Osgi - Razberry /dev/ttyAMA0 doesn't exist [message #1396428] |
Tue, 08 July 2014 09:26 |
cyril praz Messages: 1 Registered: July 2014 |
Junior Member |
I want to do a network between z-waves sensors and a raspberry pi with the razberry's module.I used for that the framework Prosyst. Even I followed the user guide, I can't establish a connection between the razberry and the z-wave controller from Osgi used by Prosyst. Osgy say that the port /dev/ttyAMA0 doesn't exist.
I have tested with the software delivered by razberry and it's work fine.
Here is the guide I followed : ht tp://dz.prosyst.com/pdoc/mBS_SH_SDK_7.3.0/modules/zwave/overview/setup.html
and here the error message displayed:
176 ERROR > Can not open connection to controller. org.osgi.service.cm.ConfigurationException: port : Port /dev/ttyAMA0 does not exist at com.prosyst.mbs.impl.services.zwave.Activator._updated(Activator.java:739) at com.prosyst.mbs.impl.services.zwave.Activator.access$1500(Activator.java:44) at com.prosyst.mbs.impl.services.zwave.Activator$ManagedServiceFactoryImpl$1.run(Activator.java:342) at com.prosyst.util.impl.tpt.threadpool.ExecutorImpl.run(ExecutorImpl.java:191)
FUDForum. Page generated in 0.03163 seconds
