DataSource Connection Parameters in a library [message #244576] |
Mon, 25 June 2007 13:10 |
Originally posted by: john.johnhornsby.me.uk
I want to create a library, that is included in my reports, where I only
define datasource properties in one place.
I'm using the datasource property bindings to set the values - which are
read from a properties file by a java class. The only thing that needs to
be defined is the properties filename.
I'm having trouble because there is some global initialisation code I wish
to run before the database property bindings are executed.
"beforeOpen" on the datasource would have been good but it seems to run
after the property bindings run.
How can I make my "global" code run before the datasource property bindings?
I want to keep all the code in the library and not have to repeat any code
in the reports.
John
FUDForum. Page generated in 0.03870 seconds
