Home » Archived » BIRT » birt from europa's update site. requirement missing
- birt from europa's update site. requirement missing [message #245680] Sat, 30 June 2007 08:15 Go to next message
Originally posted by: vansickle.gmail.com
i've installed birt from update manager - just select birt and select
required - after that birt not working - no perspective (i've tried
-clean, of course). As it has turned out problem in that no dtp's help
(which required for connectivity).
- Re: birt from europa's update site. requirement missing [message #245784 is a reply to message #245680] Mon, 02 July 2007 02:37 Go to previous messageGo to next message
I had same symptoms with RC3 all in one package, when running on JDK 1.4.
Try to run it with JDK 1.5
Leos
- Re: birt from europa's update site. requirement missing [message #245829 is a reply to message #245784] Mon, 02 July 2007 04:23 Go to previous messageGo to next message
Originally posted by: matt.deity.co.nz
Exactly the same symptoms with JDK 1.6, because for some reason Eclipse
was randomly immediately crashing with JDK 1.5.
Nothing in logs, everything seemed fine in plugin list. Tried
uninstalling, reinstalling, eclipse -clean, waving dead chickens,
etcetera.
Eventually replaced Eclipse install with all-in-one and it worked. I
hate to winge, because when BIRT works it's beautiful - but it does
seem a highly temperamental beast (and is currently horribly broken in
other ways; see my other posts!)
M
- Re: birt from europa's update site. requirement missing [message #245860 is a reply to message #245829] Mon, 02 July 2007 06:28 Go to previous messageGo to next message
Originally posted by: Peter.Mayne.hp.com
What do I have to do to get BIRT 2.2 working on an existing Europa
installation?
The all-in-one download works, but neither the framework download
unzipped or the update manager work. Comparing configurations, the
all-in-one download has more features than the framework, which in turn
has more features than update manager provides.
What's the problem?
Thanks.
PJDM
Peter Mayne
- Re: birt from europa's update site. requirement missing [message #245872 is a reply to message #245860] Mon, 02 July 2007 06:57 Go to previous messageGo to next message
Originally posted by: jk.email.com
Same problem here. The all-in-one package works, installing it using the
update manager does not. A fix for this would be great!
JK
- Re: birt from europa's update site. requirement missing [message #245889 is a reply to message #245872] Mon, 02 July 2007 09:40 Go to previous messageGo to next message
After installing BIRT Report designer framework from the Europa site
and restarting the workbench, return to "find and install new
features" and install the BIRT SDK from the BIRT update site and
required features, like oda.
Bernd
- Re: birt from europa's update site. requirement missing [message #246190 is a reply to message #245680] Tue, 03 July 2007 19:10 Go to previous messageGo to next message
Thanks for reporting the problem.
After looking at different options, we will fix the DTP feature dependency
in Europa update sites. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195210.
With the limited resources available this week, the updates will hopefully
be available this Thur., after the holiday.
Note that this problem does not exist if installing BIRT with its download
packages, such as the birt-dtp-integration-2_2_0.zip package or the
all-in-one packages.
Linda
"Pavel Samokha" <vansickle@gmail.com> wrote in message
news:f65hhp$g3u$1@build.eclipse.org...
> tried -clean, of course). As it has turned out problem in that no dtp's
> help (which required for connectivity).
- Re: birt from europa's update site. requirement missing [message #246831 is a reply to message #245680] Mon, 09 July 2007 01:46 Go to previous message
There was a missing feature dependency in
org.eclipse.datatools.connectivity.oda.designer.feature.
The workaround is to install both DTP and BIRT, which will install the
missing DTP feature.
Or additionally select "Europa Discovery Site"->"Database Development"->
"Data Tools Platform Documentaion 1.5.0.200706221" feature after you clicked
"Select Required..." when installing BIRT thru Europa discovery site.
The related bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=195210
Xiaoying
Previous Topic:Custom hyperlink
Next Topic:Localization in Computed Column
Current Time: Mon Apr 21 12:58:21 EDT 2025
Powered by FUDForum. Page generated in 0.04137 seconds
