Home » Eclipse Projects » DSDP - Target Management » Copy local file to remote while maintaining directory structure
Copy local file to remote while maintaining directory structure [message #24178] Thu, 26 June 2008 05:57 Go to next message
Originally posted by: paul.pwrutter.com
Im trying to copy a local file to a target directory but i need to be able
to retain the directory structure of the file once it arrives on the
target.
EG...
Local file: /temp/folder1/file.txt
copied to: /targetFolder/someDirectory/folder1/file.txt
Does anyone have any ideas on how to achieve this?
Many Thanks
Paul
Re: Copy local file to remote while maintaining directory structure [message #24467 is a reply to message #24178] Tue, 01 July 2008 13:12 Go to previous message
Hello Paul,
if you're talking about doing this as a "User" through the RSE UI, you'd
want to use the Import/Export wizard: File > Export > Other > Remote
File System -- choose your source and target folders, and be sure to
"ignore" or "deselect" those subfolders that you do not want to export.
Note that the wizard can store your export in a file (*.rexpfd) that you
can easily re-play.
If you are talking about doing this programmatically from your own
plugin, you may want to look at some of the RSE Unit tests which do
exactly this:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.tm.rse/ tests/org.eclipse.rse.tests/src/org/eclipse/rse/tests/subsys tems/files/RSEFileStoreTest.java?root=DSDP_Project&view= markup
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Paul Rutter wrote:
> Hi
> able to retain the directory structure of the file once it arrives on
> the target. EG...
> Many Thanks
> Paul
Re: Copy local file to remote while maintaining directory structure [message #575676 is a reply to message #24178] Tue, 01 July 2008 13:12 Go to previous message
Hello Paul,
can easily re-play.
exactly this:
Paul Rutter wrote:
> Hi
> the target. EG...
> Many Thanks
> Paul
Previous Topic:FTP Only not working for IIS
Next Topic:RSE: ftp quit after each transfer
Current Time: Sat Sep 13 02:52:05 EDT 2025
Powered by FUDForum. Page generated in 0.03931 seconds
