UvAVps pxlmRshmWigt
gd9rj4nGsQbNX8vXb5abkcTiOTPwJKSshahsAAIwiHwddIdI9NzJ6Xwdf8+F HNUhDrTtfMzJ
8Ht27/ul9Ea8WcUIeDVWMyNKDK0HuOX6JIz5VzVdBG3KMuWr/hJm41jkCORM n8kDRears/WR
890noFDMdRG4OUCDaNxcE65+IB+C3l0z3j6tI+s588vNEMBWKqGbwGQP1ttL poCw7uhx4SbN
e452K/KmPbgg2GTIeccU3MDjl3vPBWVMSAsLsrukdWBwGMtbHkEWceZffxoJ 1F9kCpDdnGoz
TZjRkV5TrAaD4MtPvVnOfenHaSbzYa3FT3zgqxk+ciAULONzy74itvldkYIY cJ2X1gptVLC2
6RQT6brp/q8N+R+ZoZIQ4f/nSBLao4nKiLddForPQUFB1fgfI1QS8e9NzL/H XyO0uG0T9vVV
pBqGCyGGCwGZC8E/N7UdIdjNv2iR316CQySzVZ5OlOynNJLfy/9viWbGhRLc BVEBC4w3ekG7
21SgToYgN8pht6xfw8BTcjgLdL7Tg3S8TthomB0nqCvKHVJnlhZQb+JZOfkk 0hi0wNeNiDs3
bjrx0xI4yd/3zQ14GlrubjOag4+7dUGMkSCwT+AKAHSKDLBY9T0HQVab4I8T UHA3vLv6kRoE
LYeKVS14PeVIL+RTgez+e1CPUPR/L/h/4V4MgPVQ0aK+8tESBeUj2f+od/7i bynqv23/b/BX
vQHMLaeMi3fJcixEMQPvkuTek77+S+mSdN4TvY6Ji42NjWPJDFJ7yjnPyzt6 mEfOR+u5HYlq
+oFe1nyCtH/6cgAO4M1DWalPYh0CyXyNKup/5mw4+MIOZTMisP/alGorBIsA tQmLYjrvfa/X
espybXjv5aS/G+xS0gklLXtdnHnBhaupy16F5NWWd67YNuMR+4VJazUzAPqS qGDtC0uxcRxa
NV9Ii5tB7uoG8IeRhD0HE0yS8DptFh+fed5ulfFcxkf5Hf9turmq5ISxAOnI rKgKOju9fTl3
S4K8AzPi/MQx0et8VZYswXWw5j4ucwtVWO1PmMtL/JlXL5mrM+oi5FICcB4L q3otCpupglwS
WqsCA0P1mT4V8ZiFxfCyLD62DPb0hjrg5VE991ApuIeUCTgb3M/Bhdko8NkA HbDmFuUBQaK8
FKW+7BfOTE0kb0nuBnJYKReoOZ17GPCjPBRcvj7rapg0bt5aOeihWWBryXzi hXFTCQeiRGA3
UPPxaRxThAxvK68vSKiBthfPrk9Ky1I9lLagfgnxTzwjHz5J/FIe/YZNbidI /tIuW7mnwyFE
YAkfBn72sdQjRHPQn7MscvmD0AyEMCS7nKrFUGbbBJTMBMT+oy79QU7bjF3J Cm1ItP2eic3d
xjrF8sftwsuZFp1I0bExyjKicenxwatdJpL0eWF8liPeOzfuwe2eoEWebN8t 0wtA8c/PNBdb
dwYUwq9VKJU+qNAx8u3xbgmWkoq8zP1zDJ/7jqErXgTtC5PDbSrHTFQscOPN nkJTCtM5HnmQ
MNPJpR/+8bmT2P25RfunsTsiWBnwJdcnclsLxlQgYF4YkMvKcfTeOVcFVQQF HuT96g1RLDZy
