Home » Archived » BIRT » how to get session attribute into reportContext?
how to get session attribute into reportContext? [message #245804] Mon, 02 July 2007 03:02 Go to next message
Originally posted by: amit.rajpurkar.pepsico.com.au
I am trying to get a java object from HttpSession in the report file.
in the DataSet's open method:
importPackage(Packages.au.com.pepsico.birt.data);
importPackage(Packages.javax.servlet.http);
var listFromSession =
reportContext.getHttpSession().getAttribute("CONTENTLIST");
iter = listFromSession.iterator();
Am i missing something in the code???
-Amit
Re: how to get session attribute into reportContext? [message #245926 is a reply to message #245804] Mon, 02 July 2007 10:33 Go to previous messageGo to next message
Amit,
This looks correct. What error are you getting?
Jason
Amit Rajpurkar wrote:
> -Amit
Re: how to get session attribute into reportContext? [message #246009 is a reply to message #245926] Mon, 02 July 2007 19:27 Go to previous messageGo to next message
Hi Jason,
Here was the error i got:
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT
exception occurred: Error evaluating Javascript expression. Script engine
error: TypeError: getHttpSession is not a function. (DataSet[Data
Set].__bm_OPEN#6)
now i have changed this code to:
importPackage(Packages.javax.servlet);
var request = reportContext.getHttpServletRequest();
var session = request.getSession();
var listFromSession = session.getAttribute("CONTENTLIST");
if(listFromSession != null){
this took away the error, but the report does not work.
i am using BIRT RCP designer 2.1.1 to develop reports. I use these reports
in a simple web application, in which a servlet calls a report design.
I found one more link:
http://wiki.eclipse.org/Retrieve_Session_information_in_Scri pt_(BIRT)
The sample i made following the above link works good in the preview
section of the designer;
But when i place the report in my web application, it shows a blank page.
From the servlet do i need to do something to send the session attributes
into the report?.
-Amit
Re: how to get session attribute into reportContext? [message #246046 is a reply to message #246009] Mon, 02 July 2007 23:37 Go to previous messageGo to next message
Amit,
I tried this report with BIRT 2.1.2 deployed to tomcat and it worked
fine. This may be an issue with 2.1.1.
Jason
> Hi Jason,
> engine error: TypeError: getHttpSession is not a function. (DataSet[Data
> Set].__bm_OPEN#6)
> reports in a simple web application, in which a servlet calls a report
> design.
> section of the designer; But when i place the report in my web
> attributes into the report?.
> -Amit
Re: how to get session attribute into reportContext? [message #246107 is a reply to message #246046] Tue, 03 July 2007 05:07 Go to previous message
Hi Jason,
It must be with version 2.1.1
We surely work in different time zones.
In the meantime today i search a lot and found some more useful links:
http://birtworld.blogspot.com/2006_03_01_archive.html
http://dev.eclipse.org/newslists/news.eclipse.birt/msg07596. html
http://www.ji.co.za/unplugged/?p=37
http://dev.eclipse.org/newslists/news.eclipse.birt/msg05292. html
http://birtworld.blogspot.com/2005/11/using-embedded-java-ob jects-within.html
the last one resolved my issue.
Within the servlet which calls my report design files, i added:
task.addScriptableJavaObject("MYLIST",sampleContent);
..and retrived this object in the report file.
This resolved my issue -- so instead of passing java object thru session,
i passed it this way. i am was able to get the POC up and running by the
evening.
I do have a serious comment though -- searching documents/references, etc
on BIRT site is a nightmare !!! But this newsgroup is definately useful :-)
-Amit
Previous Topic:Blank page issue with Birt 2.1.2
Next Topic:BIRT 2.2 - "Can't re-generate content" errors
Current Time: Fri Oct 24 17:59:35 EDT 2025
Powered by FUDForum. Page generated in 0.03742 seconds
