Home » Newcomers » Newcomers » Refreshing a View?
Refreshing a View? [message #244919] Mon, 07 January 2008 14:33 Go to next message
Originally posted by: hiteshn.mail.gmail.com
I created a View (Sampleview) which shows the outline of the diagram on the
canvas. This view is used for easier navigation. The problem I'm facing is
refreshing the view. When I have multiple diagram files opened, the
SampleView still shows the outline of first file. This problem is rectified
if I close that view and re-open it again. Please help me in solving this
problem.
Hitesh.
Re: Refreshing a View? [message #244924 is a reply to message #244919] Mon, 07 January 2008 16:26 Go to previous message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
Try adding an IPartListener (via the addPartListener method) to the page.
Something like this in your createPartControl method should do it:
public void createPartControl(Composite parent) {
getSite().getPage().addPartListener(new IPartListener() {
public void partActivated(IWorkbenchPart part) {
if (part instanceof MyEditor) refreshFor((MyEditor)part);
// snip
// snip
The partActivated method will be invoked when the user brings any editor
or view to the top. If that editor or view is an editor you care about,
update (refresh) the view. You may also want to override
partBroughtToTheTop; the comments on the method indicate that it is
called when the part is brought forward programmatically.
Make sure you remove the listener in the dispose method.
HTH,
Wayne
Hitesh Nembhwani wrote:
> problem.
> Hitesh.
Previous Topic:[EMF] Writing an application that writes code
Next Topic:Download source for SWT and/or Junit, per tutorial instructions?
Current Time: Sat Oct 25 13:22:48 EDT 2025
Powered by FUDForum. Page generated in 0.42829 seconds