Bf6SxlD4s3tfYbOWVXbWV395FuG9lrSALZlrPDVbw2mnD/qqJjNw1GheOLkO kW73pPA22R8A
QZmukzVKsEweGYydl287pJKG97PMZYas/kXECy9PpiwgH4CFck/MKx4rDt1R aWv41zqxw8SL
MTtRwO3hqOKKLQS/nkQkeB1/5YNXmF60ja/MF2/0EIKb8PeEIdV2qnf82dLN iQ5X9y9txVUy
L+dBjxvB5XmUooGI5Mj9ta2lyKQ29CMJgcfGnZeR2IvFz/g1K8sVKPEk+z0b bE1P8BWxD/fB
kh3PIME+1S8KscHUcULFDmS22Kqf5l+8zbjfhUjZXZL0HXshCjWR0n19wVw3 a2W9qUlpyfze
J5o9EZ/HYK1uRAlFRDF5BuH1mHiHo/nxzELoARjP3SrJZQh2qdQYqRXkK8+h v3TWs8OHyrBa
ObDHHxHMCgmPZYfmOrE0hkKfB4riIWaY0d7vc0ulZkDNG/gEeT+Jdb7agKjf npadzBCI2U8k
PLk61ji8DykbMgIJTIVDfCVkgXkFaiIkQ46WBHt24VLHdxUWQljCZfB7UpM5 mChL487PvGzb
IYhdFLtEvr4z4+3O+24qlLao4YKk1bsJZzg3juP463GXr6k6QykPLx89gY13 h+TLn7xv5Rxj
n+KcXPM/dwUDeSoue7eQcluUHr9jLo9PojISsC23SklxzkAgk1PytMgYfT2y 14KiwsNKYp+L
BK6fwZ9V7LyfczEkQS1ECRCRiyDFsXs+jeAaGiNv261+OKprc+9WSxEJCkVl eck3NIzeuNkO
Pz0Gu+EOiCbu/uS6b4JsrPHq/5qxSivLwFFXjFuK+1P2QFgJIGtmxImj91r/ xCdJFyjhhxlq
WD2HBdrJ0JzXflaHw5c5yxFkaxcYapFqJtve7Uo6PvxAM70rtfSJgkjkZlyh Ye38BHNQbF17
fbhWiQjtiX0/OBFt9+nscK+DfcoAfeXKOyjxusoT6LKprPcTW5Tu+RBuWHjs loR0xsvMEqa0
0DZ6nyXxAPd9gMTTMbbuqQNjn7a883bIaO1V8CV2i38nZwbzIXzLgLP57u3Z BlOi/Rp/86K7
PfkLyl4xvU8SncFFEPLnaRaXEd/jwtQ1Nm9ChsIcRM1/yIccIewRN1cMyrgm keYDP2W5Wj/E
RXbQlTMBDjuA71+gutFQbr5EM+YRIa4706UcllCnY7V75yKryjptQYR4B7as 7MXs2/6w+JsV
mMJFzXc8vTcxwj+vJJD5OgT47fU3FoqKwz3jj45CcqG9j0PSpBJDtZFUi2b2 3YH3U+e1YNzx
XP2weDY3k3yrFnkSMmlMzn0WX7RZjhUy9xAKwWQ7xaE58FQveuHkGeVIJib+ ftF3WaYDynk/
Ir4xp4vxQUfzsvviw+aL7TQ/Mddb1R+iBEN2fV6xdqDOrkJsuhZ8Ox0yS58k okXpYWjWiPjv
SYk+gT4PJYKa1Q1uVZFW4+dz9smJQ1baCVVLUevKaa8W6NKNHTOjZCHFzmjO 2Cx6EdRESE2P
bN6RFGi/1q/suZqWfXZphSS+j/7NcHLDar9cGB+PjMHRfFP7o6/aEkmBL+12 6DDGSw8SuWDR
c+T1Lw/nrLqVu9svy0XtTlyqTNH3DfpbRgu8u4sr17tf37JmmdMTbX8Uafow 0DNmqZss3G2U
