Home » Archived » BIRT » Using Hibernate Data Source
Using Hibernate Data Source [message #243601] Wed, 20 June 2007 11:34 Go to next message
Originally posted by: jam263.gmail.com
I am using BIRT 2.2.0 and launching the BIRT Report Viewer through an
action in my RCP application. To launch the viewer I am using one of the
WebViewer.deploy() methods. I have some custom data sources/sets that use
my Hibernate classes. On the open method of my data set I have some
initializing code:
importPackage(Packages.company.db.package)
values = MyHibernateClass.getValues();
count = 0;
Then, on the fetch method of the data set I have additional code:
if (values.length == count)
return false;
row.name = values[count].toString();
count++;
return true;
When I preview the report using the Report Designer plug-in everything
seems to work fine. However, in my runtime environment if I don't place
my jar files into the
ECLIPSE_HOME/plugins/org.eclipse.birt.report.viewer_2.2.0.v2 0070611/birt/WEB-INF/lib
directory, I get the error below. Is there a way to access my Hibernate
classes in the script without having to put the jar files (along with
dependencies) into the WEB-INF/lib directory?
Thanks in advance.
- There are errors evaluating script
"importPackage(Packages.company.db.package)
count = 0;":{1}.
Error.ScriptEvaluationError ( 1 time(s) ) detail :
org.eclipse.birt.report.engine.api.EngineException: There are errors
evaluating script "importPackage(Packages.company.db.package)
count = 0;":{1}.
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:77)
org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:159)
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:6 6)
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:79)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:244)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :220)
org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:761)
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:216)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:152)
org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:83)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:155)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:115)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:178)
org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1669)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:82)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:61)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 5)
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:42)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:33)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:126)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:84)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:90)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:148)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:71)
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
Source)
Source)
org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.BirtGetPageAll ActionHandler.__execute(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPageAll(Unknown
Source)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(Unknown
Source)
org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(Unknown
Source)
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:453)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Thread.java:595)
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT
exception occurred: Error evaluating Javascript expression. Script engine
error: ReferenceError: "MyHibernateClass" is not defined. (DataSet[My Data
Set].__bm_OPEN#3)
Script source: DataSet[My Data Set].__bm_OPEN, line: 1, text:
__bm_OPEN(). See next exception for more information.
Error evaluating Javascript expression. Script engine error:
Set].__bm_OPEN#3)
__bm_OPEN()
org.eclipse.birt.data.engine.core.DataException.wrap(DataExc eption.java:118)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:557)
org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:79)
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:71)
... 86 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating
Javascript expression. Script engine error: ReferenceError:
"MyHibernateClass" is not defined. (DataSet[My Data Set].__bm_OPEN#3)
__bm_OPEN()
org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoExc eption(JavascriptEvalUtil.java:281)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:105)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:137)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:553)
... 88 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError:
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRun time.java:3303)
org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu ntime.java:1632)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1571)
at org.mozilla.javascript.gen.c24._c1(DataSet[My Data Set].__bm_OPEN:3)
at org.mozilla.javascript.gen.c24.call(DataSet[My Data Set].__bm_OPEN)
org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:105)
at org.mozilla.javascript.gen.c25._c0(DataSet[My Data Set].__bm_OPEN:1)
at org.mozilla.javascript.gen.c25.call(DataSet[My Data Set].__bm_OPEN)
org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c25.exec(DataSet[My Data Set].__bm_OPEN)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:98)
... 90 more
Re: Using Hibernate Data Source [message #243706 is a reply to message #243601] Wed, 20 June 2007 17:07 Go to previous messageGo to next message
Jeff,
Are all the hibernate files in a plugin? If so you can setup a buddy
policy with the BIRT viewer.
Eclipse-BuddyPolicy: registered to the viewer manifest
to your plugin
Eclipse-RegisterBuddy: org.eclipse.birt.report.viewer
You can also get classes from script that exist in other plugins like:
importPackage(Packages.org.eclipse.core.runtime);
mybundle = Platform.getBundle(“bundle-name”).
bnd = mybundle.loadClass("classname");
cl1 = bnd.newInstance();
xyz = cl1.getMyMethod();
You can also set the scriptlibdir in the web.xml to point to a directory
to add to the classpath.
Jason
> the WebViewer.deploy() methods. I have some custom data sources/sets
> that use my Hibernate classes. On the open method of my data set I have
> some initializing code:
> count = 0;
> return false;
> count++;
> return true;
> Thanks in advance.
> count = 0;":{1}.
> count = 0;":{1}.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> engine error: ReferenceError: "MyHibernateClass" is not defined.
> Set].__bm_OPEN#3)
> __bm_OPEN()
> at
> at
> at
> at
> ... 86 more
> evaluating Javascript expression. Script engine error: ReferenceError:
> __bm_OPEN()
> at
> at
> at
> at
> ... 88 more
> at
> at
> at
> at
> at
> at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
> at
> ... 90 more
Re: Using Hibernate Data Source [message #243999 is a reply to message #243706] Thu, 21 June 2007 11:48 Go to previous messageGo to next message
Jason,
Yes, all of my Hibernate classes are contained within a plug-in. I did as
you suggested and modifed the manifest of the viewer and the manifest of
my Hibernate plug-in to be registered as buddies. This worked! I was
able to access my Hibernate classes in my report scripts during run-time
without having to add the jar files to the WEB-INF directory.
Thanks!
Re: Using Hibernate Data Source [message #244031 is a reply to message #243999] Thu, 21 June 2007 12:32 Go to previous message
Good to hear.
Jeff Martin wrote:
> Jason,
> as you suggested and modifed the manifest of the viewer and the manifest
> of my Hibernate plug-in to be registered as buddies. This worked! I
> was able to access my Hibernate classes in my report scripts during
> run-time without having to add the jar files to the WEB-INF directory.
> Thanks!
Previous Topic:DataSource changed with Birt API but no changes in the generated report.
Next Topic:XLS emitter in report engine - "Error.OutputFormatNotSupported"
Current Time: Fri Oct 17 14:38:03 EDT 2025
Powered by FUDForum. Page generated in 0.19462 seconds
