Zooming problem: class org.eclipse.draw2d.ScaledGraphics has not implemented this new graphics funct [message #244117] |
Sun, 06 July 2008 10:47 |
Originally posted by: clandestinesnehal.gmail.com
I am trying to use the zooming capabilities of GEF. I have followed the
Logic example.
I have placed the zoom-in and zoom-out actions in the context menu, but
i am getting the following exception on clicking the 'zoom' actions:
Exception: Failed to execute runnable (java.lang.RuntimeException: class
function)
Can someone please shade light on the problem?
-Snehal
Re: Zooming problem: class org.eclipse.draw2d.ScaledGraphics has not implemented this new graphics f [message #244196 is a reply to message #244140] |
Wed, 09 July 2008 06:18 |
Thanks Anthony,
So, i understand that RoleFigure does not support scaling. How do i make
it support scaling?
Here is the exception trace:
Caused by: java.lang.RuntimeException: The class: class
function
at org.eclipse.draw2d.Graphics.subclassFunctionMission(Graphics .java:897)
at org.eclipse.draw2d.Graphics.drawPath(Graphics.java:202)
org.acmestudio.ui.editor.diagram.figure.RoundedJumpingRoleCo nnection.drawWithCornerRounding(RoundedJumpingRoleConnection .java:299)
org.acmestudio.ui.editor.diagram.figure.RoundedJumpingRoleCo nnection.outlineShape(RoundedJumpingRoleConnection.java:243)
org.acmestudio.ui.editor.diagram.figure.RoleFigure.outlineSh ape(RoleFigure.java:259)
at org.eclipse.draw2d.Shape.paintFigure(Shape.java:113)
org.acmestudio.ui.editor.diagram.figure.RoleFigure.paintFigu re(RoleFigure.java:458)
at org.eclipse.draw2d.Figure.paint(Figure.java:1049)
org.acmestudio.ui.editor.diagram.figure.SystemFigure.paintCh ildren(SystemFigure.java:375)
org.acmestudio.ui.editor.diagram.figure.SystemFigure.paintCl ientArea(SystemFigure.java:246)
at org.eclipse.draw2d.Figure.paint(Figure.java:1051)
org.acmestudio.ui.editor.diagram.figure.SystemFigure.paint(S ystemFigure.java:237)
at org.eclipse.draw2d.Figure.paintChildren(Figure.java:1087)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1119)
org.eclipse.draw2d.ScalableFreeformLayeredPane.paintClientAr ea(ScalableFreeformLayeredPane.java:69)
at org.eclipse.draw2d.Figure.paintClientArea(Figure.java:1114)
at org.eclipse.draw2d.Viewport.paintClientArea(Viewport.java:15 6)
org.eclipse.draw2d.DeferredUpdateManager.paint(DeferredUpdat eManager.java:153)
at org.eclipse.draw2d.LightweightSystem.paint(LightweightSystem .java:199)
org.eclipse.draw2d.LightweightSystem$2.handleEvent(Lightweig htSystem.java:107)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:11 73)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3725 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:291)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.RedrawWindow(Native Method)
at org.eclipse.swt.widgets.Control.update(Control.java:3537)
at org.eclipse.swt.widgets.Control.update(Control.java:3527)
org.eclipse.draw2d.NativeGraphicsSource.getGraphics(NativeGr aphicsSource.java:43)
org.eclipse.draw2d.DeferredUpdateManager.getGraphics(Deferre dUpdateManager.java:136)
org.eclipse.draw2d.DeferredUpdateManager.repairDamage(Deferr edUpdateManager.java:286)
org.eclipse.draw2d.DeferredUpdateManager.performUpdate(Defer redUpdateManager.java:179)
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run(D eferredUpdateManager.java:46)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 23 more
Anthony Hunter wrote:
> Hi Snehal,
> There is a shape on your diagram that does not support scaling. Do you have
> a gradient or background pattern somewhere? The stack trace will give you a
> hint.
> Cheers...
> Anthony
> "Snehal Fulzele" <clandestinesnehal@gmail.com> wrote in message
> news:g4ptcj$hjv$1@build.eclipse.org...
>> Logic example.
>> I have placed the zoom-in and zoom-out actions in the context menu, but i
>> function)
>> -Snehal
FUDForum. Page generated in 0.03352 seconds