HLbU/NWYN7dsc8Tfmqpl4uQF11KhaHA459vXqm0Ejy5IEB8GCTC+Hhu+gAdj UXbrsm2XyRSR
aPwG+4pddhZSnyZZenX33CZeM5kJVf0oMUFMcXATfbYq/DsyhupZ83Cpg6kw J7GMXIq6S00d
ZX+rTCf1/u49VIeyzSZuL77uVsWhQlYcvk7QfDMbINj08U3XOLEHzoDliyVB KrGxcnW5zE9o
V8uQbzW8fZcdtf288baJ+6ilZgeyKs4qrLgEj5W8VHJks/DHtbEghdzRzwer mj1Tp6SCbZ+H
w7pyv8FHPYWtfON3Yw+fX769RGJyyHx0cchkFUrBlb+Ke4XChwtA26DeUTll 1HXFXTa3GMYC
jsqgj5Hh7me+nH2cKUGmuw4uyaUT0Iz3mpwOD68WHpaIkg8RoLAUprVUcyG/ U0id6mF+b5W+
HBuqQp11cbk4XeJzpggBtISNxG4oVKAnQgc/4I2Uvg8Rwt/pAFDD1SpcyeN4 651V0fi+dphk
RrYcGYmEY4TDR9XBTcZkkbeZ9UwOReHDoj1SXHTUfUU4HcYMuGB5RB/VaKUH /uR3yd4xVvU4
RwKL3erw+jrgNY2bW1rPuSJwQnikko24cYtCnclf0d2Yo/3oqlfY4zZAGktq xNe+7/L9K7k5
QjxmiDImlTEJ52m3G4YZ6mo165WrXJLWp4LX9SXRN2+QU/OLCQzBSZDYzAjG AOwtp5d1Z4KG
hxWlq7ylMtb2XrWRHWKxs75DfrxtqsaZABzUJlzpE4rZdfJp6/qfd5utRWH9 nj8PFMpx2J4k
jt4pzSLqrIV6QJeXj2Tg59O1hU7dJ0xW6s8c3va/r+DpZnmbKh3mDWME/BEk brLq0TxpjCCT
6eDOyzzuefvycIsU87pxs7Vfmjs2BJ02vd4FQGC/9wMj8Va86hYvOp9U17Ph 3E3QQZ36D6Ms
BrJGb9NnRdYlnNmLnZBJ2ffpDrztEa17wzpIn1aacNjz7qcuwUsRBvlI+BRV GP9F8yG5X3um
QzSFIltgeGvC67A+WkTC8BPy064EpGpraWZCXKQs7x7cUaubOY7j7/v85kLQ MoaCrq8iyMm6
lVPHNuR+uEPen2NxyYaLWJzR/6HUk8CSYxCNuGQRV1khODpLsWey/M3Kp/yT uRPArOuyYb+L
hEaBEZ0T6RXik33wh+e+z3Z2Qr7jVg9AdWd3A22i91LDVKtQol0IqE886PkY w19QPmgKSTwr
TLZ/6ytz4g2KR68P+fldKRs6foXN4q9qiaN1u1hwZxeaxJCt3HZjOpHKVvhe Wjmt9Q+WHJo4
yGbjSQ1bJNSDlYbty4GauJRASlHZrNXCqfbZxdYHXT1IlUFw/orJfEnxLk+i SqWtaxn++Mzl
73uPdwK7ixJLvs5hExWLnvYllfYi2GEECdQkoy26p4fDPvkka1087mjwiF+z hNggB+mwEN88
ZtgfKogSRW3Xd9EyxW67YZHvrq443HFoD6fHpbBXbFZw/CzpHlciRE+gaiT5 L0eJTf2CKgMr
fRK/wvKoZKs3Rbu6q2ie6vnaDBSRUVh+MhY1DhyQDdRYP+xn615dGGiKyAWh RCq+Mvr3SWCE
96PZyn3/NHs+dkh8nuP6Xcz1GT3h44rHoBiPm+ThK8mFWoecSxp+OfKwXQvL S0jrkDtO8pSw
