Home » Language IDEs » Java Development Tools (JDT) » Java model event delivery question
Java model event delivery question [message #246394] |
Tue, 31 July 2007 07:09 |
Hristo Sabev Messages: 6 Registered: July 2009 |
Junior Member |
I'm having problems writting PDE Junit test for my application and I need
some help/advice.
What the application does is to register for java model events and based
on these events to update an EMF model.
The testing strategy is to do a change and then in the same trhead check
whether the model has been updated.
This ussaly works as the event broadcast is done in the thread performing
the java model change. However in some very rare cases the event is
delivered in a different thread. Can you point me why sometimes the Java
Model Event gets delivered by a different thread. Bellow I'm providing the
stack-traces of 1. Normal event delivery i.e. the change and event happens
in one and the same thread, 2. Stack traces of the thread doing the change
and a stack trace of the thread delivering the event. The event itself is
about an oppened project and looks like:
org.eclipse.jdt.core.ElementChangedEvent[source=Java Model[*]: {CHILDREN |
CONTENT}
TestEJBProject3_1185799757714 11[*]: {OPENED}
ResourceDelta(/TestEJBProject3_1185799757714 11)[*]]
The validation code executed by the job comes from WTP. I.e. the class
ValidationOperation is of package
org.eclipse.wst.validation.internal.operations
Hristo
1. StackTrace of a normal event delivery:
Thread [main] (Suspended (exception AssertionFailedError))
Assert.fail(String) line: 47
Assert.assertTrue(String, boolean) line: 20
Assert.assertNotNull(String, Object) line: 217
ModelSynchronizationTests.test_openedWsProjectSynched() line: 183
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not
available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 39
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 25
Method.invoke(Object, Object...) line: 585
ModelSynchronizationTests(TestCase).runTest() line: 164
ModelSynchronizationTests(VerifyingTestCase).runBare() line: 39
ModelSynchronizationTests(MockObjectTestCase).runBareInterna l() line: 38
BeforeAfterEnabler.runBare() line: 30
ModelSynchronizationTests(MockObjectTestCase).runBare() line: 44
TestResult$1.protect() line: 106
TestResult.runProtected(Test, Protectable) line: 124
TestResult.run(TestCase) line: 109
ModelSynchronizationTests(TestCase).run(TestResult) line: 120
TestSuite.runTest(Test, TestResult) line: 230
TestSuite.run(TestResult) line: 225
JUnit3TestReference.run(TestExecution) line: 130
TestExecution.run(ITestReference[]) line: 38
RemotePluginTestRunner(RemoteTestRunner).runTests(String[], String,
TestExecution) line: 460
RemotePluginTestRunner(RemoteTestRunner).runTests(TestExecut ion) line: 673
RemotePluginTestRunner(RemoteTestRunner).run() line: 386
RemotePluginTestRunner.main(String[]) line: 58
UITestApplication$1.run() line: 122
RunnableLock.run() line: 35
UISynchronizer(Synchronizer).runAsyncMessages(boolean) line: 123
Display.runAsyncMessages(boolean) line: 3659
Display.readAndDispatch() line: 3296
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2389
Workbench.runUI() line: 2353
Workbench.access$4(Workbench) line: 2219
Workbench$4.run() line: 466
Realm.runWithDefault(Realm, Runnable) line: 289
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 461
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
IDEApplication.start(IApplicationContext) line: 106
UITestApplication.start(IApplicationContext) line: 52
EclipseAppHandle.run(Object) line: 153
EclipseAppLauncher.runApplication(Object) line: 106
EclipseAppLauncher.start(Object) line: 76
EclipseStarter.run(Object) line: 363
EclipseStarter.run(String[], Runnable) line: 176
Main.invokeFramework(String[], URL[]) line: 504
Main.basicRun(String[]) line: 443
Main.run(String[]) line: 1169
Main.main(String[]) line: 1144
2. Stack traces of thread doing the change and thread delivering the event
2.1 Stack trace of thrace doing the change:
Thread [main] (Suspended (breakpoint at line 41 in
OnEventModelSynchronizer))
OnEventModelSynchronizer.elementChanged(ElementChangedEvent) line: 41
DeltaProcessor$3.run() line: 1552
SafeRunner.run(ISafeRunnable) line: 37
DeltaProcessor.notifyListeners(IJavaElementDelta, int,
IElementChangedListener[], int[], int) line: 1542
DeltaProcessor.firePostChangeDelta(IJavaElementDelta,
IElementChangedListener[], int[], int) line: 1377
DeltaProcessor.fire(IJavaElementDelta, int) line: 1353
DeltaProcessor.resourceChanged(IResourceChangeEvent) line: 1916
DeltaProcessingState.resourceChanged(IResourceChangeEvent) line: 368
NotificationManager$2.run() line: 282
NotificationManager.notify(ResourceChangeListenerList$Listen erEntry[],
IResourceChangeEvent, boolean) line: 276
NotificationManager.broadcastChanges(ElementTree, ResourceChangeEvent,
boolean) line: 148
Workspace.broadcastPostChange() line: 311
Workspace.endOperation(ISchedulingRule, boolean, IProgressMonitor) line:
1018
Project(Resource).delete(int, IProgressMonitor) line: 725
Project.delete(boolean, boolean, IProgressMonitor) line: 289
TestProject.dispose() line: 158
ModelSynchronizationTests.test_openedWsProjectSynched() line: 196
<unknown receiving type>(NativeMethodAccessorImpl).invoke(Object,
Object[]) line: 39
<unknown receiving type>(DelegatingMethodAccessorImpl).invoke(Object,
Object[]) line: 25
<unknown receiving type>(Method).invoke(Object, Object...) line: 585
<unknown receiving type>(TestCase).runTest() line: 164
<unknown receiving type>(VerifyingTestCase).runBare() line: 39
<unknown receiving type>(MockObjectTestCase).runBareInternal() line: 38
<unknown receiving type>(BeforeAfterEnabler).runBare() line: 30
<unknown receiving type>(MockObjectTestCase).runBare() line: 44
<unknown receiving type>(TestResult$1).protect() line: 106
2.2 Stack trace of thread delivering the event:
Thread [Worker-8] (Suspended (breakpoint at line 55 in
OnEventModelSynchronizer.elementChanged(ElementChangedEvent) line: 55
boolean) line: 148
1018
Workspace.run(IWorkspaceRunnable, ISchedulingRule, int, IProgressMonitor)
line: 1806
ValidationOperation$1.done(IJobChangeEvent) line: 1767
JobListeners$3.notify(IJobChangeListener, IJobChangeEvent) line: 39
JobListeners.doNotify(JobListeners$IListenerDoit, IJobChangeEvent) line:
112
JobListeners.done(Job, IStatus, boolean) line: 152
JobManager.endJob(InternalJob, IStatus, boolean) line: 550
WorkerPool.endJob(InternalJob, IStatus) line: 105
Worker.run() line: 71
Re: Java model event delivery question-stack traces not formatted [message #246404 is a reply to message #246394] |
Tue, 31 July 2007 07:55 |
Junior Member |
I've noticed that the stack traces were not formatted. So here they are
again:
673
boolean) line: 148
1018
Object[]) line: 39
<unknown receiving
type>(DelegatingMethodAccessorImpl).invoke(Object, Object[]) line: 25
585
line: 38
673
boolean) line: 148
1018
line: 1806
112
Current Time: Tue Oct 01 10:43:57 GMT 2024
Powered by FUDForum. Page generated in 0.02705 seconds
