Edit Part Thread [message #245905] |
Thu, 23 October 2008 22:28 |
Miles Parker Messages: 1341 Registered: July 2009 |
Hi all,
This has come up a few times in the past, but I'm not sure if I've seen
a good solution. I have a quite complex edit part tree that takes a
long time to build initially, this is literally from creating the
figures (1,000s) and walking the tree and no there is no way I can
reduce that. After initial draw the part is dynamically updated but
that happens quickly enough that it isn't an issue -- I have been very
happy with GEF performance in this regard and in fact it performs
really well when compared with raw SWT drawing! A lot of this is
because I don't have to redraw every figure so I can stand the overhead
of all of those extra objects, etc..
But for building the root tree the Platform UI is locked completely ==
not good. I'm on OS X so I don't know if part of this has to do with
that.
First, I'm not sure if this is entirely a GEF issue. It seems to me
that regardless of what you are doing in a given UI thread, the
platform should be able to manage this situation, unless we are in the
middle of a global paint / refresh. OTOH if all of the figure creation
is happening synchronously during an actual paint that is going to be
an issue. Perhaps I've implemented something incorrectly such that I'm
forcing a refresh children from paint or is that how GEF is intending
to implement things?
I guess I'm wondering if this is expected behavior, i.e. whenever there
is a big refresh of all children down from root edit part the whole UI
is locked. And if that is true, what if any strategies can I use to
mitigate that.
Re: Edit Part Thread [message #245913 is a reply to message #245905] |
Fri, 24 October 2008 02:40 |
OK, on further investigation it looks like there is some kind of
thrashing that is happening here that may somehow be due to the large
number of connections I'm creating. There is an odd validation cycle
where connections revalidate which triggers a parent layour
revaildation, which triggers a connection revalidation... Somehow this
seems to be spamming the event queue or something. Anyway, wanted to
update that this does not appear to be a painting issue per se.
On 2008-10-23 15:28:36 -0700, Miles Parker <milesparker@gmail.com> said:
> Hi all,
> that.
> mitigate that.
Re: Edit Part Thread [message #245928 is a reply to message #245913] |
Fri, 24 October 2008 10:03 |
Originally posted by: shady_86.sify.com
really this is a very unexpected thing since i have tried handling large number objects together in the logic example, but it never went slow.
i will suggest you to see the shapes example and change your architecture according to it and see the results...
FUDForum. Page generated in 0.03505 seconds