6mc95E18jVhYAiTxYWQNeUhV2E7KnavgX5VA9xWPLIDMJN+OUF15B1nAkBEo r0nbZ3eljRoc
ohibrQe6lfrxXFkhrbfkBXSiUHMXHacoBzgAha8LNWRZTRBBFANNGA33qzdo JWw9DxlnLK+G
b2mKultvDJqvJfZfBCSLe8hB1QuLCwjRp56hLFidQH+cv1GiOccuE+aLwlH5 3iw4cjamD3Xg
9TjzvItfHxbiij9oFBmBnXtRHZV6xTpSHz5VI+8fEzKeFxdzOSsgppR+FjeV hJWV+11/QnHH
rnpXiHbt6J71BkC8dRJnbnNZYzohyVt/LVIzJv2y/nUBdSX1Al4ES3AJxUyV yghWXc4te6s1
wjNq/G+EkSxELdIGuVXS+lBCfAfNHvsT7QorRenZ6+POlSPHpeJ33VueR1c4 jQse9W47E6e8
ERzjxF0htOj59LsCFbSez64sbJV7shd2n8kQ/WvsfJK36CjqQ2+/7ATH4mKz Q8B5oZFtlePZ
bOecBpwdR9IX9fvwmaJOJBc8Z0Qz7C5cScjoxQ7CiCRQx6ymMz4Y1QT1zaEn mqzcC49322Bc
jm/XdsogBfiXUABL9DLYNUzkfC0+UieAV1KCQJt3tR0lUWaTrMzgnCvdwY+b 1lAAud1eCVr7
zO149GqJmOfznFu4V+iaEc4fqXyodRl+aNxNrO9daHtT0SacH5m2Ral6kmqY 4ZtLdnHdxtFE
4V2yE0iGAmv8zE9n1vUhBNhFXNVsJuNnfp1Bsb6JRtXW6UQFjRbzGmSPUXNT rd5tJcoyJpkI
mXoLwOTykeAcSPTz70K+4KkvbYkKGBf19nNhNOmuW50JNSkEvAiOn0aopXy4 Kp2w7624474J
LQaGejtoy4Mig2XPqn9JHr6ZvTnlIDomSsZcJbIDqS3CY7lsPltTrLEMI4Mf dx9j3ii0ZalH
QwcHLn6SDPSN3I2ooH59HAFHjNW1RyYI017H6RPktSh7Ld80mQys3Tf91AuO 7/GOMVB398xC
nTXS+3y2bmLAiDpGPaKXqSqdnnCCPH/L8S1ro+hFoXX8FjT31AedHaqBkqhI O+KDN6mGpoo/
kUdwRqcuNldLz11tki9A8IyBcxQ1b+D7VpM8SYX0ML/O6L2868IAFncZcfpH nzy4KQ0w6Pt4
x9wbNroYXO+a9Zk1oSFO9b/6/PMd9Xbn9eK2Ch/w7Kc1JGXhh2b8tRFmqd3z G9z2rJLdUsa9
rgKWkuh8TvIoGIgJKIkBFWRcThTKoFTjEu1EcG8zPX6Ifpg35T0nk+BHhRsU vKKpR3FuvM0a
PS23ED5uO9M4aiVIDF06XWGes3W7GHCODW/B3PwgTP/a3Y8LEFuEWeGvjM7k zEdomjn/LOh8
9wgwb1JssydF3KhtjxmUTIpa2HkRrZOR/6xHb0VUyOM+l6nYzgmNiU57e2RS I8uxyky90/sm
1U+/x03Hk6O4QoAnhtC44k0Fu8IR+W0v+TfCpoVMvhXRPJQvzoU8Ud9blhuK 7d9wlWjA3i3l
Hiued0brJB5HgHPL9bd5HO4K7/Fw2rrVUETeeQTcJQ05A3989I4zvVuIaTvf zdils1Firn8Q
