How to set up a JAVA_HOME based JRE ? [message #244532] |
Thu, 14 June 2007 17:51 |
Originally posted by: christian.bach.swx.ch
Dear newsgroup readers
I am struggling with the configuration of a Java Application launcher;
I would like to link the "Runtime JRE" to ${env:JAVA_HOME}, which is
predefined in the shell eclipse itself was started in and
which is about being promoted to the shell the launcher will run its
configuration in. - Similar to the possibilites to resolve arguments on
promoted environment variables under the Arguments tab.
I tried to set up a JAVA_HOME based JRE, by trying to introduce an
"Installed JRE" based on ${env:JAVA_HOME} with no success neither, as
"Installed JREs" are supposed to be referenced by absolute path.
How can I setup a Java Application launcher that has ist JRE based on
${env:JAVA_HOME} ? This seems currently impossible. Does anyone know of
any plans of supporting such a need ? Or some means of achieving it
today ?
Thanks for your replies, Christian.
Re: How to set up a JAVA_HOME based JRE ? [message #244569 is a reply to message #244561] |
Sun, 17 June 2007 07:11 |
Darin, thanks for your reply.
I submitted a feature request under
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192951
Darin Wright wrote:
> Please file a feature request - we currently do not support this.
> Darin Wright
> "christian bach" <christian.bach@swx.ch> wrote in message
> news:f4rv42$nbq$1@build.eclipse.org...
>>today ?
FUDForum. Page generated in 0.03720 seconds
