Home » Newcomers » Newcomers » how can we work with latest code from CVS?
how can we work with latest code from CVS? [message #246828] Fri, 25 January 2008 10:10 Go to next message
Originally posted by: NOSPAM.xyz.com
Hi there,
recently I discovered that those desperately needed latest examples from CVS
(GMF examples)
will not build anymore ( btw, how come examples do not have versions? ).
I assumed that they use a lot of new code from the platform, GMF, Ecore,
SWT, JFace...
Then I decided to download all of these form the CVS, foolishly hoping that
it would
be sufficient to satisfy the dependencies and there you go...
Now, what I understand least of all is that freshly downloaded classes
reference
other classes that are supposed to live in the same (or nearby) package (!)
but those other classes do not exist ?!
Just one example:
org.eclipse.jface.text.CursorLinePainter
misses
org.eclipse.jface.text.BadLocationException;
org.eclipse.jface.text.IDocument;
org.eclipse.jface.text.IRegion;
org.eclipse.jface.text.ITextViewerExtension5;
org.eclipse.jface.text.Position;
How can this be possible? Apparently I am missing the point badly here...
Is there any info about how can one use the latest from CVS?
Thank you,
Theo
Re: how can we work with latest code from CVS? [message #246833 is a reply to message #246828] Fri, 25 January 2008 10:28 Go to previous messageGo to next message
--------------060006020600030805050402
Theo,
Someone helped us write this document for EMF's CVS:
http://wiki.eclipse.org/EMF/Getting_Source
Most CVS repositories will have branches that allow you to get older
versions of the source. I extract GMF regularly though not the
examples. The problem below looks more like a missing plugin dependency
kind of issue...
Theo wrote:
> Hi there,
> (GMF examples)
> SWT, JFace...
> it would
> reference
> Just one example:
> misses
> Thank you,
> Theo
<html>
<head>
</head>
Theo,<br>
<br>
Someone helped us write this document for EMF's CVS:&nbsp; <br>
<blockquote><a href="http://wiki.eclipse.org/EMF/Getting_Source">http://wiki.eclipse.org/EMF/Getting_Source</a><br>
</blockquote>
versions of the source.&nbsp; I extract GMF regularly though not the
examples.&nbsp; The problem below looks more like a missing plugin
dependency kind of issue...<br>
<br>
<br>
Theo wrote:
<blockquote cite="mid:fnctvt$3j9$1@build.eclipse.org" type="cite">
<pre wrap="">Hi there,
(GMF examples)
SWT, JFace...
it would
reference
Just one example:
misses
Thank you,
Theo
</pre>
</blockquote>
<br>
</body>
</html>
--------------060006020600030805050402--
Re: how can we work with latest code from CVS? [message #246868 is a reply to message #246833] Fri, 25 January 2008 14:46 Go to previous messageGo to next message
Hi Ed, thank you for the quick responce and the link.
I am reading this doc now, it is informative but a bit off topic.
I mean, if right now you open org.eclipse.jface.text.CursorLinePainter from
the CVS
you'll see that it tries to use org.eclipse.jface.text.IDocument, Position,
IRegion ampog others.
None of these is on the CVS in the moment !
I just don't get it. Maybe the answer is obvious, sorry...
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fncv6m$cur$2@build.eclipse.org...
Theo,
versions of the source. I extract GMF regularly though not the examples.
The problem below looks more like a missing plugin dependency kind of
issue...
Theo wrote:
Hi there,
(GMF examples)
SWT, JFace...
it would
reference
Just one example:
misses
Thank you,
Theo
Re: how can we work with latest code from CVS? [message #246873 is a reply to message #246868] Fri, 25 January 2008 14:55 Go to previous messageGo to next message
--------------090808090404070004090702
Theo,
Since I don't actually understand what problem you're specifically
having I can only point at general information:
http://wiki.eclipse.org/index.php/CVS_FAQ
I can assure you that the things you are talking about do exist in CVS:
< http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.t ext/src/org/eclipse/jface/text/>
So perhaps the issue lies with the way you are extracting from CVS
because your problem sound like missing plugin dependencies. Perhaps
the examples themselves aren't properly committed to CVS. Without
details, what can I say?
> the CVS
> Theo,
> issue...
> Theo wrote:
> Hi there,
> (GMF examples)
> SWT, JFace...
> it would
> reference
> Just one example:
> misses
> Thank you,
> Theo
<html>
<head>
</head>
Theo,<br>
<br>
having I can only point at general information:<br>
<blockquote><a href="http://wiki.eclipse.org/index.php/CVS_FAQ">http://wiki.eclipse.org/index.php/CVS_FAQ</a><br>
</blockquote>
<a
href=" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.t ext/src/org/eclipse/jface/text/"><br>
</a>
<blockquote><a
href=" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.t ext/src/org/eclipse/jface/text/"> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.t ext/src/org/eclipse/jface/text/</a><br>
</blockquote>
because your problem sound like missing plugin dependencies.&nbsp; Perhaps
the examples themselves aren't properly committed to CVS.&nbsp; Without
details, what can I say?<br>
<br>
<br>
Theo wrote:
<blockquote cite="mid:fnde5u$6so$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed, thank you for the quick responce and the link.
the CVS
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fncv6m$cur$2@build.eclipse.org">news:fncv6m$cur$2@build.eclipse.org</a>...
Theo,
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/EMF/Getting_Source">http://wiki.eclipse.org/EMF/Getting_Source</a>
issue...
Theo wrote:
Hi there,
(GMF examples)
SWT, JFace...
it would
reference
Just one example:
misses
Thank you,
Theo
</pre>
</blockquote>
<br>
</body>
</html>
--------------090808090404070004090702--
Re: how can we work with latest code from CVS? [message #246876 is a reply to message #246873] Fri, 25 January 2008 15:46 Go to previous message
Ed, for sure it is not your problem and I do not want to sound as if I am
blaming somebody.
Still, out of curiousity, open that very same link to the CVS you pasted
below, take a look at
and you'll see that it references non-existent stuff.
Or better - don't, I know it sounds weird but I see it
Anyway, thanks, have a great weekend
news:fndert$bf0$1@build.eclipse.org...
Theo,
Since I don't actually understand what problem you're specifically having I
So perhaps the issue lies with the way you are extracting from CVS because
your problem sound like missing plugin dependencies. Perhaps the examples
themselves aren't properly committed to CVS. Without details, what can I
say?
the CVS
Theo,
issue...
Theo wrote:
Hi there,
(GMF examples)
SWT, JFace...
it would
reference
Just one example:
misses
Thank you,
Theo
Previous Topic:A new console for the new process
Next Topic:start debugging at breakpoint
Current Time: Thu Nov 06 06:06:08 EST 2025
Powered by FUDForum. Page generated in 0.06452 seconds