a9ejTXyJaAZWBdpuzeqmrleQkCcVNsy+pwbwfEsrcEB3P/aINnwb9SFeLB66 HiGIx23NvxrW
8qOw3d3jlIyrR+gRaypJpZhDnM31e/fzrswXWBRDhED1jzw9f4+08VObNXpb uue61JyCbe/1
MBlNKs0PxDZFGXyx8l6hh4MUCSqq6ytWn5GdRDX97uTVS5zp4ff/SjHEu/7u 2X6sDirHpnEw
vu8LBgLccxnW39D2mYQnQM2jjtGzK2xxQQAH5k8MoaUJazYF8jwtCYZbDByY p4ojEc1r4HMZ
javQjlGcW/Sh4uMayMSGmp+InTVfZg+Z0n51j5eO2oMzzMATMpkypcKGbPo0 eLdy2Yp1E6fM
1Twpp6B+MWr/TSH9XbYLFf5VKnWMkfba83rrkA4OL/cH6t0CbGsxjGelFTNc FxZENLwIZf/0
ZLKm3t/f5YV8zhOuATRo/O766GH6R7RJ2I8lje9ZaKaqFCubLdLfJbzw/bX/ QX4jUvzYbm2C
jFB9z56Wy+ORf2slxId48wRAbJynPXjUyRQmbio5e3t0q/JA6+rbHW7ys5hH o3bScTGjqD6a
kK7vlTCcm8snYY333R+Sgll1+PHMzWaYZEio2vP9bnrRFv2EDjosCRS5yeHO TT/PQoutFyA7
lX7Ql1F7F8YETTm0i8lG6wR8nPb1VH6CNhYx95rGu5H+hVDFVT9nzIbXaTCa GLalj+OK7+Je
mRv74NBAgvLtWLjPsWUn0uEzplKiLL3AT052RO/gUkKR/nzp+p9IKBulFiXP yMRz8gn36GJs
hg+O7JGw6hhgfqH8YsU06RXmzvUGjVS3S6ch8wa5hfTLtKt043JW1oLMsF/Y KzVmvymz6w/B
wUb33SWKN0Q/XGo5AglPCCQTNyVTkKn3eZIpAoXxmFbKcYR713Dk05uUW7mR 5/wSpHbWx+Dy
z73xdHrFrF8ftUKcSjOVxk3eCriSE5K9RyE+X2h7habH2mF9bWd9RYNFA5BM ed/88sko/dJ9
IAHaLWDOmMRPqroeYbjSlFUE8tIn+onqZU9+BBRqjDVPm3fMAEXeOE0plB/G mT/gyL35tRHO
KPVYHVH9VyZHmPzEWyXILsyYEeUhpAPv9cWbnGTy8wseJl4iOba72wndSY6o lre1auoHsXY0
LI7ji086cp2V6GMxF3hJYWPjgFeiSPIsc8uU56hget76IBis00g6iORzusN3 old/jtw3RvxK
JDMaszsnJCuemX3tPF9mH4vwpOah6u/zFt4LuzYQ0H3WvI40234CTe8FcKyw 874DNdAuJlzn
nwgcm9sLMqTjPHHIvesVllNuekZviD3AA7xL4G0SGKYllT/jEHqXOEp9f67r LQ4EKbBm+NwG
OfhbB9Fk4ZhT4v58Z3gBBCFXT1oxNVs/mdiVW5maenFyV8T9gv8I67FlbX2r hvdnog9FxTyd
dfH5Yq+g8rdXL81lSzPGS5SWESWX+/fQQvmXWveyIvXa90G0qK68R9leM3Jc 17Xk7aRPs87v
LqlAq9/JcFBbC0OL6Kx4P3qXCNBcVIVD7PzkEquEtRPL7jDP1iRI1TbjVMDd +EpazwkfIvwU
rG/zjYQnZIJIYrRxqYT3GhV7Iofhgl7v/WucdINz
FUDForum. Page generated in 0.03941 seconds
