Home » Language IDEs » Java Development Tools (JDT) » Defect in flow analysis ?
Defect in flow analysis ? [message #244615] Mon, 18 June 2007 03:28 Go to next message
Originally posted by: none.domain.invalid
Should i report a bug for this :
public class TestUndefined {
Object throwRuntimeException() {
throw new RuntimeException();
void test1() {
Object o;
try {
o = throwRuntimeException();
} finally {
// The local variable o may not have been initialized
o.hashCode();
void test2() {
Object o;
try {
} finally {
// nothing reported
o.hashCode();
Re: Defect in flow analysis ? [message #244624 is a reply to message #244615] Mon, 18 June 2007 06:27 Go to previous messageGo to next message
If in test2, an exception is thrown, o.hashCode() won't be reached,
right? In other words, if o.hashCode is call in test2(), then it must
have been initialized properly.
> void test1() {
> Object o;
> try {
> } finally {
> o.hashCode();
> void test2() {
> Object o;
> try {
> } finally {
> // nothing reported
> o.hashCode();
Re: Defect in flow analysis ? [message #244628 is a reply to message #244624] Mon, 18 June 2007 06:46 Go to previous message
Thanks of the explanation. With a catch block i get an error, so it's ok.
Previous Topic:Code formatting problem of AST (import statement)
Next Topic:Package Explorer - packages in source folder are hidden
Current Time: Tue Nov 04 10:23:36 EST 2025
Powered by FUDForum. Page generated in 0.24384 seconds
